7th January 2005, 22:40 | #101 | Link |
Life's clearer in 4K UHD
8th January 2005, 00:37 | #103 | Link |
Derek Prestegard IRL
If you have Recode installed you have Ahead's AVC/AAC decoders installed and you should be able to play that MP4 on any decent player like Core, or Media Player Classic
These are all my personal statements, not those of my employer :) |
8th January 2005, 00:40 | #104 | Link |
sidekick
or install for example ffdshow (05.01.05) and activate decoding h264 in it....
@SMD: nice vid @ such low bitrate !
greets, kurt. Pioneer PDP-427 XA | Popcorn Hour NMT C-200 | Sony STR-DB 840 QS | Canton Ergo 91 DC |
8th January 2005, 01:52 | #105 | Link | |
8th January 2005, 02:27 | #107 | Link | |
This effect is much less in the X264 encode, IMO. |
8th January 2005, 08:23 | #108 | Link |
stupid
Okay I made a comparison between 3, 2 and 1 b-frame
the other settings were: bitrate=1000, CABAC, deblocking filter -2:-2, Max refrence frames 5, , prediction method= 1 temporal, max key frame interval= 250, subpixel refinement precision=4=always b-frames For me, Max b-frames=3 brings best results (with celticdruids newest filters), sadly the clips are too big to up them somewhere. I´ll make shorter (=smaller ) ones next time My problem is, I don´t find a muxer to convert them into MP4 (fourcc is h264). The following don´t work: - 3ivx: as expectet - mp4creator60: I really thought he can do this - mp4box: I was sure this would work - MP4UI: as expectet Any new ideas? The second thing is the question, how to make the first pass faster. The second pass ist as fast as with Ateme. But the first pass with Ateme is much faster. Can´t we have something like "discard first pass" like in Xvid?
cu Joe ------------------------ freedom is just another word for nothing left to loose Last edited by JoeBG; 8th January 2005 at 09:06. |
8th January 2005, 10:10 | #110 | Link | ||
x264 developer
I don't know how compliant the result is, but I can play it in MPlayer. Quote:
I don't have a single option to do the adjustments for you, because the speed/quality tradeoffs are still changing, so any effort I spend now optimizing the decisions will become obsolete soon. |
8th January 2005, 11:17 | #111 | Link |
clueless n00b
unfortunately, I'm also getting a 2nd pass error. Interestingly enough, when I closed VDub, opened it and created my job manually (I had set up the 2nd pass job in the job list and wanted to run it this morning), things worked just fine. In absence of a vdub log entry I have no idea what went wrong when trying to start the 2nd pass for the first time.
8th January 2005, 11:38 | #112 | Link |
My second pass gave an error at ~ 60% (rate.c something error) with b-frames enabled.
With all advanced options switched off everything worked smoothly. I'm gonna try another 2-pass encoding tonight with the default options and see what happens. Very good quality so far.. |
8th January 2005, 13:52 | #113 | Link |
sorry for offtopic but i need advise.
Right now i´m encoding a DVD Harry Poter pr. Azkaban( 2h 9m) in recode2 Nero H.264 (too slow options: ref 6, b 3, Extra , MV 511, 2pass.... ) but i want to test sex264 in Vdub. will be there any problems (artefacts) if i´ll do it at the same time? can i put pause in recode2 encoding? Last edited by IgorC; 8th January 2005 at 13:56. |
8th January 2005, 14:12 | #114 | Link | |
stupid
Another question maybe is what brings best quality in the field motion search precision. I choosed sub-8x8 PFRAME search and 4x4INTRA search together and nothing else. Can I make it better? Which combination brings best results?
cu Joe ------------------------ freedom is just another word for nothing left to loose Last edited by JoeBG; 8th January 2005 at 14:19. |
8th January 2005, 20:28 | #116 | Link |
<The VFW Sheep of Death>
ALL of them? You gotta be kidding... :-)
Wow, I typically don't use B-frames... With no deblocking and slower encode time, what use are they? The only things that really help are yer reference frames. I typically stick in 15. Compared to 1, 2, or even 3, this thing packs one heck of a punch in the lamb chops, baa Cheers, baa
Recommended all-in-one stop for x264/GCC needs on Windows: Komisar x264 builds! |
8th January 2005, 22:03 | #117 | Link |
hmm well after watching more thoroughly my 95mb family guy x264 episodes I noticed a strange problem with multiple consecutive b-frames.
Occasionally some of the b-frames will recieve absurdly high quantization, blocking very heavily (see my samples), while some of their neighboring b-frames recieve normal quantization, and look nice. I'm not short on bitrate... considering 95-99% of the frames look incredible. I'm not complaining, rather inquiring if ppl are aware of this rate control bug. Samples: clean frame b0rked b-frame (previous frame's neighbor)
8th January 2005, 22:54 | #118 | Link | |
ffdshow/AviSynth wrangler
Not that I'm well-versed in codec development, mind you... np: Pan Sonic - Käytävä / Corridoor (Kesto (234.48:4) (Disc 3)) |
9th January 2005, 00:38 | #119 | Link |
x264 developer
Yes, that's drastically overquantized.
H.264@qp=37 is ~equivalent to mpeg4@qp=18, while H.264@qp=46 would be equivalent to mpeg4@qp=50 if the scale went that high. Any frames that look good at qp=37 are just because they happen to motion compensate very well based on a P-frame at lower quantizer. (unless ffdshow displays some wacky quantizer scale?) That said, it is a bug and I will try to find it. |
9th January 2005, 01:28 | #120 | Link |
I am suspicious of ffdshow's OSD... Its "input bitrate" is never correct with h264, so perhaps the quantizer scale is incorrect as well.
I am re-encoding with 1 bvop and will let you know if these frames are better. [edit] encode finished. Problems persist with b-frames. I am using ffdshow to decode, a very recent version from celtric_druid, his jan 5 build. Could this be a decoder issue and if so how can I try another one? [/edit] ~misfit
These are all my personal statements, not those of my employer :) Last edited by Blue_MiSfit; 9th January 2005 at 01:35. |
