15th July 2016, 00:09 | #38721 | Link | |
15th July 2016, 00:11 | #38722 | Link | ||
I want to replace the motherboard on my TV with this: https://hardforum.com/threads/no-lat...board.1894299/ My plan is to also build a custom shutter glasses+emitter setup to do 3d active. |
15th July 2016, 07:10 | #38726 | Link | |
Intel i5 6600, 16 GB DDR4, AMD Vega RX56 8 GB, Windows 10 x64, Kodi DS Player 17.6, MadVR (x64), LAV Filters (x64), XySubfilter .746 (x64) LG 4K OLED (65C8D), Denon X-4200 AVR, Dali Zensor 5.1 Set |
15th July 2016, 08:42 | #38727 | Link |
What are my options if I want to use MadVR without administrator rights? Presumably there's no way to use it with MPC-HC but are there any other players that include it without having to manually register the filter file?
TV Setup: LG OLED55B7V; Onkyo TX-NR515; ODroid N2+; CoreElec 9.2.7 |
15th July 2016, 09:04 | #38728 | Link |
After updating from v0.90.20 to v0.90.21 (haven't got to try v0.90.22 yet), I started getting worse rendering times but only when scaling.
Just wondering what could be affecting the performance so much because according to the changelog, the .20 -> .21 update was almost exclusively HDR-related (which doesn't concern my usage scenario). The get rendering times down and to avoid dropped frames, I've now downgraded from SSIM 2D to 1D in almost all of my profiles. Nvidia drivers are up to date (I have GTX 960). |
15th July 2016, 09:10 | #38729 | Link |
X Cinema Projectionist NZ
Image Doubling question?
Guys Ive never used image doubling but want to try. I have the new GTX1080 card. Is it ok to use Image Doubling with just straight 1080p content (ripped BDs)? Im using the JVC X9000 projector but not sure how you set this up for 1080p content, 1080p > 1080p. Can some of you offer some instructions please? Thanks in advance... |
15th July 2016, 09:21 | #38730 | Link | |
QB the Slayer
I had to skip .21 since mixed scaling was broken for me, but moving to .22 caused a pretty big performance hit. madshi thought it might be the new rules for when scaling is active and maybe some upscaling refinements now being used... But I'm not so sure, especially now that you see a performance hit with version .21. QB
15th July 2016, 09:54 | #38731 | Link |
It's likely a AMD driver error that stops me from using MPC-HC x64 with madvr. x86 version works fine. The issue is OpenCL. OpenCl kernel compile failure.
Not sure it's worth finding an older driver that works. Will just keep using x86 i guess. |
15th July 2016, 11:36 | #38732 | Link | |
Anyway, I'll try the .22 version later today and report back. EDIT: No discernible difference in rendering times here when going from version .21 to .22. So, still no clue where those aforementioned differences originated from. Last edited by Uoppi; 15th July 2016 at 16:27. |
15th July 2016, 12:33 | #38733 | Link |
anyone has an idea what player supports madvr exclusive mode while using a nice osd and not just the madvr fse bar?
15th July 2016, 12:55 | #38734 | Link | |
https://imouto.my/tutorials/configur...ware-decoding/ Last edited by toniash; 15th July 2016 at 12:59. |
15th July 2016, 13:02 | #38735 | Link | |
15th July 2016, 13:09 | #38736 | Link | |
https://www.dropbox.com/s/bhl4u4rfb1wjxbf/pot2.jpg?dl=0 https://www.dropbox.com/s/al74z459zoewwrh/pot1.jpg?dl=0 and enable automatic fullscreen exclusive mode im Madvr you get the OSD when moving the cursor top or bottom |
15th July 2016, 13:09 | #38737 | Link |
Why do you even need this? Seekbar makes sense in FSE, but other controls? Use keyboard shortcuts or a remote for the player, and problem solved.
Ryzen 5 2600,Asus Prime b450-Plus,16GB,MSI GTX 1060 Gaming X 6GB(v398.18),Win10 LTSC 1809,MPC-BEx64+LAV+MadVR,Yamaha RX-A870,LG OLED77G2(2160p@23/24/25/29/30/50/59/60Hz) | madvr config |
15th July 2016, 13:16 | #38738 | Link | |
15th July 2016, 13:39 | #38739 | Link | ||
15th July 2016, 16:33 | #38740 | Link |
With the .22 version (I can't remember seeing this before), the madvr OSD is reporting Bicubic150 AR downscaling in addition to SSIM 1D that is chosen for the profile.
Like this: image x > super-xbr > super-xbr < SSIM 1D100AR image y > super-xbr > super-xbr < SSIM 1D100AR < Bicubic150 AR Would someone be able to tell me what's going on there? This is quadrupling (luma) SD to 1080p. Last edited by Uoppi; 15th July 2016 at 17:43. |
