15th November 2016, 20:52 | #25242 | Link | |
BD-RB does have the ability to convert it during output to ALTERNATE formats (see the selection in the SETUP dialog) -- but the OCR is unsupervised, so there is usually some required editing after the conversion. There are a few good independent methods for PGS -> SRT conversion. Subtitle Edit is a pretty good one. You can use TSMUXER to extract the PGS (to a .SUP file), and then use Subtitle Edit to perform a supervised OCR conversion. |
16th November 2016, 02:54 | #25246 | Link | |
Not as fast as DgdecNV, but reliable and quick. |
16th November 2016, 13:54 | #25247 | Link | |
Yesterday I purchased a license for DgdecNV and tried it with BD-RB. (Nvidia card GeForce GTX 750, Intel Core i7 4770). Pointed BD-RB to the location of DgdecNV exe file and ran the job. There was no difference in encoding speed at all. Could someone suggest what I should pay attention to or be aware of when using BD-RB with DgdecNV? Do I need to have installed LAV Directshow Filters or FFDShow or Haali as well? |
16th November 2016, 15:29 | #25248 | Link | |
16th November 2016, 19:00 | #25249 | Link |
When "Scanning source directory" is triggered, for example by changing Settings/Output options or selecting "Quicker Encode for Extras", all Blanked item selections are lost. Not sure if this is intended behaviour, doesn't seem like these selections interfere with these options.
Win 10 Pro x64 |
18th November 2016, 04:58 | #25251 | Link | |
18th November 2016, 17:00 | #25252 | Link |
Need some help troubleshooting an issue..
After extracting... I get a pop-up error from windows saying.. BD Rebuilder experienced an error [time] CreateAVS() 00000 Code:
[11/16/16] BD Rebuilder v0.50.19 [10:34:16] Source: INDEPENDENCE_DAY_RESURGENCE_00801 - Input BD size: 31.58 GB - Approximate total content: [01:59:44.176] - Windows Version: 6.1 [7601] - MOVIE-ONLY/ALTERNATE OUTPUT mode enabled - Mode: MKV Container, 1920x1080, Intact Audio - Quality: Better (Faster) - Decoding/Frame serving: DGDecNV - Audio Settings: AC3=0 DTS=0 HD=1 Kbs=640 [10:34:19] PHASE ONE, Encoding - [10:34:19] Processing: VID_00600 (1 of 3) - [10:34:19] Extracting A/V streams [VID_00600] - [10:39:38] CreateAVS() 00000 [10:49:46] - Could not create AVS file I know i had issues that were self inflicted before.. but they seem to be resolved. And I have this error with this disc, and only this disc. Other movies (like Ice Age Collision course, etc) are fine. ANd I've tried freshly unpacking BD-Rebuilder again. This error happens on each of my 3 OS partitions (each with BD-Rebuilder installed). Should I post any log, or ini file? |
18th November 2016, 17:50 | #25253 | Link | |
18th November 2016, 19:02 | #25255 | Link |
I just tested that call and got the time also. I have no idea how the time gets embedded in the error code...
[Edit] Ok, I see it now. The location of the error isn't provided, so the 0000 is actually the error number and the location is "blank". The problem is: That call should never be executed with an error of 0 (meaning no-error). Last edited by jdobbs; 18th November 2016 at 19:12. |
19th November 2016, 04:15 | #25257 | Link |
YES.... and seeing your question.. I just unchecked it... its now "Reencoding: VID_00600, Pass 1 of 1" i.e. it got past the error and seems to be working... It will be a little before it fully finishes (assuming it continues without error).
Could this be something with the way subtitles are done in this movie? Has anyone done INDEPENDENCE_DAY_RESURGENCE yet? |
19th November 2016, 12:46 | #25258 | Link | |
I've done that movie, but I check for forced subs first and probably didn't use SupTitle on it Last edited by gonca; 19th November 2016 at 12:47. Reason: More info |
19th November 2016, 15:53 | #25259 | Link |
What I don't get is how it would cause an error in CreateAVS()? All that does is create the AVS file... it doesn't attempt the conversion.
@Mark_Venture What language to you have selected as the default for subtitles? Are you using the default of English. I'll see if I can pick up that movie and give it a test. |
