Old 30th June 2017, 17:27   #44221  |  Link
johnnylaiyee
johnnylaiyee's Avatar
Originally Posted by hannes69 View Post
Maybe itīs a better strategy to spend more time watching videos than seeking something within them I donīt quite understand why here and there often comes up the topic of perfect performant seeking. What the heck is permanently to be sought in videos? Start a movie, lean back and enjoy
Porn maybe?
Sent from my LG-H860 using Tapatalk
johnnylaiyee is offline   Reply With Quote
Old 30th June 2017, 19:51   #44222  |  Link
XMonarchY
Posts: n/a
If I have Chroma Upscaling set to NGU - AA Very High Q + SuperRes, then should I also enable Anti-Ringing for Upscaling Refinement for the best quality with SuperRes? Linear Light too?
I noticed Chroma Upscaling with NGU AA Very High Q + SuperRes does not allow Anti-Ringing, so it got me confused...
Old 30th June 2017, 20:09   #44223  |  Link
QBhd
QB the Slayer
QBhd's Avatar
I thought that the consensus was SuperRes and NGU was less than ideal
QB
QBhd is offline   Reply With Quote
Old 30th June 2017, 21:12   #44224  |  Link
AngelGraves13
Nvidia's private API for HDR will no longer work with the Creator's Update and has been abandoned according to Nvidia Rep in their forums. The Fall Creator's Update will better support HDR.
AngelGraves13 is offline   Reply With Quote
Old 30th June 2017, 21:21   #44225  |  Link
mzso
Good for you for understanding every mumbled sentence, and never being disturbed while watching a movie, and for always having the time to watch all arbitrarily long videos for the bit of stuff you're interested in partway through it.
Why don't we just use a single keyframe and then only encode reference frames?
Old 30th June 2017, 21:39   #44226  |  Link
ryrynz
ryrynz's Avatar
Originally Posted by XMonarchY View Post
should I also enable Anti-Ringing for Upscaling Refinement for the best quality...
I keep telling you to decide these things for yourself.
Old 30th June 2017, 21:54   #44227  |  Link
hannes69
I watch movies in my home cinema and like the name of this institution suggests I use it like a cinema: The movie is started and then the audience watches the movie till the end. Maybe the movie will get paused when going to the restroom or when getting some beer etc (most of the time not by me, I donīt like interruptions). But seeking is indeed never really needed in my case.
Of course I understand that needs are different. But I think that seek performance is a) not highest priority in a playback chain (video quality e.g. is way more important in my opinion) and b) the given seek performance should be sufficient for everybody. When not having the time to wait 1 sec maybe itīs time to think about stress syndromes
hannes69 is offline   Reply With Quote
Old 30th June 2017, 22:06   #44228  |  Link
mzso
It's really annoying if you seek a lot. eg: when you skim a movie that you already watched.
I myself seek a lot because I often loose focus, or just don't understand what they say in english.
Old 1st July 2017, 00:09   #44229  |  Link
XTrojan
So I have 1080p blu-ray rips and a 1080 Ti, I'm settled on NGU, but unsure which NGU to use, very high "sharp" feels way to aliased.
I'm also unsure if I should activate "debanding" since it kinda just seems to add a filter.
XTrojan is offline   Reply With Quote
Old 1st July 2017, 02:51   #44230  |  Link
ryrynz
ryrynz's Avatar
Sounds to me like you should turn your screen sharpness down.
Old 1st July 2017, 04:24   #44231  |  Link
galneon
What I don't understand is people who waste time criticizing the viewing priorities of others, even going so far as to suggest psychological issues, instead of spending their free time watching films in their pretense-laden 'home cinemas'.
galneon is offline   Reply With Quote
Old 1st July 2017, 11:51   #44232  |  Link
Rick164
Noticed that madVR GUI didn't have a settings import/export option and even after some google-fu couldn't find any examples that archived this so decided to create 2 simple batch scripts
// Creates settings.reg for automated or manual restore
backup_settings.bat
// Restores from settings.reg file and clears any current settings
restore_settings.bat
Rick164 is offline   Reply With Quote
Old 1st July 2017, 14:24   #44233  |  Link
Q-the-STORM
Shouldn't it be enough just to copy the settings.bin?
Old 1st July 2017, 16:07   #44234  |  Link
Rick164
It never creates one here, thought that settings.bin export was something the user could do manually but didn't find examples
Best guess is that it's a rights restriction as typically you would need to run as admin before anything can write in program files (at least with UAC enabled), the registry exports just works from anywhere and automated that here with daily task so I can always rollback.
Old 1st July 2017, 16:50   #44235  |  Link
XMonarchY
Posts: n/a
Is there a set of example images that can be used to make a comparison? I can't even figure out how to take a screenshot of madVR-rendered content in Exclusive FullScreen Mode...
I often can't see any difference, even zoomed in. I just go by what general thread population suggests as overall highest-quality setting for non-anime film content.
Old 1st July 2017, 20:49   #44236  |  Link
Asmodian
Install madVR to a directory outside of Program Files (or you can change the permissions of madVR's directory in Program Files).
But thanks for creating the batch files too.
madVR options explained
Old 1st July 2017, 21:11   #44237  |  Link
madshi
Originally Posted by Telion View Post
, please make downscaling after doubling use strict AR in NGU AA & super-xbr. And add the hotkey to display configuration dialog. Why it's taking so long to do these simple things?
It's taking so long because my day only has 24 hours, and because I have to spend some of my time on earning money, too. Strict AR for NGU AA + super-xbr will be in the next build. The hotkey will have to wait.
Originally Posted by Ver Greeneyes View Post
@madshi, I don't know whether this is just an aesthetic glitch, or whether this is specific to my system, but I've noticed that my queues periodically seem to empty for a moment. I don't know if this is because of a latency spike or what, and it usually doesn't seem to cause a dropped frame, but I think it does sometimes when it gets unlucky with the render time. I've noticed that by significantly lowering my settings (bringing the processing down to ~5ms below my frame budget) I can sometimes get it to stop, but it doesn't seem consistent. Maybe it's related to memory usage on the GPU? I'm using the D3D11 path, and enabling "present a frame for every VSync" or "use a separate device for presentation" doesn't change it.
Edit: The reason I ask is that I've noticed the same thing on my laptop (GeForce GTX 1060 3G) and desktop (GeForce GTX 1080). I have Smooth Motion set to "only if there would be motion judder without it", but these 'glitches' don't seem to correspond directly with duplicated frames. Both devices are running Windows 10 with the Creators update, and the latest drivers (382.33), but I think this has been happening for a while now.
That's really hard to say. You don't have any tools like GPU-Z or F.lux running? You may have to experiment to find the cause. E.g. try without a 3dlut. Try a long m2ts movie without segments. Try with FSE mode turned on or off. Try with the new option "hack Direct3D to make 24.000Hz work" turned on or off. Try with a lower number of pre-presented frames. Etc...
Originally Posted by sauma144 View Post
Is there a reason why madVR doesn't/can't have a reclock feature like on MPDN or Kodi?
Is it because it can't affect audio?
Correct. madVR is not involved at all in anything audio related. Reclock works by resampling audio, so that's not something madVR can do. However, there will soon be a new feature that may make Reclock like algorithms not needed, anymore. We'll have to see if it works as intended, but that's my hope.
Hey do you know if a Splash Motion2 or SVP like feature is planned for madVR?
Not in the near future.
Originally Posted by rod93 View Post
mpc-hc crash when playing mvc 3d with lavideo decoder, madvr on intel 4600 (with optimus)
"exception: acces violation"
crashin module:
igd10iumd32.dll
offset: 0x17cf088d, codebase: 0xc90000
thread 3992 tried to read memory at adress 0x8244491"
Try different GPU driver versions for both Nvidia and Intel. Also try disabling or enabling automatic fullscreen exclusive mode in madVR, or lowering the number of pre-presented frames to e.g. 3.
Originally Posted by Damien147 View Post
Guys I am confused and I need an opinion.After trying madvr's new option I can finally activate 23hz and results seem good(1 frame drop every 1 hour) but I lose 4:4:4.
What do you think it's the best choice?4:2:2 with 23hz and supposedly smoother motion or 60hz with smooth motion on and 4:4:4?
For video playback 4:4:4 is not terribly important. However, smooth motion works pretty well. So I can't really tell you which is better. I'd say compare both and trust your eyes.
Originally Posted by 70MM View Post
Can someone please explain.
I have a ripped version of the BD Oklahoma which is 1080 29.970 frame rate.
Says who? What does eac3to say about this video?
Originally Posted by lunkens View Post
Is there a way to modify any file in Kodi to report back "actual aspect ratio" from MadVR?
Today I have a plugin (Control4 Driver) that make API calls to Kodi VideoPlayer.VideoAspect and ListItem.VideoAspect.
I think the problem reside in Kodi not getting the info from MadVR. And most files I've tried have hard encoded blackbars hence 1.78 is reported. Maybe a trivial problem for most. But I still seek the answer.
I don't really understand what you mean/need. Which exactly is the problem you're having? madVR generally does report all the needed information, but whatever software you think should access this information must know how to get the information from madVR.
Madshi, with D3D11 I still get some frames presented from earlier in the video when I jump forward on my HD4000.
Was there at least an improvement? Or is it still as bad as it always was? FWIW, I was able to reproduce the problem on Kaby Lake and my changes worked around the problem for me. In any case, it's an Intel GPU driver bug.
Originally Posted by oddball View Post
Madshi can you please explain why the following does not work '1080p23, 2160p23' If I use that when the display is set to 2160, it cuts off a 1080p video and only shows half of the video on the display to the right and the left half is black. If I set the display to 1080 it shrinks the 2160p video to the top left corner (quarter) of the display and the rest of the display is black. Is there no way to fix this?
Can I see a screenshot of the OSD? Most probably it's a media player bug. It probably asks madVR to do weird zooming, for some reason.
Originally Posted by Vincent Vega View Post
Is there a way to turn off the "Exclusive/Windowed" message at the top left when switching between windowed/fullscreen?
Not yet. Planned for some future version.
another question:
i cant use mpc-hc "save image" with madvr (dxva2 copy-back decoding + dxva2 scaling).
the output of save image is discolored mostly white picture with barely visible silhouettes, and the size of mpc-hc window, not the frame size.
Screenshotting is currently just barebones feature. It works sometimes and sometimes not. I plan to totally revisit it at some point in the future.
Originally Posted by Xello View Post
Are there any known fixes for this issue? https://forum.redfox.bz/threads/wind...reclock.72475/
Basically the creator's update has resulted in the loss of normal playback using madvr with reclock, with repeated/dropped frames frequently where before it would not be an issue
I don't know. You could try to reinstall the GPU drivers, hoping for the best. My personal recommendation is to use Windows 8.1.
Originally Posted by igvk View Post
could you please add the current display ICC profile name to the madVR profile rules variables?
Currently I'm not doing anything ICC. What do you need this for?
Originally Posted by Soulnight View Post
is there any boolean value to apply a specific "profile" to hdr content with "undefined hdr"?
I created a profile with the boolean value "HDR". Problem is, I have some videos which doe have HDR but somehow with hdr flag resulting in this "HDR: undefined" instead of HDR: 4000 nits for example.
And in this case the HDR boolean value does not recognize the profile as being HDR.
You're saying the "HDR" profile variable isn't set for HDR content with unknown metadata? If so, that would be a bug!
Do you plan to add Enhanced EWA upscalers into madVR?
Are you sure there's anything new in there? It seems to be very old, much older than the EWA implementation in ImageMagick/madVR.
Originally Posted by SamuelMaki View Post
My LG TV has a PC-mode only on 59 or 60hz refreshrates, it drops to the full-processing mode with anything else (23,24,25,29,50 etc).
Hence I am asking if there is any real reason why I shouldn't use 60hz and smooth motion with madVR?
Is the blending algorithm worse than what TVs do? I doubt this 2010-year panel does REAL 24hz, but some sort of internal conversion to 60hz or close instead. It has the LGs "True Cinema" toggle in settings though, which apparently in new models means 72hz, but when doing a custom resolution with 72hz, it drops frames and is still 60hz really. Very confusing for sure. However even with all settings turned off in the LG, when it is not in PC-mode, the text is less sharp and clearly some processing still left, which I am trying to eliminate with the PC-mode in the first place.
The only person who could answer your question would be someone with *exactly* the same TV you have. So basically, you yourself are the best candidate to test this and come to your own conclusion...
Originally Posted by no1d View Post
I think, when I have "don't rerender frames when fade in/out is detected" option disabled, subtitles are flashing sometimes. Are there any workarounds for it?
That's a problem with the subtitle renderer. You could try a different subtitle renderer. Or, simply activate the "don't rerender frames" option. It's not a night-and-day difference option, so it's not all that dramatic to lose it.
Originally Posted by Magik Mark View Post
I'm not sure if this has been answered. It seems I can't find it in this thread.
I'm having problem in PERMANENTLY setting the BRIGHTNESS to -15. Once I have changed it to -15 it just won't stick. It resets back to 0 once a new video is played.
Is there a way to permanently set it to -15?
Where exactly are you trying to set the brightness? If you change it in "color & gamma" in your madVR display settings, it's supposed to stick.
Originally Posted by Siso View Post
Is there a possibility for madvr to add crop functions like - crop to 1.85:1, or crop to 2.35:1, or crop to 2.39:1 or crop to 2.40:1?
What do you need this for? madVR already has automatic detection (and optionally removal) of black bars, which supports any possible aspect ratio, not just those you listed.
Originally Posted by takenori View Post
between lav settings of hw decoding: no hw decoding through dxva, which of them the "proper/right way" for madvr?
If your CPU/GPU can do it, I prefer software decoding, next best for me is DXVA copyback. If all else fails, you can use DXVA native.
Originally Posted by pankov View Post
last week I got the chance to test my first 4K TV with HDR support (LG OLED65E6)
Nice!
Since madVR is smart enough to turn on the HDR mode on the TV and get specular highlights in 1000+ nits (well ~500 nits on this OLED TV) while maintaining the rest of the picture at lower levels ... or even much lower in dark scenes ... the rendered subtitles (which by default are "white" - RGB 255,255,255) are blindingly bright and they have much greater area than a specular highlight and are almost hurting the eyes. This got me thinking if the way madVR and XySubFilter that I use are actually rendering the subtitles is correct. On one side XySubFilter doesn't know if the subs are rendered over an HDR or SDR video ... I think ... and the preference for font color it uses is always the same ... which makes me believe that it's madVR's job to lower the brightness of the color/white in some way (f.e. 255,255,255 = 100 nits as per SDR spec) but on the other side if there is some color/brightness information in the SRT file (I'm not 100% sure if it's possible but with other external subtitles formats it is AFAIK) how should madVR react?
Good question! Will have to add this to my to-do list. I suppose subtitles should probably never be brighter than 100 nits. So maybe I need to post process the subtitles to enforce them to not be too bright...
I don't know if this can be useful for madVR.
But it seems it's possible to detect HDR support of any displays with Windows.
https://github.com/Microsoft/DirectX...12HDR.cpp#L904
Thanks, was already aware of that, though.
Originally Posted by Zaoshi View Post
Just tried this. All issues have disappeared so I did some poking. This problem seems to arise only when I'm using NGU. Even when I set NNEDI3 to 256 neurons (100 ms frame time) it still seeks faster than NGU (30 ms).
Strange stuff. Just tried to reproduce the problem here, but can't. Seeking is not any slower here with NGU compared to Catmull-Rom.
Actually, that's not true - fortunately! I've been in contact with the Nvidia developer who's responsible for Nvidia's private HDR API. He's aware of a bug in the current Nvidia drivers and plans to fix it soon.
backup_settings.bat
Nice!
For export yes. For import no, because madVR checks both the settings.bin and the registry and uses the settings block with the higher revision number. However, you can run the "restore default settings.bat" and afterwards copy the settings.bin. That should do the trick for import.
The settings.bin file is automatically written, but only if madVR has write access to its own folder. This is supposed to help making madVR more portable.
Originally Posted by ABDO View Post
hi madshi , The authors of SRCNN have published another paper about accelerating SRCNN(FSRCNN).now it can run in real-time performance
http://mmlab.ie.cuhk.edu.hk/projects/FSRCNN.html
FSRCNN is a big improvement over SRCNN. But it's still not as good as NGU, IMHO.
FSRCNN is a neural network which is trained to do only one very specific thing, namely reverting a Catmull-Rom downscale in such a way that you get the highest possible PSNR/SSIM numbers. Which means that FSRCNN produces very sharp and detailed results, but also has very noticeable ringing artifacts. Furthermore, it works best with images that were downscaled using Catmull-Rom. Any other images (while still looking fairly good) suffer in comparison.
I'm not sure exactly how fast FSRCNN is compared to NGU. My best guess is that the slower FSRCNN preset might be near to NGU Very High, and the faster FSRCNN preset might be near to NGU Medium. But this is just a guess.
If you're interested, I've uploaded some comparison images here:
http://madshi.net/FsrcnnVsNguSharp.zip
I'm pretty sure that FSRCNN achieves higher PSNR/SSIM numbers than NGU Sharp (haven't actually checked), but to my eyes NGU Sharp looks significantly better. NGU is slightly softer, but is much cleaner and consequently looks more natural to my eyes.
NGU is not optimized for PSNR/SSIM. Of course I could do that, and I could also reduce NGU to be just a Catrom-Downscale-Reverter instead of a general purpose upscaler. This way I would probably beat FSRCNN's PSNR/SSIM numbers. But my top priority is not to produce the highest PSNR/SSIM results, but to create the best looking images for the human eye. Which e.g. means that ringing artifacts should be avoided. I like sharpness like the next guy, but it shouldn't come at the cost of ringing.
Old 1st July 2017, 21:12   #44238  |  Link
Rick164
@Asmodian that explains it, just noticed your guide from the signature and thanks for that as it helped to clarify some things.
Old 1st July 2017, 21:27   #44239  |  Link
igvk
The reason for this is simple - I would like to use different 3D LUTs for different ICC profiles.
This is because NEC MultiProfiler loads differently named profiles depending on built-in gamut modes of the monitor.
So, this is the only way for me to switch between different calibration modes in madVR automatically, depending on selected picture mode in MultiProfiler.
igvk is offline   Reply With Quote
Old 1st July 2017, 21:28   #44240  |  Link
madshi
madVR v0.91.11 released
http://madshi.net/madVR.zip
* fixed: HDR metadata via Nvidia's private API was broken in 64bit
* added workaround for driver bug in Nvidia's private HDR API
* improved Windows 10 HDR metadata support
* D3D11 windowed mode now supports 10bit, if "HDR and Advanced Color" is on
* improved AMD native 10bit DXVA decoding; drivers are still broken, though
* downscaling after doubling now uses relaxed AR only for NGU Sharp + Standard
This is just a little bugfix release for improved HDR handling.
