15th June 2006, 22:26 | #201 | Link |
Hi Manao,
it's again me --- the troublemaker. I have a suggestion of new feature. Of course, it comes from what I do and I need and I know neither how many other users will appreciate it, nor how difficult to add this feature. And as you are the judge, I only show what I have in mind. IDEA: Sometimes there are more values calculated than necessary. Example: I want to calculate range value per each 8x8 block. When I do it with Code:
mt_luts("range",mt_freerectangle(0,0,7,7)...) SUGGESTION: How about adding another optional common parameter or pair of parameters where would be set which pixels the operation should be applied to. When I should present the maximalistic version, there could be defined repeating cycle in each axis, list of pixels within the cycles to be processed and logical operator between h and v axis. EXAMPLES:Calculating range for each 8x8 block Code:
mt_luts("range",mt_freerectangle(0,0,7,7),applyto="h % 8 = (0) & v % 8 = (0)",...) Code:
mt_luts("range",mt_freerectangle(0,0,7,7),applyto="h % 4 = (0)",...) Code:
original.mt_lut(y=-255).mt_lut("0",applyto="h % 8 =(0,7) | v % 8 =(0,7)") |
3rd December 2006, 02:20 | #202 | Link |
Hi Manao,
today I'll be brief. Would you consider adding a "bias" parameter for mt_convolution like in GeneralConvolution? Would be useful in cases like Code:
mt_convolution("0 -1 1","1",bias=128...) Code:
function rd_convolution(clip o, string "horizontal", string "vertical", bool "saturate", float "total", int "bias", int "y", int "u", int "v") { bias=default(bias,0) rdhorizontal=default(horizontal,"1 1 1") rdvertical=default(vertical,"1 1 1") rdsaturate=default(saturate,true) rdtotal=default(total,1.0) rdy=default(y,3) rdu=default(u,1) rdv=default(v,1) p=o.mt_convolution(rdhorizontal, rdvertical, bias==0 ? rdsaturate : true, rdtotal, rdy, rdu, rdv) a= bias==0 ? p : mt_convolution(o, rdhorizontal, rdvertical, false, rdtotal, rdy, rdu, rdv) bias==0 ? p : mt_lutxy(rdsaturate==true ? p : a, a, "x y == y 0 y - ? " + String(bias) + " +",y=rdy,u=rdu,v=rdv) } Last edited by redfordxx; 3rd December 2006 at 03:03. |
22nd March 2007, 21:23 | #206 | Link |
You just have to load both dlls into your script. (1.5.8 and 2.0a30)
And now onto my question. I have a function that uses edgemask() from masktools version 1.5.8. Since it is conflicting with fft3dgpu, I would like to modify this function to use mt_edge instead (from mt 2.0a30) I had a look at the documentation, but I couldn't understand much. I've never written a function before, or have paid much attention to the ones I copied from the board. I hope at least the developer of masktools could help me out. You can see the fft3dgpu development thread for reference about the problem. |
29th March 2007, 17:26 | #207 | Link |
is mt_polish broken in 2.0a30? It's complaining that spirit parser is not available with this script:
blackness().converttoyv12() subtitle(mt_polish("x+y"))
Get my avisynth filters @ http://www.avisynth.org/tsp/ Last edited by tsp; 6th April 2007 at 23:19. |
6th April 2007, 22:16 | #208 | Link |
masktools 1,2 bugs
colorbars(pixel_type="YV12")
yv12lut() returns a bright green image (expected original image). mt_lut(yexpr="x 161 = 0 x ?",uexpr="128",vexpr="128",y=3,u=3,v=3) doesn't work, no test is true for equality. != does work and can be used as a workaround. |
7th April 2007, 06:43 | #211 | Link |
By default, yv12lut trash the chroma planes, so their values is random. It's not a bug.
Tsp : noted, next version will have mt_polish back ( i must have disabled it because it was so slow to compile ). redfordxx : noted too
12th April 2007, 02:32 | #212 | Link | |
Proposal: New mode for mt_LutS: masking of "pixel's extremity" Explanation: in a pixel's neighborhood, there's a darkest and a brightest pixel. Then ... Method1: extremity = abs((pixel-min)/(max-min)-0.5)*2*255 (In the very middle between max and min, extremity is zero. At min and at max, extremity is maximal.) (Used that several times.) Method2: extremity = (pixel-min)/(max-min)*255 (Zero extremity gives mask=128. mask=0 means "pixel has 100% extremity @ dark". mask=255 means "pixel has 100% extremity @ bright".) (Never used this one, but seems feasable, for completeness.) Several times I found this useful during toying-around, but it's rather laborious to script with the current filters: three values are needed for computing, the complete list goes: one (or 2 or 3) inpand's, one (or 2 or 3) expand's, and three instances of LutXY: a=lutxy(min,max), b=lutxy(pixel,min), mask=lutxy(a,b). A good bunch of filter instances that is. So I thought, perhaps(!) it is easier(?) when integrated into mt_LutS ... A new mode, "extremity1/2" or whatever, and via "pixels=" one can define the neighborhood that is to search for the local min and max. Not earthbreaking, not of major importance. Just an idea.
23rd April 2007, 16:56 | #213 | Link | |
Not sure if this thread is the correct place for this, but here I go...
Been fooling around with VMtoon. (the anime sites tend to rave about its predecessor, MFToon). Got it all set up and it produced a horrible result: it turned most of the black outlines into white pixels! Hopefully, I'm doing something wrong. Turning down the power with VMtoon(strength=20) reduced the effect, but then it didn't sharpen either. Here is my script: Quote:
23rd April 2007, 17:19 | #214 | Link |
ангел смерти
A few things to test, to see what eliminates the effect.
Remove resizing: ssw=0 & ssh=0 Remove xsharpen: xstren=0 Remove thinning: thinning=0 Remove darkening: strength=0 If only one is missing the white, that'll quickly narrow it down; if it's more, it could be tougher. |
24th April 2007, 00:13 | #215 | Link |
vmtoon(ssw=0)
vmtoon(ssh=0) vmtoon(ssw=0, ssh=0) Using any of thse returns the same error: "Resize: Width must be bigger then or equal to 4." vmtoon(xstren=0) Result: fixes the problem. vmtoon(thinning=0) Seems to make the problem slightly worse. vmtoon(strength=0) Seems to fix the problem, but makes the sharpening wierd: the black edge lines break up a little. |
24th April 2007, 16:27 | #218 | Link |
I've now confirmed that:
vmtoon(ssw=1) vmtoon(ssh=1) vmtoon(ssw=1, ssh=1) Do not fix the problem, they only make it worse. Thanks for all the help, let me know if you need a few frames to check it out. Would posting screen shots of the output with those different settings help? |
24th April 2007, 22:20 | #219 | Link |
ангел смерти
I wasn't able to reproduce, but I'm not sure I have the right source to do so. If you could replace vmtoon() with ImageWriter(file="x:\wherever\sample",start=x,end=y,type="ebmp") where x to y are representative frames, and then zip them up, I can try to find out where it's overflowing.
24th April 2007, 23:38 | #220 | Link |
Here you go:
http://www.mytempdir.com/1307532 It only 3 frames, I wasn't sure if that was enough. Anyway, if you couldn't reproduce it, its probably somehting to do with my set up. I just did a clean install of everything though, and I was careful to get the latest DLLs... EDIT: I tried using an older version, mftoon2 (mfToon-v0.54.avsi), but it keeps telling me that the "Unsharpmask" function cannot be found... I can't this function anywhere. Is it part of an older package I might be missing? Last edited by Dr.Khron; 25th April 2007 at 03:24. |
