Old 22nd March 2010, 07:44   #1  |  Link
M_Knox
Custom user
M_Knox's Avatar
[PgcEdit plugin] Context Help plugin 1.0 (2010.03.22)
Context Help plugin allows you to receive help based on what you're currently doing in PgcEdit. For example, when a dialog window pops up, just press F1 and, in most cases, you'll be redirected to the appropriate help page describing the dialog options.
Installation of the plugin is plain simple. Copy the archive contents keeping the folder structure to the "plugins" subfolder of PgcEdit folder (the one, that contains PgcEdit.exe file). If there is no "plugins" subfolder there, just create it manually or run PgcEdit.exe - the subfolder will be created. After you copy files to the plugins folder, restart PgcEdit.
If you're getting "Page not found" errors when using PgcEdit_Manual.chm, please ensure that you have the latest version of it, which can be obtained here: http://www.digital-digest.com/~bluta...dit_Manual.zip
More information can be found in "info.txt" in the plugin package.
If there are PgcEdit plugin developers out there, they can benefit from the Context Help plugin easily - more information can be found in "Info_for_PgcEdit_plugin_developers.txt" in the plugin package.
The plugin was written for PgcEdit 9.3 (coming really soon! ), but it should work with previous versions. However, as help is based on some PgcEdit internals (think of the window names as unique IDs), and those were changed in 9.3 to avoid ambiguity, you may not always get what you want.
I hope you'll find this plugin useful.
Additional URL for the plugin package: http://members.elysium.pl/morris/pro...plugin_1.0.rar
M.O.R.R.I.S.: Mechanical Obedient Replicant Responsible for Infiltration and Sabotage
morris#rarlab*com
M_Knox is offline   Reply With Quote
Old 22nd March 2010, 08:50   #2  |  Link
r0lZ
PgcEdit daemon
r0lZ's Avatar
Huge thanks, M_Knox! This plugin is really a great addition to PgcEdit.
Many thanks also to blutach and Wombler. They have written and illustrated the manual, and added the HTML anchors where necessary for the help plugin.
I'm glad to have such a great team among the PgcEdit beta testers!
r0lZ
Old 22nd March 2010, 10:33   #3  |  Link
blutach
Country Member
blutach's Avatar
Huge thanks M_Knox. I hope all PgcEdit users find this as useful as I do.
@r0lZ - thanks for the kind words.
Regards
Les
Only use genuine Verbatim or Taiyo Yuden media.
blutach is offline   Reply With Quote
context help, docs, pgcedit, plugin
