Old 18th June 2023, 12:55   #41  |  Link
Grimsdyke
The incredible flexibility and range of settings and the profiling system allow me to fine-tune any content to my liking. So far, i have not tested anything better than madVR.
MPC-BE feature wishlist: 1) DiscID
2) Two independent volume control sliders in the UI when using dual-audio-out.
Grimsdyke is online now   Reply With Quote
Old 20th June 2023, 10:10   #42  |  Link
ashlar42
Originally Posted by richardpl View Post
madvr is dead project/code do not use it.
Betas are updated regularly, though. One can always hope for a paid for version, sooner or later.
LG 77C1 - Denon AVC-X3800H - Windows 10 Pro 22H2 - Kodi DSPlayer (LAV Filters, xySubFilter, madVR, Sanear) - RTX 4070 - Ryzen 5 3600 - 16GB RAM
Old 20th June 2023, 13:08   #43  |  Link
nothing of this matters it only confirms even more that it is dead.
mpv is pretty much over taking it planning in a paid madVR version that can't even do what mpv can is just...
Old 25th June 2023, 16:29   #44  |  Link
ashlar42
mpv is one of the least user friendly software I've met in my whole life.
I don't dispute the quality it can offer, I strongly dispute the amount of time needed to get there. Especially when comparing to madVR and a DirectShow based player.
Old 25th June 2023, 16:35   #45  |  Link
Klaus1189
I tried to get HDR passthrough with mpv but i was not successful. Anybody can help me?
Klaus1189 is online now   Reply With Quote
Old 25th June 2023, 22:49   #46  |  Link
pirlouy
_
That's what I said the first time.
But the second time, I accepted to spent several hours on the manual: https://mpv.io/manual/master/
If you have lot of free time, it's doable in 1 day, but with limited time, you have to accept you'll need several days (weeks in my case).
But now I use it for several years (thanks stax76 for motivating me)
Ok, I don't know anything about HDR (i'm still a 1080p SDR user) and maybe it's less good than madVR, but in terms of ressources, mpv is better (you can use HwInfo64 to check CPU/GPU datas for both)
But I'm sure a power user which created a nice guide could learn mpv easily !
Old 26th June 2023, 15:05   #47  |  Link
*MidnightWatcher*
*MidnightWatcher*'s Avatar
I got it up and running in an hour, it's actually easier than I also thought. If you're using Windows I'd recommend Shinchiro's 64bit-v3 build (the 64bit-v3 build has these instructions enabled by default: avx avx2 bmi bmi2 fma lzcnt movbe sse3 sse4 sse4.1 sse4.2 ssse3 xsave sahf mwait crc32 cx16 popcnt f16c). If v3 doesn't work with your CPU just use the regular 64bit version.
1. Download and extract into C:\Program Files\mpv
2. Navigate to the C:\Program Files\mpv\installer directory, right-click the mpv-install.bat and Run as administrator.
3. Go to the C:\Program Files\mpv folder and run the updater.bat as administrator (follow the prompts quickly - I recommend selecting the 64bit-v3 version and the daily builds). This simply updates to any new Shinchiro mpv build and installs/updates ffmpeg.
4. Navigate to C:\Users\[user]\AppData\Roaming\mpv and put your mpv.conf text file here. An example mpv.conf added below.
FYI, there is an mpv player support thread now on AVS to help with the mpv.conf file and settings. The mpv manual also shows all the various options you can include.
https://www.avsforum.com/threads/uno...hread.3274072/
Edit: Here's my current mpv.conf (Windows 10, nVidia RTX 2070S, Display is a JVC X790 projector). You can download shaders from the avs support thread above.
msg-level=auto_profiles=warn,autocrop=warn,autoload=warn,cplayer=warn
#no-osc
#no-osd-bar
no-border
snap-window
autofit-larger=100%x88%
autofit-smaller=33%x66%
no-input-default-bindings
input-doubleclick-time=200
image-display-duration=inf
screenshot-template="%{media-title}-%P-%n"
screenshot-format=png
sub-font-size=36
sub-border-size=0
sub-back-color=0.0/0.0/0.0/0.75
sub-shadow-offset=4
#Video
#ontop
fullscreen=yes
vo=gpu-next
hwdec=nvdec #or d3d11va
video-output-levels=full
#GPU Renderer
fbo-format=rgba16hf  #similar to MadVR
gpu-api=d3d11
gpu-context=d3d11
d3d11-output-format=rgb10_a2
#Luma Upscaling
glsl-shaders-clr
glsl-shaders-append="C:\Users\tmitc\AppData\Roaming\mpv\shaders\FSRCNNX_x2_16-0-4-1.glsl" #update to match your location
scale=ewa_lanczos
scale-blur=0.981251
#Luma Downscaling
glsl-shaders-append="C:\Users\tmitc\AppData\Roaming\mpv\shaders\SSimDownscaler.glsl" #update to match your location
dscale=mitchell
linear-downscaling=no
#Chroma Upscaling / Downscaling
glsl-shaders-append="C:\Users\tmitc\AppData\Roaming\mpv\shaders\KrigBilateral.glsl" #update to match your location
cscale=mitchell
#Upscaling / Downscaling Options
correct-downscaling=yes
sigmoid-upscaling=yes
#Deringing
scale-antiring=0.7
dscale-antiring=0.7
cscale-antiring=0.7
#Optional Shaders
glsl-shader=~~/shaders/adaptive-sharpen.glsl
#Dithering
temporal-dither=yes
dither=fruit
dither-depth=auto
#Deband (Uncomment options below to enable)
#deband
#deband-iterations=4
#deband-threshold=48
#deband-range=16
#deband-grain=48
#Audio Bitstreaming
#audio-spdif=ac3,dts,dts-hd,eac3,truehd #Uncomment this to enable HDMI bitstreaming (Atmos may currently have issues on some systems)
audio-channels=7.1,5.1,stereo #update to match your setup
#OSD
input-default-bindings = yes
input-ar-delay = 500
input-ar-rate = 20
keep-open = yes
keep-open-pause = no
osd-duration = 2000
#osd-playing-msg = '${filename}'
script-opts = osc-scalewindowed=1.5,osc-hidetimeout=2000,console-scale=1
screenshot-directory = '~~desktop/'
[protocol.https]
#osd-playing-msg = '${media-title}'
# Profiles #
[bt.2100-pq]
profile-cond=get("video-params/primaries") == "bt.2020" and get("video-params/gamma") == "pq"
profile-restore=copy
target-trc=bt.1886
target-prim=dci-p3 #options are bt.2020, dci-p3, bt.709
tone-mapping=auto #use "vo=gpu-next" to allow the default spline tone mapping (the best)
tone-mapping-mode=auto
hdr-compute-peak=yes
target-peak=100 # change to auto if using an SDR display (defaults to 203 nits)
gamut-mapping-mode=auto #uses perceptual by default
[bt.2020]
profile-cond=get("video-params/primaries") == "bt.2020" and get("video-params/gamma") == "bt.1886"
target-trc=bt.1886
target-prim=dci-p3
[bt.709]
profile-cond=get("video-params/primaries") == "bt.709"
target-trc=bt.1886
target-prim=bt.709
[interlaced]
profile-cond=deinterlace or (get("video-frame-info/interlaced") and not deinterlace)
deinterlace
[end]
profile-cond=eof_reached
profile-restore=copy-equal
My HT: JVC X790R | 120" CineWhite | madVR HTPC RTX 2070S | mpv | UB420 | Denon X3600H @ 5.2.4 | Totem Tribe LCR | 4 x ADX Maximus & Dayton Audio SA230 | 40" TV / MeLE N5105 / MoviePosterApp
*MidnightWatcher* is offline   Reply With Quote
Old 27th June 2023, 15:30   #48  |  Link
JNW
target-colorspace-hint=yes
And manually turn on HDR in Windows.
JNW is offline   Reply With Quote
Old 27th June 2023, 15:57   #49  |  Link
Klaus1189
Ok, and auto hdr switch possible?
Old 27th June 2023, 16:17   #50  |  Link
JNW
I don't think so. Only if you use gpu-api=vulkan
Old 27th June 2023, 17:14   #51  |  Link
Klaus1189
Ok. What is best solution for refresh rate change? I only can find scripts which require nirsoft.
Old 27th June 2023, 17:31   #52  |  Link
*MidnightWatcher*
That is the best way currently. It works perfectly.
https://www.avsforum.com/threads/uno...#post-62560932
Old 27th June 2023, 17:38   #53  |  Link
JNW
Yep, that is the best way. Change-refresh.lua and nircmd. Just add any missing refresh rates to changerefresh.conf. I've been using it for years now, works perfectly.
Old 27th June 2023, 19:08   #54  |  Link
Klaus1189
It works yes, but not perfect. The pause must be before playback starts, not start playback for a split of a second, change refresh rate, pause for the set seconds and continue.
But thank you very much. Finally I got it working, but I stick with MPC-BE with MPC-VR, madVR and LAV Filters and Kodi.
Old 5th July 2023, 14:07   #55  |  Link
ulysses
I use tv-box on s905 with kodi (corelec 9.2.0)
I need quality hdr to sdr conversion (madvr like)
Can I install this player? or anyone else?
ulysses is offline   Reply With Quote
Old 5th July 2023, 14:40   #56  |  Link
*MidnightWatcher*
No, not that I'm aware of. You'll need a PC.
Old 2nd September 2023, 07:20   #57  |  Link
JimH
Minneapolis
Originally Posted by Charky View Post
Many of you are already aware of it (I recognized a few names on the JRiver forum) bur JRiver now has created its own in-house renderer called JRVR, actively developed by Hendrik/nevcairel (LAV filters) :
Here's an updated thread on JRVR:
https://yabb.jriver.com/interact/ind...,135621.0.html
Support for custom shaders was recently added. Requires MC 31.0.50 or higher.
JRiver
JimH is offline   Reply With Quote
Old 9th September 2023, 16:36   #58  |  Link
stax76
stax76's Avatar
On Windows you can use mpv.net which has a context menu. I will soon build a complete new settings dialog and add many rendering settings. For anything beyond that, feel free to make a feature request.
https://github.com/stax76/awesome-mpv
Old 11th September 2023, 13:15   #59  |  Link
kopija
Glad to hear of your recovery!
kopija is offline   Reply With Quote
Old 24th October 2023, 14:45   #60  |  Link
andybkma
Hi, couple of quick questions please :
- Does the JRiver Renderer (JRVR) have RTX Super Resolution support now? Is it planned?
- Conversely, since MPC Video Renderer does have RTX Super Resolution support, are you able to use MPC Video Renderer with JRiver Media Player?
Thanks, I am hunting for a new video player since ZoomPlayer is only 32bit
andybkma is offline   Reply With Quote
direct3d, enhanced, video renderer
