10th June 2009, 03:00 | #541 | Link |
Fighting spam with a fish
Yeah, I thought there were some bugs due to the clip at hand.
As for the clip being corrupt, it shouldn't be. I cut it with DGSplit directly from the .m2ts file. I have even converted the entire m2ts file to h.264 in MKV (using DSS2) and that went just fine. TSMuxer (1.10.6) demuxes the clip just fine. Last edited by Adub; 10th June 2009 at 03:02. |
10th June 2009, 20:38 | #542 | Link |
Excessively jovial fellow
I finally got around writing some API docs for FFMS2. Useful if you don't want to fight with ffmpeg to decode stuff in your program.
21st June 2009, 16:30 | #543 | Link |
Professional Code Monkey
As you can see if you look at the todo list the next beta is progressing nicely, or at least close to it. But to finish the API design, so others can begin to use FFMS2 as a library without weekly updates, I really need a clip where the resolution changes in the video. Without it it will be impossible to test any implementation. So if you have one don't hesitate to send it to me. I only need a small part where the transition actually happens.
26th June 2009, 21:57 | #545 | Link |
VC-1 crash, and the benefit of avcodec_close()
I've been using FFMS2 within x264 for a while, with very satisfactory results on various files. However, I've just found one which has particularily nasty effects : vc1-crash.mkv This VC-1 in MKV file actually corrupts the heap when you call FFMS_CreateVideoSource() on it, causing random crashes somewhere down the line. The odd thing is, ffmpeg itself can decode it without trouble ! This problem has actually already been encountered by some clever guys at the HandBrake forums. It turns out that, sometimes, the VC-1 codec does not set itself up properly when you call avcodec_open the first time : but it does work if you close it and open it again (this is what ffmpeg does). Indeed, if I add Code:
avcodec_close(CodecContext); avcodec_open(CodecContext, Codec); I don't even know which codecs need this kind of double-opening, or when the ffmpeg application does it. But I thought you'd like to know. AG |
26th June 2009, 23:00 | #546 | Link |
This is obviously an FFmpeg bug. One of my evil minions may or may not bother to bring it to the attention of the relevant developers. In the future I suggest you report such issues at http://ffmpeg.org/bugreports.html because I don't want more ugly workarounds in my code either way.
VapourSynth - proving that scripting languages and video processing isn't dead yet Last edited by Myrsloik; 26th June 2009 at 23:02. |
27th June 2009, 02:55 | #547 | Link |
I am the evil minion in question and I've reported it.
28th June 2009, 01:32 | #548 | Link | |
The things that are left before the next release is to add some kind of NVOP fix/hack so it can be tested and for Haali to take a look at big ts files that hang while indexing. Maybe also a small bit of internal testing... A new compile with the VC1 fix can be downloaded from http://ivtc.org/new/beta/FFMS2_vc1_fix_test.rar It also has a lot of other changes so if you encounter any other new bugs feel free to report them as well.
VapourSynth - proving that scripting languages and video processing isn't dead yet Last edited by Myrsloik; 28th June 2009 at 01:47. Reason: Added a download link |
28th June 2009, 10:00 | #550 | Link |
"Hello there! I have an unspecified script I won't tell you about! Now guess what it does!"
2nd July 2009, 15:09 | #551 | Link |
Posts: n/a
Hi ya
Just wanted to report another instance of "Codec returned zero size video" in VirtualDub, AvsP and MPC ... Same errror when invoked with FFMS2() or FFVideoSource() ... Example clips (MTS with AVC video and AC3 audio, straight from a Panasonic AVCHDlite device): 00000.MTS, 00001.MTS, 00002.MTS Can anybody suggest a possible fix using FFMS2, as they work with FFMpegSource(), DSS2() and AVCSource(), but I would prefer an FFMS2_MT version for speed (MT and standard FFMS2 throw the same error)!! Thanks, Tek Last edited by 7ekno; 2nd July 2009 at 15:54. |
2nd July 2009, 20:47 | #552 | Link | |
After that I looked at the real problem which looks similar to other clips I've seen before. Sometimes in transport streams it can't decode a single frame when Haali's splitter is used. I have no idea exactly what causes it. The reason 1.x can open it is that it uses LAVF instead. Then I tried opening it with LAVF's splitter intead of Haali's and it now "works" with seekmode!=1 after I found another typo in the code... So I guess I'll make it possible to force using LAVF when creating indices with FFIndex() in the next version. That should at least give you working linear access. Or did 1.x work better than that?
5th July 2009, 02:45 | #553 | Link |
warpsharpened
ffms2-mt-04072009.rar (beta 10ish)
Ditched ICL for now. Compiled with gcc 4.4.0 + msvc. Includes libfaad and opencore-amr. ffms2, ffmpeg-mt, and opencore all updated to this day. Last edited by TheRyuu; 5th July 2009 at 02:50. |
12th July 2009, 13:28 | #554 | Link |
A new version with more experimental fixes. Should fix h264 in TS like in this post http://forum.doom9.org/showthread.ph...28#post1302028 (despite the name too). It also fixes a typo in the code for setting the width/height in the previous VC1 fix. If there are any regressions, especially that h264 files in TS stop working, make sure to report it.
Get it from http://ivtc.org/new/beta/FFMS2_vc1_fix2_test.rar Note that there is still an issue that stops VC1 in TS streams from working (need to ask Haali when he reappears). Indexing of huge TS files can still hang but Haali has managed to reproduce it.
14th July 2009, 08:08 | #555 | Link | |
Posts: n/a
I find for some reason FFMPEGSource2 more reliable on AVCHD sources (motion seems smoother in final transcoded MKV for some reason) .. Now where is TheRyuu with a -MT version :P Thanks, 7ek |
15th July 2009, 23:26 | #557 | Link |
Software Developer
Same here with my FFV1 source. I'm back to Beta-9
17th July 2009, 22:36 | #558 | Link |
Is this a regression? Did your files work with beta9? If yes, could you upload a short sample of one of those files?
17th July 2009, 23:26 | #559 | Link | |
Software Developer
Sample: http://www.mediafire.com/file/tzqcoz...ffvh_sample.7z
Go to https://standforukraine.com/ to find legitimate Ukrainian Charities 🇺🇦✊ Last edited by LoRd_MuldeR; 17th July 2009 at 23:37. |
21st July 2009, 18:24 | #560 | Link | |
