21st January 2006, 18:55 | #241 | Link | |
Ok, so the layout is as follows...
Source: C:\MULAN\VIDEO_TS VB backup folder located in C:\MULAN\VobBlanker_backup Log output: Quote:
Edit: After moving VobBlanker_backup into VIDEO_TS PGCedit prompts with the mkisofs Invalid node - -m error, and prompted if it should delete the backups and continue (YES), continue w/o deleting the backups (NO), or cancel. There's a typo in the dialogue BTW, "mkisofs returnde the...". So I guess the solution is to configure VB to store the backup folder inside VIDEO_TS. Last edited by Drinken; 21st January 2006 at 19:01. |
21st January 2006, 19:07 | #242 | Link |
PgcEdit daemon
Well, I have just modified (again) the way the burn function sends the mkisofs command. I hope now that this irritating - -m bug will be fixed. With some luck, the location of the backup will not matter any more.
A new beta will be available in a couple of days...
28th January 2006, 10:10 | #244 | Link |
Bug in <Remap Titlesets> command
First of all I would like to say thank you r0lZ for this unbelievable tool It's more than a knife it's an axe. I can literally butcher a DVD with it Carve it anyway I like it
And to the point. It's seems to be a bug in <Remap Titlesets> command in PgcEdit 0.6.2. The setup: VMGM: has a button referencing VTS2 menu with the command Jump to VTSM 2, Root menu (TTN 1) VTS 2: here is the main feature and a menu so as you can see this DVD's (R2 Taxi Driver btw) menu spans across VMG and VTS2. I want to make VTS2 into VTS1 so the main feature is in the first TitleSet and I'll be able to delete the rest of the TitleSets which are all kinds of extra material. I use PgcEdit's <Remap Titlesets> command. It does the file renaming alright but command Jump to VTSM 2, Root menu (TTN 1) in VMG does NOT change to Jump to VTSM 1, Root menu (TTN 1) as it should. I changed it manually but thought you would like to know Plus it gave me the opportunity to say my thanks for PgcEdit |
28th January 2006, 11:55 | #245 | Link |
PgcEdit daemon
Thanks, Denis!
There was indeed a big bug in the remap titlesets function: the JumpSS commands in the menu buttons of the VMGM were modified, but not saved! Since the DVD is reloaded automatically after the remap titleset operation, the modified commands were overwritten by the original ones. It's fixed now. Thanks again! V0.6.3 will be released very soon. Probably today.
r0lZ PgcEdit homepage (hosted by VideoHelp) BD3D2MK3D A tool to convert 3D blu-rays to SBS, T&B or FS MKV Last edited by r0lZ; 28th January 2006 at 11:57. |
28th January 2006, 16:47 | #246 | Link |
PgcEdit daemon
PgcEdit v0.6.3 released!
PgcEdit v0.6.3 release history:
DVDShrink plugin v1.4 released!
28th January 2006, 21:26 | #249 | Link |
r0lZ,
Thanks for the release! The menu killing feature is awesome! That's 4 or 5 guides that just became obsolete! Really cool! I'm impressed! jeanl
A few PgcEdit guides. DVDSubEdit a free tool to edit subtitles directly inside the vob. |
28th January 2006, 21:34 | #250 | Link |
PgcEdit daemon
But I have to release a new version! Tobi is right. There is a bug in the Burn DL DVD GUI.
28th January 2006, 22:42 | #252 | Link |
PgcEdit daemon
I will chanhge the version number. Perhaps 0.6.3.1.
You can burn a DL safely. The bug is only in the GUI. If you click the Cancel button in the LB selection dialog, the dialog is closed, but the main burn window has the OK and Cancel buttons disabled. It is not possible to close the burn GUI, and you have to kill PgcEdit. But if you continue the burn normally, it should work. I haven't changed the way the IFOs are patched and saved, nor the mkisofs and ImgBurn parameters (though the way mkisofs is called is now different, and the bug when passing the LB value for a DL-R to ImgBurn is fixed.)
29th January 2006, 00:16 | #254 | Link |
PgcEdit daemon
The verification of the number of streams at startup was requested by several users. It's not mandatory, and you can switch this option off via the options menu.
29th January 2006, 02:30 | #256 | Link |
Just a Member
Thanks once more... Incredible application.
I don't agree with the "0" starting in the release numbering. Seems it is a beta, unstable, and this is confussing... I really think you should change to 1.anything (or better 6.3 if you want) jsoto
Web sites with my tools http://download.videohelp.com/jsoto http://jsoto.posunplugged.com/ |
29th January 2006, 08:03 | #257 | Link | |
I'll rephrase my question: Why is there something to fix after blanking out all VTST titles? Isn't the number of streams adjusted as well when using this function? |
29th January 2006, 10:12 | #258 | Link |
Country Member
@DiggnSaeg
What happens is that the stream needs to stay in place as it may need to be selected. jsoto first brought this to our attention - see here. So after blanking, the domaion attributes are "out" and need to be re-instated. BTW: Thanks r0lZ for another Herculean effort! Regards
Les Only use genuine Verbatim or Taiyo Yuden media. Last edited by blutach; 29th January 2006 at 10:19. |
29th January 2006, 10:19 | #259 | Link | |
Country Member
Regards
Les Only use genuine Verbatim or Taiyo Yuden media. |
29th January 2006, 10:34 | #260 | Link |
PgcEdit daemon
OK, I understand the message.
But, really, I can't jump from 0.6.3 to 6.3 or even 1.0 just for a small bug fix! And I suppose there are still some bugs in the current version. So, I prefer, for now, to consider it still as a somewhat unstable version. But it's OK. The next major release will be 1.0. Thanks for your support, guys!
