Old 16th November 2019, 21:14   #981  |  Link
Arrasa_340
Arrasa_340's Avatar
Originally Posted by malimuc View Post
I donated. Now i am waiting for answer.
Unfortunately I made a donation at the end of September 2019, and as of today I still receive nothing,
I advance it so that you don't make donations if what you expect is an update.
Regards
Arrasa_340 is offline   Reply With Quote
Old 18th November 2019, 18:08   #982  |  Link
Ghitulescu
Ghitulescu's Avatar
Donations are for the work done.
For future promises in relationship with donations, maybe you should try the church.
Born in the USB (not USA)
Old 19th November 2019, 17:27   #983  |  Link
outgoing
Regards
You must choose on the subject that you buy the license. That means paying 10 or its equivalent in $.
outgoing is offline   Reply With Quote
Old 3rd February 2020, 00:42   #984  |  Link
jerrycan
Hi. Just FYI, I did receive 0.44 recently. I had to send a follow-up email but I got a quick reply with a link. (Before anybody asks, no, I'm not sharing it.) The program still has some rough edges but it's usable once you get the hang of it. I was able to fix a couple of improperly authored Blus. They work great now. I also opened up a few UHDs (SDR, HDR10, HDR10+, and DV). Everything looked fine to me at a glance. I highly recommend making the donation if this is a program you think you'll find useful. Just be prepared for a somewhat difficult learning curve.
jerrycan is offline   Reply With Quote
Old 13th February 2020, 17:42   #985  |  Link
Gabriel88
I also received BdEdit0.46 today.
I made a donation.
I sent a follow-up email and I received a link.
The program is good.
Thank you
Gabriel88 is offline   Reply With Quote
bd menu, bdedit, blu-ray
