10th January 2018, 16:34 | #401 | Link | |
Everything else was exactly the same as your test setup , RGB48 . I tested 1280x720 (maybe you have some weird dimensions causing crash?) I just dragged the vpy to vdfm , and it automatically chose AVI, with "internal DIB decoder (b64a)" as reported in file=>file information The CPU I tested on has avx2 . Win8 Was that on XP ? Some ffmpeg changes made XP support more difficult, maybe it has something to do with that ? |
11th January 2018, 03:12 | #402 | Link | ||
Evidently, with these 16-255 range clips something is going on YUV420-709 > YUV420 or YUYV (YUY2) 'conversion' that is preventing transfer of the full data range. Come to that, why does YUV420-709 need to be 'converted' to YUV420 anyway if the decompression format 'interpretation' is set for 'no change' in the component range ? Surely it's just pass-through ? Anyhow, hopefully Shekh will get to the bottom of it.
Nostalgia's not what it used to be Last edited by WorBry; 11th January 2018 at 05:31. |
11th January 2018, 08:29 | #403 | Link | |
Opening vpy issue: maybe you used driver override feature in error, try to see Open dialog, select vpy file, and then change preferred driver to default one (in dropdown there should be AVIfile, then caching..) avx in cineform: no I don't think there is such code. And I run some tests on core2.
VirtualDub2 |
12th January 2018, 14:12 | #405 | Link | |
The conversion 709->601 with out-of-range luma values requires clipping which is not applied. I will replace the procedure.
VirtualDub2 |
12th January 2018, 15:44 | #406 | Link |
I'm not converting 709 > 601 though. Both the Color Space and Component Range interpretations are set as 'No Change' (the default).
Nostalgia's not what it used to be |
12th January 2018, 16:05 | #407 | Link | |
Actually "no change" in compression pixel format means nothing. Currently more informative is the line "Using conversion: YUV420-709 -> YUV420" To really have no colorspace change, either select "pixel format-> same as decoding" or set colorspace explicitly the same as source (709). |
12th January 2018, 18:01 | #408 | Link |
I did some more testing, and the crash for me was from using video=>fast recompress
(You used to be able to bypass all the other extraneous conversions by using it in classic vdub) I agree that current part of the UI with color space / component range is confusing |
12th January 2018, 19:10 | #409 | Link | |
- crash report: when you see "Oops - VirtualDub has crashed..." press "Save" button - also VirtualDub_AutoSave_xxx.vdproject file (created automatically before crash) - source video. Please save Vapoursynth output as uncompressed avi (1 frame should be enough) Repeated, will be fixed. |
12th January 2018, 20:44 | #410 | Link |
OK, I've got it sorted. What confuses matters is the "(?) Format Not Accepted by Codec, YMMV" comment when transcoding to the 'non-native' vfw codec formats, like MagicYUV and the GoPro Cineform codec. I'll post some shots of the config panels to illustrate what I mean, when I have a moment. But yes, when transcoding these 8-bit YUV420-709 sources to Cineform, setting the YUY2 output colorspace explicitly to 'Rec709' resolves the issue with the black-coded specular highlights - the GoPro vfw Cineform codec complains that "(?) Format Not Accepted by Codec, YMMV" but it still works. I guess that's the reason for the 'YMMV' ;>)
Nostalgia's not what it used to be Last edited by WorBry; 12th January 2018 at 20:53. |
12th January 2018, 21:45 | #411 | Link | |
12th January 2018, 22:01 | #412 | Link |
I was editing my last post just as you replied. I was going to add that when using the native Cineform encoder, setting the YUY2 output explicitly for Rec709 is accurately reflected in the comment 'Using conversion YUV420-709 ->YUYV-709'.
On the other hand, transcoding (these YUV420-709 inputs) to MagicYUV-YUV420 (configured for Rec709 YUV420 input) does not require specifying 'Rec709' in the output pixel format. Leaving at default 'Same as Decoding' (YUV420-709) works fine (pass-through with no black-coded highlights) provided you ignore the "(?) Format Not Accepted by Codec, YMMV" comment. Same with UTVideo YUV420. Well that's 'my mileage' at least I won't bother posting any screen shots. Cheers.
Nostalgia's not what it used to be Last edited by WorBry; 12th January 2018 at 22:21. |
13th January 2018, 18:19 | #413 | Link | |
New version with many fixes.
Also same way to enable alpha when it is not detected (e.g. from AviSynth)
VirtualDub2 |
23rd January 2018, 04:23 | #417 | Link |
Hi Shekh,
Build 40898, and my prev 40879, Problem when switch to Free Adjust, image still scrolls around in box (via mouse), you have to screw around with sizing it to get it to show full image. Ta very much
23rd January 2018, 11:16 | #419 | Link |
Definitely somewhat bigger (I would not bother too much about 1 pixel, maybe 10, 16 something like that, perhaps bigger).
AVI. EDIT: No, I mean AVS. Starts out ok, but resize via mouse, then switch to Free Adjust, significant scrolling, even when view area is only a quarter occupied. Can be way more than 16 pixels.
I sometimes post sober. StainlessS@MediaFire ::: AND/OR ::: StainlessS@SendSpace "Some infinities are bigger than other infinities", but how many of them are infinitely bigger ??? Last edited by StainlessS; 23rd January 2018 at 11:20. |
23rd January 2018, 11:20 | #420 | Link | |
Edit: ok Last edited by shekh; 23rd January 2018 at 11:33. |
