30th November 2014, 19:57 | #27681 | Link |
Okay, is there a way for me to check this? I mean, your TV from 2009 is pretty old by today's standards (no offence!).
SETUP: Win 10/MPC-HC/LAV/MadVR HARDWARE: Fractal Design Node 804 | Xeon E3-1260L v5 | Supermicro X11SSZ-TLN4F | Samsung 2x8GB DDR4 ECC | Samsung 850 EVO 1TB | MSI GTX 1650 Super | EVGA G2 750 |
30th November 2014, 20:53 | #27682 | Link |
_
From first post of this thread: http://madshi.net/madVR/ChromaRes.png in full screen
30th November 2014, 21:52 | #27684 | Link | |
Ok, so I'm using 23,976 refresh rate and I can see the image saying 4:4:4. Is there something more I need to do?
30th November 2014, 22:07 | #27686 | Link |
SETUP: Win 10/MPC-HC/LAV/MadVR HARDWARE: Fractal Design Node 804 | Xeon E3-1260L v5 | Supermicro X11SSZ-TLN4F | Samsung 2x8GB DDR4 ECC | Samsung 850 EVO 1TB | MSI GTX 1650 Super | EVGA G2 750 Last edited by Xaurus; 30th November 2014 at 22:13. |
30th November 2014, 22:39 | #27688 | Link |
Ok cool, so what was mentioned by pirlouy for other refresh rates than 60 doesn't apply to this Samsung set then?
30th November 2014, 23:16 | #27690 | Link | |
A couple of questions:
1st December 2014, 00:01 | #27692 | Link | |||
HKCU\Software\madshi\madVR\OpenCL\forceVendor A search for "forceVendor" should give you more details on how to use that. Quote:
Well, at least that's without the SuperRes post processing. Not sure how that changes things. I haven't really had time yet to study Shiandow's algorithms in detail. Hopefully I'll get around to do that rather sooner than later. But I don't know yet... Leave LAV filters to default. The defaults are usually optimal for madVR. Best bang for the buck is luma doubling, followed by chroma upscaling. Usually doubling chroma has the lowest benefit. If you have performance to spare, up the neurons for luma doubling. |
1st December 2014, 00:11 | #27693 | Link | |
FWIW there'll soon be a working (open source) implementation of SuperRes (with or without NEDI) in MPDN. It's still a bit experimental though. I still need to try out all the things that were impossible to achieve using only shaders, but have become possible with MPDN's more flexible system. |
1st December 2014, 00:27 | #27695 | Link |
No sorry, almost everything in the menu is greyed out, including those kind of options.
1st December 2014, 00:30 | #27696 | Link | |
So if I understand you correctly, just push chroma doubling as far as it goes, then put "the rest" into chroma upscaling (something like Jinc)?
1st December 2014, 00:37 | #27697 | Link |
Mainly the fact that I couldn't save any intermediate results. I had to somehow store the current image, the original image, and the difference between the current and original image, simultaneously. I could just barely manage this by abusing the alpha channel, but I could save at most 2 channels of the original, it didn't improve the legibility of the code and also limited the kind of processing I could do. For the chroma version of SuperRes it also didn't help that I couldn't make use of MadVR's chroma conversion. I could either disable it entirely or try to reverse it. In both cases I essentially needed to reverse engineer MadVR's chroma processing.
That said not even I am entirely sure why but for some reason the adaptation I made for MPDN seems to beat the (unpublished) experimental version of SuperRes that I had developed. Maybe because I can save more information of the original image, or because it sped up enough that I could use 16 bit processing. Oh and the fact that I could reuse MPDN's scaling algorithms also helped. Although in the end the shader version couldn't handle anything more complicated than bilinear anyway because I had to do everything in 1 pass (nowhere to store the intermediate result). Last edited by Shiandow; 1st December 2014 at 00:44. |
1st December 2014, 09:12 | #27699 | Link | |
1st December 2014, 13:34 | #27700 | Link |
Yes luma doubling, of course. Thanks guys.
