1st December 2005, 21:50 | #261 | Link | |||
Get my avisynth filters @ http://www.avisynth.org/tsp/ Last edited by tsp; 1st December 2005 at 22:31. |
1st December 2005, 22:46 | #262 | Link |
Brazilian Anime Ripper
Well here is some screens using bh=bw=32 and bh=bw=64 and the original without fft3dgpu.
fft3dgpu_screens.rar edit:Your special version is slight better than v0.51.
Capture cards: Compro VideoMate Gold+ (Philips SAA7134 based) (not active) Hauppauge PVR 150MCE (not active) ATI TV Wonder Elite (active) Last edited by acrespo; 1st December 2005 at 23:08. |
1st December 2005, 23:20 | #263 | Link |
acrespo: I'm not sure that the grid you are seeing is the same grid artifact that I'm talking about. For me it looks like the gridsize is about 4x4 pixels when using bh=bh=32 and if you look closely at the original the 4x4 grid is ever sligtly present. If you want to see how the grid artifacts looks like with fft3dgpu try this (the grid that then appears has a gridsize of bw/2, bh/2):
fft3dgpu(mode=1,sigma=1000,degrid=0.0) But you are right about the grid disappears when using bw=bh=64. It looks like the the image is more blurry with that setting. What codec is the capture file saved in? It could be that the grid is caused by enhancing the artifacts from the compression.
Get my avisynth filters @ http://www.avisynth.org/tsp/ |
2nd December 2005, 02:02 | #264 | Link |
I always capture with PIC MJPEG 3 quality 19 (or decrease some chrominance and luminance to between quality 18 and 19).
I understood the grid you explain now. Well I don't understand why bh=bw=64 resolved my problem, because this setting have closely to fft3dfilter with bh=bw=48 (defaults). Can be something wrong with 32 setting?
Capture cards: Compro VideoMate Gold+ (Philips SAA7134 based) (not active) Hauppauge PVR 150MCE (not active) ATI TV Wonder Elite (active) |
2nd December 2005, 10:54 | #265 | Link | ||
Learning...
Slower codec ? Hmm... DivX at "Insane quality" ? Until an upgrade, it's fft3dfilter for me... |
2nd December 2005, 11:13 | #266 | Link |
interlace this!
slower codec like snow or dirac...
x264 is always good (it's pretty fast too). definitely not divx at insane quality... it's not worth it (the insanity lies in wondering why something could take so long while not looking as nice as an xvid encode...)
sucking the life out of your videos since 2004 |
5th December 2005, 13:57 | #268 | Link |
tsp, I have guestions for you... (best phrase on my bad English )
1) I can't found reduceCPU on last docs 2) I found about you comment "reduceCPU" 3) CPU busy 100% - -------------- FFT3DFilter(bt=4,plane=0) FT3DGPU(bt=4,mode=1,plane=1) -------------- my CPU busy 80% - -------------- FT3DGPU(bt=4,mode=1,plane=1) FFT3DFilter(bt=4,plane=0) -------------- I undestend about it... (You sad about it already) but earlier 20% busy kernel (in taskmanager) 4) -------------------- i=DePanEstimate(Last,dxmax=24,dymax=0,fftw=True) Pre2=DePan(Last,i,offset=+2,subpixel=1,matchfields=false,mirror=3).Crop(80,0,-80,0) Prev=DePan(Last,i,offset=+1,subpixel=1,matchfields=false,mirror=3).Crop(80,0,-80,0) Next=DePan(Last,ir,offset=-1,subpixel=1,matchfields=false,mirror=3).Crop(80,0,-80,0) Clip Interleave(Pre2,Prev,Last,Next) FFT3DFilter(sigma=5,sigma2=4,sigma3=3,sigma4=2,bt=4,plane=0) SelectEvery(4,2) Interleave(Pre2,Prev,Last,Next) # a) Busy 80% #Interleave(Last,Pre2,Prev,Last,Next) # b) Busy 80% #Interleave(Last,Pre2,Prev,Last) # c) Busy 100% - Good! #Interleave(Pre2,Prev,Last,MergeLuma(Next,Trim(1,0))) # d) Busy 100% - Good! - My Idea about a+c (or b+c) FFT3DGPU(sigma=7,bt=4,mode=1,plane=1) SelectEvery(4,2) # a) #SelectEvery(5,3) # b) #SelectEvery(4,3) # c) #SelectEvery(4,3) # b) ------------------- |
5th December 2005, 15:12 | #269 | Link |
AI:
1 and 2: I removed reduceCPU in version 0.5 so that is why you can't find it. 3: That is because fft3dGPU is about 6-7 times faster than fft3dfilter in that script so the reason you see a 80% cpu utilization is that fft3dfilter uses most of the time. In this case it might be worth it to set UseFloat16=false to increase the quality. This shouldn't affect the process time very much but try and see: Code:
FTT3DGPU(bt=4,mode=1,plane=1,usefloat16=false) FFT3DFilter(bt=4,plane=0) Code:
FTT3DGPU(bt=4,mode=1,plane=1) FFT3DGPU(bt=4,mode=1,plane=0) a) look right to me. Might be a little faster like this: Code:
i=DePanEstimate(Last,dxmax=24,dymax=0,fftw=True) Pre2=DePan(Last,i,offset=+2,subpixel=1,matchfields=false,mirror=3).Crop(80,0,-80,0) Prev=DePan(Last,i,offset=+1,subpixel=1,matchfields=false,mirror=3).Crop(80,0,-80,0) Next=DePan(Last,ir,offset=-1,subpixel=1,matchfields=false,mirror=3).Crop(80,0,-80,0) Clip Il=Interleave(Pre2,Prev,Last,Next) MergeChroma(il.FFT3dFilter(sigma=5,sigma2=4,sigma3=3,sigma4=2,bt=4,plane=0),il. FFT3DGPU(sigma=7,bt=4,mode=1,plane=1)) SelectEvery(4,2)
6th December 2005, 06:36 | #270 | Link |
next question:
FFT3DGPU().FFT3DFilter() - GPU first, CPU secont (in script, realy on the contrary) Why v0.47 Busy Kernel = 20% (i.e. wait when work GPU, and CPU busy = 100%) now (v0.51) CPU idle = 20% (Kernel Busy =1-2%, i.e. I/O only) |
6th December 2005, 11:33 | #271 | Link |
AI: I change the inner working of this filter somehow in version 0.5. The frame is now uploaded to the GPU while the GPU is working on the frame and the number of passes needed to process the frame is also reduced(that might save a switch to the kernel to process the commands to the GPU). But I think it is a good thing that the kernel and cpu utilization is lower now.
6th December 2005, 13:56 | #272 | Link |
ask again: (possible error on your optimize algoritm)
usual script: Code:
i=DePanEstimate(Last,fftw=True) Pre2=DePan(Last,i,offset=+2,subpixel=1,matchfields=false,mirror=3) Prev=DePan(Last,i,offset=+1,subpixel=1,matchfields=false,mirror=3) Next=DePan(Last,i,offset=-1,subpixel=1,matchfields=false,mirror=3) Interleave(Pre2,Prev,Last,Next) MergeChroma(FFT3DFilter(bt=4,plane=0),\ FFT3DGPU(bt=4,mode=1,plane=1)) SelectEvery(4,2) optimize script: Code:
i=DePanEstimate(Last,fftw=True) Pre2=DePan(Last,i,offset=+2,subpixel=1,matchfields=false,mirror=3) Prev=DePan(Last,i,offset=+1,subpixel=1,matchfields=false,mirror=3) Next=DePan(Last,i,offset=-1,subpixel=1,matchfields=false,mirror=3) Interleave(Pre2,Prev,Last,Next) FFT3DFilter(bt=4,plane=0) SelectEvery(4,2) Interleave(Last,Pre2,Prev,Last,Next) FFT3DGPU(bt=4,mode=1,plane=1) SelectEvery(5,3) FFT3DGPU ask from AVISynth frame n+2, (on this script n+1 after Interleave().FFT3DFilter().SelectEvery()) But this script not use 100% CPU not right,but realy optimize script: Code:
i=DePanEstimate(Last,fftw=True) Pre2=DePan(Last,i,offset=+2,subpixel=1,matchfields=false,mirror=3) Prev=DePan(Last,i,offset=+1,subpixel=1,matchfields=false,mirror=3) Next=DePan(Last,i,offset=-1,subpixel=1,matchfields=false,mirror=3) Interleave(Pre2,Prev,Last,Next) FFT3DFilter(bt=4,plane=0) SelectEvery(4,2) Interleave(Last,Pre2,Prev,Last) FFT3DGPU(bt=4,mode=1,plane=1) SelectEvery(4,3) And I fount decision: First script string "Interleave(Pre2,Prev,Last,Next)" change to "Interleave(Pre2,Prev,Last,MergeLuma(Next,Trim(1,0)))" now CPU use 100% and all frames (n+1 too) is compensation. PS very difficult write on not native language Last edited by AI; 7th December 2005 at 05:18. |
6th December 2005, 15:17 | #273 | Link |
What about the framerate? Also how does my script above perform?
7th December 2005, 01:13 | #274 | Link |
12th December 2005, 23:49 | #276 | Link |
Nope. Compare it to the overlap picture in the fft3dfilter documentation. Yellow= 4 block overlap. red=2 block overlap and turquoise=no overlap.
the YUV option will be implemented as it is in fft3dfilter so the filter converts: fft3dgpu(plane=4) to fft3dgpu(plane=0) last.fft3dgpu(plane=1)
13th December 2005, 10:17 | #277 | Link | |
YToUV(fft3dfilter(sigma=3, plane=1).UToY,\ fft3dfilter(sigma=3, plane=2).VToY,\ fft3dfilter(sigma=2, plane=0)) Is that equiv to what you are saying is the way to process all planes? |
13th December 2005, 13:18 | #278 | Link |
sorry didn't look closely at the fft3dfilter sourcecode. Fizick implemented it like you said but I don't understand why because it produces the same result as my script just with more copying from one plane to another. Try this script. It should be grey if the result is the same:
src=avisource("f:\20051210-143802.avi") motion=src.DepanEstimate(trust=2.5, fftw=true) src.DepanInterleave(data=motion) YToUV(fft3dfilter(sigma=3, plane=1).UToY,\ fft3dfilter(sigma=3, plane=2).VToY,\ fft3dfilter(sigma=2, plane=0)) a=SelectEvery(3,1) src.DepanInterleave(data=motion) fft3dfilter(sigma=3, plane=1) fft3dfilter(sigma=3, plane=2) fft3dfilter(sigma=2, plane=0) b=SelectEvery(3,1) subtract(a,b).Levels(127, 1, 129, 0, 255)
14th December 2005, 05:39 | #279 | Link |
tsp
What about speed? first script faster! Give "filter" with matrix 121 (as Convolution3D but only temporal) filter.filter = "filter" with matrix 14641 filter.filter.filter = "filter" with matrix [1 6 15 20 15 6 1] if pre filter = matrix [1] then 1 1 2 1 1 4 6 4 1 1 6 15 20 15 6 1 i.e. triangle Pascal (SelectEvenString ) i.e. if use several temopral filters, it more temporal i.e. need Code:
DePanInterleave(...) filtre1() selectevery(3,1) DePanInterleave(...) filtre2() selectevery(3,1) DePanInterleave(...) filtre3() selectevery(3,1) Code:
DePanInterleave(prev=3, next=3) filtre1() filtre2() filtre3() selectevery(7,3) if filters "independent" Code:
DePanInterleave(prev=1, next=1) MergeChroma(filtre1(),filtre2()) selectevery(3,1) Last edited by AI; 15th December 2005 at 05:16. |
14th December 2005, 13:17 | #280 | Link |
AI: that is what the build in cache is for. So in my script the filterchain really look like this:
src.DepanInterleave(data=motion) InternalCache() fft3dfilter(sigma=3, plane=1) InternalCache() fft3dfilter(sigma=3, plane=2) InternalCache() fft3dfilter(sigma=2, plane=0) InternalCache() b=SelectEvery(3,1) [EDIT] sorry you're right. The InternalCache reduces the number of extra calls to fft3dfilter(plane=2) and fft3dfilter(plane=1) to 4. But the YtoUV is still inefficient with the copying from one plane to another. I will implement it better in fft3dgpu so they write to a common frame.
Get my avisynth filters @ http://www.avisynth.org/tsp/ Last edited by tsp; 14th December 2005 at 18:19. |
