3rd January 2012, 08:23 | #14501 | Link |
QuickSync Decoder author
Strangely, code compiled on my home system didn't compile in other systems. A function refused to inline causing a warning that turned into an error.
Fixed at 4222. No ffdshow code change.
Eric Gur, Processor Application Engineer for Overclocking and CPU technologies Intel QuickSync Decoder author Intel Corp. |
3rd January 2012, 08:29 | #14503 | Link |
Yes, look here:
http://forum.doom9.org/showthread.php?t=163110 I also ran the 10 clips on my own PC (i7-2600) with a newer version of ffdhsow-quicksync: http://forum.doom9.org/showthread.ph...92#post1548192
4th January 2012, 11:46 | #14506 | Link | |
AMD CPU (without SSE2): QuickSync DLL: not found (ffdshow -> About page -> Version details) Intel CPU (without Intel GPU): QuickSync DLL: Version properly shown (ffdshow -> About page -> Version details) Why is the DLL not "found" on AMD system? I know it doesn't work on AMD but the DLL itself should be listed under About page -> Version details! Last edited by Dstruct; 4th January 2012 at 11:48. |
4th January 2012, 22:12 | #14508 | Link | |
5th January 2012, 22:03 | #14511 | Link |
My system is this:
http://www.asrock.com/nettop/overvie...Specifications and I'm having big problems to use my new AVR Sony STR-DN1020: http://www.sony.co.uk/product/hcs-ho...technicalspecs
In particular see this MediaInfo report file: Code:
General ID : 0 (0x0) Complete name : D:\Torrenti\Fantasia.1940.BD.RU\BDMV\STREAM\00125.m2ts Format : BDAV Format/Info : Blu-ray Video File size : 35.1 GiB Duration : 2h 4mn Overall bit rate mode : Variable Overall bit rate : 40.3 Mbps Maximum Overall bit rate : 48.0 Mbps Video ID : 4113 (0x1011) Menu ID : 1 (0x1) Format : AVC Format/Info : Advanced Video Codec Format profile : High@L4.1 Format settings, CABAC : Yes Format settings, ReFrames : 4 frames Format settings, GOP : M=3, N=12 Codec ID : 27 Duration : 2h 4mn Bit rate mode : Variable Bit rate : 27.2 Mbps Maximum bit rate : 27.5 Mbps Width : 1 920 pixels Height : 1 080 pixels Display aspect ratio : 16:9 Frame rate : 23.976 fps Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Scan type : Progressive Bits/(Pixel*Frame) : 0.546 Stream size : 23.6 GiB (67%) Color primaries : BT.709-5, BT.1361, IEC 61966-2-4, SMPTE RP177 Transfer characteristics : BT.709-5, BT.1361 Matrix coefficients : BT.709-5, BT.1361, IEC 61966-2-4 709, SMPTE RP177 Audio #1 ID : 4352 (0x1100) Menu ID : 1 (0x1) Format : DTS Format/Info : Digital Theater Systems Format profile : MA / Core Muxing mode : Stream extension Codec ID : 134 Duration : 2h 4mn Bit rate mode : Variable Bit rate : 4 759 Kbps / 1 510 Kbps Channel(s) : 8 channels / 6 channels Channel positions : Front: L C R, Side: L R, Back: L R, LFE / Front: L C R, Side: L R, LFE Sampling rate : 48.0 KHz Bit depth : 24 bits Compression mode : Lossless / Lossy Audio #2 ID : 4353 (0x1101) Menu ID : 1 (0x1) Format : DTS Format/Info : Digital Theater Systems Format profile : MA / Core Muxing mode : Stream extension Codec ID : 134 Duration : 2h 4mn Bit rate mode : Variable Bit rate : 2 722 Kbps / 1 510 Kbps Channel(s) : 8 channels / 6 channels Channel positions : Front: L C R, Side: L R, Back: L R, LFE / Front: L C R, Side: L R, LFE Sampling rate : 48.0 KHz Bit depth : 24 bits Compression mode : Lossless / Lossy Audio #3 ID : 4354 (0x1102) Menu ID : 1 (0x1) Format : DTS Format/Info : Digital Theater Systems Codec ID : 130 Duration : 2h 4mn Bit rate mode : Constant Bit rate : 1 510 Kbps Channel(s) : 6 channels Channel positions : Front: L C R, Side: L R, LFE Sampling rate : 48.0 KHz Bit depth : 24 bits Compression mode : Lossy Stream size : 1.31 GiB (4%) There are 6 more AUDIO tracks Text #1 ID : 4609 (0x1201) Menu ID : 1 (0x1) Format : PGS Codec ID : 144 Duration : 2h 4mn Delay relative to video : 7s 674ms Text #2 ID : 4610 (0x1202) Menu ID : 1 (0x1) Format : PGS Codec ID : 144 Text #3 ID : 4615 (0x1207) Menu ID : 1 (0x1) Format : PGS Codec ID : 144 There are 14 more AUDIO tracks :scared: |
7th January 2012, 03:18 | #14512 | Link |
Is there any way for ffdshow to honor the full range flag in H.264 videos if it's specifically set? I encoded a few videos and specifically set the full range flag but regardless of whether I choose Auto or Standard for the output range, it's still outputting limited range. I'm hoping there's an alternative to selecting Full Range each time those videos are played.
The more I think about it, the more certain I am that the tooltip for Auto is unclear whether the H.264 full range flag is honored or not. |
7th January 2012, 13:38 | #14513 | Link | |
7th January 2012, 15:14 | #14514 | Link |
I have a FFDshow feature request
Can ffdshow render subtitles to a secondary pin ? Like this If it acted as a pass through filter for the video we could support DXVA this way, which is a big plus. The secondary pin can just output RGBA no need to worry about all the hundreds of different colour spaces. Can be more efficient too since only need to update the subtitle image when the text needs to change, rather than composite it every frame. |
8th January 2012, 00:46 | #14515 | Link | |
8th January 2012, 01:38 | #14516 | Link |
I can't see it being a huge amount of work, although I've not really studied the FFDShow source.
I might be able to assist. I am actually a c++ programmer. Specialise in opengl, but I know directshow. Written an opengl renderer in dshow ;p Im guessing you would need a new pin type for pass through, since it would be reading the sample type, for video size but not altering it. |
8th January 2012, 03:02 | #14517 | Link | |
Subtitles rendering is not pass through nor just alpha blending bitmaps. The input pin accepts text or coded bitmap and rasterize/decode them. And finally blend to the video. The output stage may be issued to a video renderer. It is not easy. None the less, you can do it . I hope you have patience huge enough to deal with the messy existing code. |
8th January 2012, 06:42 | #14518 | Link | |
