8th March 2012, 09:49 | #701 | Link |
Today just encoding with your tool with updated x264 (rev 2183) but I get API problem. I don't know if the problem related with your tool or avs2yuv itself :
Creating process: "C:/Program Files (x86)/MuldeR/Simple x264 Launcher v2/toolset/avs2yuv.exe" Avs2YUV 0.24bm2 x264 revision: 2183 (core #122) Avs2YUV version: 0.24.2 WARNING: Your revision of x264 uses an unsupported core (API) version, take care! This application works best with x264 core (API) version 120. Code:
Warning: Avisynth did not respond for 60 seconds, potential deadlock... |
8th March 2012, 09:54 | #702 | Link | |
Indeed, my suggestion for 10-bit x264 support was motivated by the fact that replacing 8-bit with 10-bit and vice versa seems like unnecessary complicated step one has to do with many of the other GUIs, too. Well, I guess, not anymore @LoRd_MuldeR: You are probably aware that LAV filters, CoreAVC and the new ffdshow builds can decode 10-bit H.264. Hence installing one of them on HTPC technically gives you hardware support for 10-bit H.264 (though not natively, of course) And thanks for your replies to my other points. I am looking forward to what you are going to code for the "fast-bulk-encoding" (so to replace writing batch scripts..) and the keyboard shortcuts. |
8th March 2012, 10:30 | #703 | Link | |||
Software Developer
Now the latest x264 has increased the "core" version to 122 which potentially breaks compatibility - thus the warning message. Still it's just a warning and you can probably ignore that. I will increase the expected core version to 122 soon... Quote:
That often happens with FFVideoSource(), if the index file still has to be created. You may use "ffmsindex.exe" to avoid that situation. If Avisynth takes too long to open (more than 5 minutes), then Simple x264 Launcher will eventually kill the job... Quote:
The problem is, when you give people a "10-Bit" option, they will start using it, because "more is better". Most people don't have the technical background to understand what it means. And indeed, if you test it on your PC or HTPC, then it will play just fine, e.g. with a lavc-based decoder. But as soon as you try on your hardware (standalone) player, the file will fail! Of course most users will then blame the GUI program for having created a "broken" file
Go to https://standforukraine.com/ to find legitimate Ukrainian Charities 🇺🇦✊ Last edited by LoRd_MuldeR; 8th March 2012 at 10:38. |
8th March 2012, 12:28 | #704 | Link |
Yeah, I know, I was merely joking about the hardware part. But one cannot deny that 10-bit x264 has been gathering the hype for some time now, for whatever that is worth. Personally, I have not been able to justify the performance penalty in the case of fullhd encoding. Maybe there is some hidden setting that unlocks the power of 10-bit x264 (That is to say that 8-bit x264 is already impressively good.) \\OT
EDIT: My observations on the 10-bit x264 are limited only to 1080 movies only. I have little experience with animation or lower resolutions. Last edited by Marin85; 8th March 2012 at 16:25. |
9th March 2012, 00:56 | #706 | Link |
@LoRd_MuldeR:
Little question: I've a lot tv show from DVD source and I wish to convert into H264 (mkv) using x264 cli command only without avisynth. Using simplex264gui, I've not problem with crop or resize command, but I've not found a good method for deinterlace my source to 576P. Do exist command for this ? I've read full help command, but I've not found anything useful. |
9th March 2012, 01:19 | #707 | Link |
Software Developer
Apparently there is no deinterlace filter among the built-in video filters of x264. Use one of the various Avisynth deinterlacers, such as QTGMC.
I think there are some patched x264 builds with built-in "Yadif" filter. But Yadif isn't a great deinterlacer anyway - it's okay for the speed it delivers, but something like QTGMC is much better. Another option would be using FFmpeg or MEncoder instead of the x264 CLI encoder. These should provide various deinterlacing options without using Avisynth.
Go to https://standforukraine.com/ to find legitimate Ukrainian Charities 🇺🇦✊ Last edited by LoRd_MuldeR; 9th March 2012 at 01:55. |
9th March 2012, 08:20 | #708 | Link |
I hope I am not overflowing your topic too much, but the whole talking about replacing x264 builds got me an idea about a little but useful thing, namely to include a shortcut to the program folder of Simple x264 Launcher somewhere in the menus, similarly to what AvsPmod has for the Avisynth plugins. I believe it will be useful to those who want to always stay on the cutting edge with x264 builds or would like to use their own (possibly patched) builds.
9th March 2012, 19:03 | #710 | Link | |
Software Developer
9th March 2012, 19:17 | #712 | Link |
Any chance of getting the estimated time of completion added to the status of avs2yuv as well as the current/total frames? I liked having that info when running x264 directly. Thanks for considering it.
Chumbo |
9th March 2012, 20:28 | #713 | Link | |
Software Developer
If, however, you feed x264 with data from the STDIN (like when you use avs2yuv), it cannot know the number of total frames! Therefore you have to use the "--frames" switch and this way tell x264 the total number of frames. Then it will display progress, as usual. (That's exactly what the Simple x264 Launcher does to get x264 print status messages)
Go to https://standforukraine.com/ to find legitimate Ukrainian Charities 🇺🇦✊ Last edited by LoRd_MuldeR; 9th March 2012 at 20:33. |
10th March 2012, 02:55 | #714 | Link | |
Chumbo |
10th March 2012, 23:25 | #715 | Link | |
13th March 2012, 20:39 | #716 | Link |
Just some idea. What do you think about adding option to delay starting of queued jobs? Like 10, 20 minutes.. Because some folk may not have proper cooling down system when encoding like laptop. So the delay option may help to cool down the laptop when there are ton of awaiting queued jobs in the gui
*I just speak out idea which come out from my mind. Ignore it if you think unnecessary |
13th March 2012, 20:54 | #717 | Link | |
Software Developer
Putting a pause of 20 minutes between two consecutive encodes doesn't help at all here! If the computer was running stable for hours to finish the previous encode, then it will continue to do so with the next encode - no break between the encodes is required. And if the computer does NOT run stable, it will probably power-off itself (or just crash/freeze) during the encode, i.e. long before it reaches the pause. In any case, inserting a pause would only be an ugly workaround for the symptoms of inadequate cooling. Rather than applying such workarounds and risking hardware damage in the long term, you should fix the cause of the problem, i.e. get an adequate cooling for your CPU... (All above comments apply for computers which are running the CPU at "standard" clock frequency, of course. If your CPU became unstable as a result of "overclocking" attempts, revert to the defaults ASAP!)
Go to https://standforukraine.com/ to find legitimate Ukrainian Charities 🇺🇦✊ Last edited by LoRd_MuldeR; 13th March 2012 at 21:16. |
14th March 2012, 01:20 | #718 | Link |
@LoRd_MuldeR,
I had a real strange issue come up today. I noticed that one of my files did not encode. After some digging I found, eventually, that avs2yuv was crashing on pass 2 for some reason. I hope you may be able to shed some light on this. So pass 1 encodes just fine (I'm feeding the avs file via avs2yuv into x264 64bit) and creates the stats files. But when I get to pass 2 avs2yuv reports the following after I ran it manually to see what's going on: Code:
avs2yuv "file_p1.avs" - file_p1.avs: 1920x1080, 60000/2002 fps, 12396 frames YUV4MPEG2 W1920 H1080 F60000:2002 Ip A0:0 C420mpeg2 error: wrote only 3085668 of 3110400 bytes
Chumbo |
14th March 2012, 01:36 | #719 | Link |
Software Developer
Doesn't make much sense that avs2yuv crashes with the same AVS script in the second pass, while the first one runs trough fine.
That's because avs2yuv doesn't know anything about passes. It just requests the raw video data from Avisynth and passes it to the STDOUT, where x264 will grab the data. Consequently pass 1 or 2 doesn't make any difference for avs2yuv. It has absolutely no idea who or what is reading the data (and what for) that it writes to the STDOUT But the error "wrote only X of Y bytes" indicates that x264 (or whatever process the pipe was connected to) terminated before avs2yuv could write all data. (So probably x264 just crashed/failed for some reason! Didn't x264 output any error/warning message ???) To make sure that avs2yuv (or Avisynth) isn't failing, you may try this: Code:
for %%i in (1 2 3 4) do ( avs2yuv "file_p1.avs" - > NULL )
Go to https://standforukraine.com/ to find legitimate Ukrainian Charities 🇺🇦✊ Last edited by LoRd_MuldeR; 14th March 2012 at 02:13. |
14th March 2012, 02:16 | #720 | Link | |
Just FYI, x264 did report the following, but initially I thought it may have been due to the "error" I posted from avs2yuv: Code:
y4m [info]: 1920x1080p 1:1 @ 30000/1001 fps (cfr) x264 [info]: using SAR=1/1 x264 [info]: using cpu capabilities: MMX2 SSE2Fast SSSE3 FastShuffle SSE4.2 Process terminated with code: 4294967295
Chumbo |
