Old 12th July 2016, 03:55   #2081  |  Link
Chikuzen
typo lover
Chikuzen's Avatar
Originally Posted by MysteryX View Post
- How do I know a clip has UINT16 or FLOAT formats?
bool is_uint16 = (vi.pixel_type & VideoInfo::CS_Sample_Bits_16) != 0;
bool is_float = (vi.pixel_type & VideoInfo::CS_Sample_Bits_32) != 0;
- What about Dithering?
Currently, nothing.
my repositories
Chikuzen is offline
Old 12th July 2016, 11:26   #2082  |  Link
ultim
AVS+ Dev
ultim's Avatar
Or easier, but AvsPlus-specific:
bool is_uint16 = vi.ComponentSize() == 2;
bool is_float = vi.ComponentSize() == 4;
Btw, there is a another new function vi.NumComponents(), which is 1 for greyscale, 3 for yuv/rgb, 4 for rgba etc.
Unlike IScriptEnv2, these can be considered stable.
AviSynth+
ultim is offline
Old 12th July 2016, 12:10   #2083  |  Link
Groucho2004
@ultim, pinterf
Did you guys get a chance to look at this one? Not high priority I guess but still...
Groucho's Avisynth Stuff
Groucho2004 is offline
Old 12th July 2016, 12:45   #2084  |  Link
MysteryX
Soul Architect
MysteryX's Avatar
Is there a way to define macros that allow using the simpler new syntax while remaining compatible with AviSynth 2.6?
MysteryX is offline
Old 12th July 2016, 12:55   #2085  |  Link
Chikuzen
typo lover
Chikuzen's Avatar
@ultim, pinterf
from avisynth.cpp line 1686
  int size = pitchY * height + 2 * pitchUV * heightUV;
  size = size + align -1;
  VideoFrame *res = GetNewFrame(size);
1920*30*1080*30 + 2*960*30*540*30 = 2799360000
max of int32_t is 2^31 - 1= 2147483647
i don't know whether this is bug or spec.
my repositories
Chikuzen is offline
Old 12th July 2016, 13:12   #2086  |  Link
MysteryX
Soul Architect
MysteryX's Avatar
Why the *30?
There was discussion recently regarding x64 and whether the frame size should be INT(32-bit) like Ultim implemented or 64-bit. Changing that would require recompiling every x64 plugin.
MysteryX is offline
Old 12th July 2016, 13:40   #2087  |  Link
Chikuzen
typo lover
Chikuzen's Avatar
Why the *30?
see groucho's post.
from avisynth.cpp line 1228
VideoFrame* ScriptEnvironment::AllocateFrame(size_t vfb_size)
  if (vfb_size > (size_t)std::numeric_limits<int>::max())
    throw AvisynthError(this->Sprintf("Requested buffer size of %zu is too large", vfb_size));
so, it's a bug.
vfb_size should be calculated on size_t.
error messages should be correct.
my repositories
Chikuzen is offline
Old 12th July 2016, 14:39   #2088  |  Link
jpsdr
It would be nice if the avisynth header can be kept compatible with VS2010.
jpsdr is offline
Old 12th July 2016, 15:42   #2089  |  Link
ultim
AVS+ Dev
ultim's Avatar
ok. it might happen that we accidentially break vs2010 because none of the active developers use it so we don't test it. but if you let us know of problems with vs2010 we'll correct it, as long as it is only the public headers.
AviSynth+
ultim is offline
Old 12th July 2016, 16:36   #2090  |  Link
MysteryX
Soul Architect
MysteryX's Avatar
http://forum.doom9.org/showthread.ph...86#post1773786
MysteryX is offline
Old 12th July 2016, 18:24   #2091  |  Link
jpsdr
Basicaly, functions of C++11 are not supported (only VS2015 begin to allmost fully support it from what i've understood), so delete is not supported.
jpsdr is offline
Old 12th July 2016, 18:29   #2092  |  Link
qyot27
qyot27's Avatar
Lines 443 and 444 in turn.cpp cause compilation errors in VS2013. Is 'constexpr' an intended change, or was it a typo that slipped in there?
EDIT: Okay, apparently it is (why didn't I try looking that up before?). But since it fails, I'm thinking either VS2013 is missing the header to support it, or turn.cpp needs the right header added to its includes.
qyot27 is offline
Old 12th July 2016, 18:38   #2093  |  Link
jpsdr
VS2013 just begin to support a few features of C++11, and so it's probably VS2013 missing the header.
jpsdr is offline
Old 12th July 2016, 19:01   #2094  |  Link
ultim
AVS+ Dev
ultim's Avatar
Ah, ok. I will get rid of "delete" there. Will be in the next push.
constexpr is a core language feature and cannot be added via a header. As is currently, it will not compile on VC2013. Please ask chikuzen if he can do something about it, as he's the author of those lines, and I'm not really an intrinsics expert.
AviSynth+
ultim is offline
Old 12th July 2016, 21:48   #2095  |  Link
TheFluff
Excessively jovial fellow
templated intrinsics is the new cool thing to do if you want to write optimized code that supports multiple bitdepths without copypasting shit all over the place, get with the times and upgrade yer compilers
TheFluff is offline
Old 12th July 2016, 21:57   #2096  |  Link
TurboPascal7
TurboPascal7's Avatar
Does it even have to do anything with the intrinsics there? Looks completely unnecessary (like most of the C++ duhuhu).
Me on GitHub | AviSynth+ - the (dead) future of AviSynth
TurboPascal7 is offline
Old 13th July 2016, 00:43   #2097  |  Link
Chikuzen
typo lover
Chikuzen's Avatar
Please ask chikuzen if he can do something about it.
hmm, ok.
I'll send a PR.
btw, when does AVS+ keep supporting VS2013? 22nd century?
my repositories
Chikuzen is offline
Old 13th July 2016, 01:08   #2098  |  Link
feisty2
I'm Siri
feisty2's Avatar
Guess it's probably not a good idea to stay vs2010 or 2013, the latest c++ standard is c++14 so..
And vs2015 community is free anyways, what's the point of getting stuck at square one
feisty2 is offline
Old 13th July 2016, 04:46   #2099  |  Link
MysteryX
Soul Architect
MysteryX's Avatar
I have a question. Let's say I run a script at 8fps, then in the middle of it, I'm running something else. Obviously performance goes down to, say, 4fps. Once the other task is done and the script has all the resources again, however, it stays stuck at 4fps and doesn't go back to 8fps. Has anyone else noticed this? What's causing that?
MysteryX is offline
Old 13th July 2016, 06:21   #2100  |  Link
jackoneill
unsigned int
jackoneill's Avatar
You don't have to use all the cool new features just because you can.
Buy me a "coffee" and/or hire me to write code!
jackoneill is offline
