17th November 2007, 23:43 | #1422 | Link | |
No idea. The best idea would be: Try it out and report it here! |
17th November 2007, 23:47 | #1423 | Link | |
"Source file is ac3, destination file is ac3, and no different bitrate was specified. So I'm not supposed to reencode. I'm only supposed to remove dialnorm (if even necessary)." You can work around that by doing it in 2 steps: (1) eac3to ice.greek.ac3 ice.greek.wav -slowdown (2) eac3to ice.greek.wav ice.greek.new.ac3 Please note that the "-resampleto48000" is probably superfluous in your case. AC3 files coming from DVDs are usually already 48000. And "-slowdown" does not change the samplerate. |
17th November 2007, 23:55 | #1425 | Link |
Ah yes, that's one thing I forgot to mention: Bitdepth can be reduced to anything between 14 bits and 23 bits now. And for FLAC encoding every bit helps getting the file size down. Roger Dressler (Dolby) recently stated on AVSForum that in his opinion 20 bits may be the sweet spot. So personally I might now reduce all my 24 bit tracks to 20 bit. Haven't fully decided yet...
17th November 2007, 23:56 | #1427 | Link |
Can somebody post a command line for an eac3 source and the desired target to be AC3 640kbps using the sonic filter?
This is not working anymore for me: eac3to stream1.eac3 stream2.ac3 -48 -640 -sonic enjoy, Mtz |
17th November 2007, 23:57 | #1428 | Link |
You can PM me the bug report or you can post it into gmail. Once the bug report window is visible on screen, the bug report is automatically stored into the clipboard. So just open PM or gmail and press Ctrl+V.
18th November 2007, 00:00 | #1430 | Link |
What is that "-48" supposed to mean? Just remove that. It should work then. The "-640" is probably not necessary, either, cause it's the default value used by eac3to for multichannel audio tracks. So just "eac3to stream1.eac3 stream2.ac3 -sonic" should do.
18th November 2007, 00:15 | #1433 | Link |
I have a problem with ratatouille remuxing (AVC, LPCM).
the movie has seamless branching so I joined each .m2ts part via "copy /b..". after that I used xport to extract video and audio from the joined .m2ts file and used eac3to to convert the LPCM stream (24-bit) to FLAC (everything fine). but after I remuxed both together with mkvmerge I get an audio problem at playback (ffdshow, coreflac): audio suddenly disappeares at ~53 seconds movietime and also doesnt come back later on, shortly after that mpc crashes. im not quite sure whether this could be a problem of the new eac3to version or because of seamless branching joining; however the error occurs before the first switch from the 1st to 2nd .m2ts file took place (length of 1st .m2ts file ~1:30 mins). im currently using v1.23 to convert to flac again and will mux it all again together to see whether it might still crash then. |
18th November 2007, 00:18 | #1434 | Link | |
Usually after having joined TS files you need to run TsRemux over the result. However, I'm not sure if that does anything to audio. Maybe as a result of the seamless branching the joined audio data is corrupt. Would be strange but not impossible. E.g. if you add one byte in the middle of a valid PCM file you'll get totally trash sound after that byte. |
18th November 2007, 00:20 | #1435 | Link | |
I also think a rename of eac3to is needed. |
18th November 2007, 00:25 | #1437 | Link |
New eac3to name suggestions:
- madAvConvert(er) - (AV for AudioVideo) - madHcConvert(er) - (Hc for HomeCinema) - madConvert(er) The AudioVideo just in case. If I name it "AudioConverter" now, I'll have to change again in case I should ever decide to add some kind of video processing. Your opinions? Any other suggestions? |
18th November 2007, 00:25 | #1438 | Link | |
I tried to mux the flac file into .mka and wanted to play it outside, but I got an error directly before at the beginning of the parsing stage (and strangely enough this error was not reported or didnt stop the muxing of the previous .mkv with video and audio together). |
18th November 2007, 00:28 | #1439 | Link | |
18th November 2007, 00:35 | #1440 | Link | |
the mkvmerge remux with the v1.23 flac file just finished parsing successfully, will soon find out whether it will work together with the video. |
eac3to |
