Old 12th February 2012, 00:58   #14701  |  Link
clsid
There is a function called sws_setColorspaceDetails in swscale. That might be useful.
Old 12th February 2012, 02:20   #14702  |  Link
haruhiko_yamagata
I have already tried that. It doesn't help.
As far as I can see, it works only for 8-bit YCbCr to RGB conversion.
[ Download ffdshow | Wiki ]
haruhiko_yamagata is offline   Reply With Quote
Old 12th February 2012, 04:17   #14703  |  Link
CruNcher
CruNcher's Avatar
haruhiko_yamagata did you saw that ?
https://forum.doom9.org/showpost.php...1&postcount=16
It is about Time
Old 12th February 2012, 06:03   #14704  |  Link
haruhiko_yamagata
Thanks for the link. I'll consider importing next time I can spare time for subtitles.
Old 12th February 2012, 14:13   #14705  |  Link
haruhiko_yamagata
Thats quite normal, ffdshow will try to not output frames that show corruption, and a B frame needs more then the first I frame to be decodable without corruption.
No, that two B frames are dropped unintentionally.
Any pictures decoded after an IDR picture should be displayed even if the POC is earlier than the IDR picture.
I don't know where the bug is, ffdshow or libavcodec. Not likely in ffdshow, but not sure...
Old 12th February 2012, 14:16   #14706  |  Link
nevcairiel
The point remains that a B-frame is bi-predictive, which means it needs two reference frames. avcodec itself will not decode a B-frame if it doesn't have two references yet, unless you set a special flag to blindly decode everything.
Old 12th February 2012, 16:54   #14707  |  Link
Vincent Vega
rgb16, i want you back
guys, scary story: i use 2002 via kle133 mobo with trident blade3d 8mb graphics on xp, can only handle 16bit color at 1280x1024. i output rgb from ffdshow to have control over conversion coefficients. after rev3765 even though theres no explicit rgb16 output option, ffdshow still connects normally in rgb16 to vmr7 (with rgb32/24-only checked in settings). but with directvobsub in between ffdshow and vmr7, it outputs rgb32/24, and following conversion rgb32/24->rgb16 in directvobsub produces unwatchable messed up picture. i didnt have much luck using ffdshow's own subtitler either on this computer.
so i need rgb16 option back or i'll be stuck with r3764 foreva -)
Vincent Vega is offline   Reply With Quote
Old 12th February 2012, 23:12   #14708  |  Link
egur
QuickSync Decoder author
Funny
Eric Gur,
Processor Application Engineer for Overclocking and CPU technologies
Intel QuickSync Decoder author
Intel Corp.
egur is offline   Reply With Quote
Old 13th February 2012, 02:36   #14709  |  Link
mandarinka
mandarinka's Avatar
This might not work but it's worth to try it:
Open directvobsub setitngs, and on the tab with list of preferred colorspaces, move rgb565 all the way up. Maybe that makes directvobsub to negotiate a 16bit connection. Too bad you can't remove colorspaces from the list, to make vsfilter not accept them...
mandarinka is offline   Reply With Quote
Old 13th February 2012, 06:04   #14710  |  Link
Vincent Vega
thanks i tried that before too, same result. those i think are preferences for output colorspace (vobsub->renderer)
Old 13th February 2012, 10:57   #14711  |  Link
haruhiko_yamagata
I think it is not illegal for B-frames to have only one reference frame.
See ITU-T Recommendation, Advanced video coding for generic audiovisual services, 3.8 B slice.
In my opinion, it's a bug. I would admit if there are different opinions, but ffdshow already has way to drop unnecessary frames. Double check is unwanted.
What is the special flag called?
Old 13th February 2012, 12:33   #14712  |  Link
kc7bfi
Originally Posted by kc7bfi View Post
Not sure why its not working there. It works fine here, although I'm using 64bit. You should not need anything other filters. The key message is "RTPSource could not resolve streams, no data received" which seems to indicate that it could not read/process the video information from the PCAP file (a wireshark capture). Maybe you need wireshark installed. I'll ask the guy who wrote our wireshark replay service. Thanks. David
Sorry, I don't know why it is not working there. The only other thing I can think of is if your machine has two active NICs. The replay reads the video packets from the PCAP file and re-broadcasts them on the multicast address. If for some reason the multicast traffic gets bound to a different NIC than your primary there there can be an issue. But that's a long shot. Thanks anyway for looking at it. I still have the problem but will need to look at another way to reproduce it. David
kc7bfi is offline   Reply With Quote
Old 13th February 2012, 13:02   #14713  |  Link
clsid
CODEC_FLAG2_SHOW_ALL, but it is only used in FFmpeg, not in Libav.
Old 13th February 2012, 13:59   #14714  |  Link
haruhiko_yamagata
@kc7bfi,
How does your filter feed SPS/PPS to ffdshow?
Is it given as codec private data on connection? or is it given to IMemInputPin::Receive?
How NAL unit size is handled for SPS/PPS?
This is an important question. Can anyone in your company answer?
Old 13th February 2012, 14:47   #14715  |  Link
haruhiko_yamagata
Thanks. I'm reading Libav. It's not easy...
Old 14th February 2012, 17:55   #14716  |  Link
hoborg
Hi.
Is there a way how to force FFDshow installer to deploy quicksync decoder even if my Intel HD Graphics 2000 GPU is disabled right now?
Working machine: Win10x64 + Intel Skull Canyon
My HTPC.
How to start with Bitcoin
hoborg is offline   Reply With Quote
Old 14th February 2012, 19:30   #14717  |  Link
gendouhydeist
There's seems to be a problem with the latest revision of ffdshow whenever I play a h264 file. The player just keep crashing on Y416 output, It doesn't happen on 4319 though.
gendouhydeist is offline   Reply With Quote
Old 15th February 2012, 11:44   #14718  |  Link
CruNcher
CruNcher's Avatar
It seems SPP doesn't work with ffdshow-quicksync http://www.mediafire.com/?0n9f62ih6f5chn4 it works externally though
It is about Time
Old 15th February 2012, 12:31   #14719  |  Link
clsid
That has nothing to do with QS. PP is skipped when decoding H.264.
Old 15th February 2012, 12:35   #14720  |  Link
CruNcher
CruNcher's Avatar
But why restricting it to any format and this isn't H.264 but Mpeg-2 and it doesn't work ?
Here it's working when forcing it externaly http://www.mediafire.com/?op1aegifswodc8p
It is about Time
