21st May 2012, 07:56 | #11061 | Link | |
Heres the view of the splitter during playback: |
21st May 2012, 08:08 | #11062 | Link | |
So is it worth to switch to a GT 630 with GDDR5 (96 cuda, 128 bit memory!!!)? Is it inlcludes vp5? (The other 2 (610,620) are very bad. I know that these are the low end cards now.) Thanks
Ryzen 5 2600,Asus Prime b450-Plus,16GB,MSI GTX 1060 Gaming X 6GB(v398.18),Win10 LTSC 1809,MPC-BEx64+LAV+MadVR,Yamaha RX-A870,LG OLED77G2(2160p@23/24/25/29/30/50/59/60Hz) | madvr config |
21st May 2012, 10:06 | #11063 | Link | |
Even if the first stream would have the same bitrate as the second stream, it will always prefer the first stream in a file. A rule like "always use the second" just doesn't make much sense. Its possible that i can add an option to ignore streams marked as hearing impaired in the future, but for now you will have to change it manually.
21st May 2012, 10:28 | #11064 | Link | |
The same problem used to exist with UK satellite broadcasts in MediaPortal because the "audio description" stream is first for some reason. Luckily, they are always MP2 and the normal audio is always AC3 so they just added a "prefer AC3" option.
TV Setup: LG OLED55B7V; Onkyo TX-NR515; ODroid N2+; CoreElec 9.2.7 |
21st May 2012, 10:52 | #11065 | Link | |
21st May 2012, 16:01 | #11066 | Link | |
Nevermnid: I see now that you are trying to change a .wtv file. Remux it to another container I guess. Last edited by glorp; 21st May 2012 at 16:06. |
22nd May 2012, 03:01 | #11068 | Link |
SVP developer
LAV and DVD
I faced with DVD-playing problem in MPC-HC.
I use LAV decoder preferred in external filters MPC. When I open single VOB-file from DVD I see LAV decoder is working for me. But when I use "Open DVD" dialog it loads ffdShow decoder but not LAV. Do you know why? Can LAV Filters to decode whole DVD? How to setup it? |
22nd May 2012, 06:10 | #11070 | Link | |
On a side note, there was a question burried in the original post regarding the best method of updating LAV Filters without having to lose settings. I would still like that one answered if anyone here is willing. I use the installer method currently, but I think uninstalling and reinstalling will cause me to lose settings. Haven't tried it. Thanks again so much Andy! I really hope you take a look at the other thread: http://www.avsforum.com/avs-vb/showt...8#post22044858 Last edited by powder21; 22nd May 2012 at 06:12. |
22nd May 2012, 06:32 | #11071 | Link |
Thanks for the clarification ...
23rd May 2012, 03:44 | #11074 | Link | ||||
I also noticed this in the changelog: Quote:
23rd May 2012, 06:06 | #11075 | Link |
Thanks for the info! I'll install on both desktop and laptop ...
23rd May 2012, 08:17 | #11077 | Link |
Fantasy Codecs writer
(301.42)[GeForce 400 series]: There is no picture when using LAV DirectShow Filters on MPCHC for MPEG4 video playback. [952108]
test GTX 460 with 301.42 whql.play mpeg4-asp video with last lav git use cuvid no problem! |
23rd May 2012, 16:57 | #11080 | Link | |
This has also been discussed in great lengths before.
