Old 19th September 2019, 23:44   #28781  |  Link
jdobbs
Originally Posted by zamengo View Post
I found another bug / mistake.
When import MKV HEVC 2160p, BD Rebuilder recognize as a HEVC 1080p.
After encode and UHD Adjust has done, this keep HEVC 1080p, but the file is 2160p, only the disc structure has this info.
I've imported multiple 2160p sources and haven't experienced what you describe. Are you sure you are letting it complete? When TSMUXER creates the structure it marks it as 1080p (because it doesn't support 2160p directly) -- but BD-RB corrects that after the TSMUXER session is completed.
Website: www.jdobbs.net
Old 20th September 2019, 02:00   #28782  |  Link
zamengo
yep, after encode this keep with 1080p info, when open the encoded disc in bdrebuilder.
Another stranger things that happened, but with a legit 1080p, the CPU use is around 20%, this is a bug ?
I already see this low cpu use in the past, but i don't know how I fix this
zamengo is offline   Reply With Quote
Old 20th September 2019, 12:26   #28783  |  Link
jdobbs
That's very unusual with newer versions of X264... but trying looking up MULTIPROCESS in HIDDENOPTS.txt.
Old 20th September 2019, 20:02   #28784  |  Link
Mike-uk
hi, anyone know how i can run avisynth+ and avisynth260 at the same time, i use avs2dvd with avisynth+ for its MT capabilities but when i install avisynth260 avs2dvd only sees 260 and not the MT version,
thanks
Mike
Mike-uk is offline   Reply With Quote
Old 20th September 2019, 23:14   #28785  |  Link
MrVideo
MrVideo's Avatar
I'm not sure you can because of the same-named DLL file that is installed.
Old 21st September 2019, 01:22   #28786  |  Link
LowDead
Elit Amans
thanks
Mike
Not really the right thread for this, but check out Universal Avisynth Installer
I think its very useful.
//LD
LowDead is offline   Reply With Quote
Old 22nd September 2019, 20:29   #28787  |  Link
jdobbs
BD Rebuilder v0.60.25
I have updated the first post of this thread with a link to the most recent version of BD-RB (v0.60.25). Changes for this release:
- Corrected an error in which BD-RB was using
  X264 (incorrectly) to reencode UHD sources
  when CRF mode was selected, causing rebuild
  to fail.
- Added code to better adjust predicted sizing
  for sources that use audio bitrates that are
  poorly sized due to muxing overhead.  This
  helps prevent oversizing that causes output
  to exceed targets and not fit on media.
- Fixed a bug in which some odd imports may
  not reflect necessary resizing in the MPLS
  file of the pseudo-BD structure.
- Fixed an error in which FORCE_STEREO_RATE
  hidden option was used in prediction calcs
  even in multichannel output, causing over-
  sizing and target miss.
- Fixed a bug that causes "ExtractAudioSubs()
  00009 2904" error when working with VC1
  sources.
- Added code to adjust for non-standard frame
  rates on imported files.
- Corrected "UHD_Correct_M2TS() 00005  8100"
  error that could occur during muxing of
  UHD sources.
- Fixed an issue in which imported UHD video
  could be flagged incorrectly as 1080p in
  the CLPI file.
- Other minor corrections and cosmetic fixes.
Old 23rd September 2019, 10:23   #28788  |  Link
Sharc
This seems to have solved the problem which I reported here. Thank you
Would the (automatic) rotation of .mp4 sources shot in portrait orientation be something for a future release?
Old 23rd September 2019, 12:18   #28789  |  Link
jdobbs
I'll look at it and see how hard it would be to do. Since most portrait videos are meant to stay that way, though, wouldn't it make more sense to frame them into a landscape backdrop but keep them displayed as portrait?
Old 23rd September 2019, 13:08   #28790  |  Link
Sharc
Exactly.
Currently the encoded picture is displayed as 1920x1080 landscape, 90 degrees rotated. MediaInfo reports the rotation of the original .mp4 source as 90 degrees. As I understand it, the 1920x1080 picture should be rotated back by 90 degrees (1080x1920), then resized to 608x1080 and finally pillarboxed to 1920x1080 for blu-ray compliance.
Perhaps there is a simpler method?
Old 24th September 2019, 01:25   #28791  |  Link
zamengo
I got a new error on Spider Man
[09/23/19] BD Rebuilder v0.60.23
[06:25:23] Source: SPIDER_MAN_FAR_FROM_HOME
- Input BD size: 71,98 GB
- Approximate total content: [02:34:25.963]
- Target BD size: 22,95 GB
- Windows Version: 6.2 [9200]
- Auto Quality: Very Good (Very Fast), ABR
- Decoding/Frame serving: FFMPEG
- Audio Settings: AC3=0 DTS=0 HD=0 Kbs=640
[06:25:23] PHASE ONE, Encoding
- [06:25:23] Processing: VID_00001 (1 of 4)
- [06:25:23] Extracting A/V streams [VID_00001]
- [06:28:47] Reencoding video [VID_00001]
- Source Video: HEVC, 3840x2160
- Rate/Length: 23,976fps, 186.144 frames
- Bitrate: 15.931 Kbs
- [06:28:47] Reencoding: VID_00001, Pass 1 of 1
- [20:10:33] Video Encode complete
- [20:10:33] Processing audio tracks
- Track 4353 (eng): Keeping original audio
- Track 4360 (por): Keeping original audio
- [20:10:33] Multiplexing M2TS
- [20:11:45] UHD_Correct_M2TS() 00005 8100
[21:22:24]PHASE ONE aborted by user request
Old 24th September 2019, 03:22   #28792  |  Link
lithiumus
Try the new version... this error should be fixed. I'm also testing with another release.
lithiumus is offline   Reply With Quote
Old 24th September 2019, 06:05   #28793  |  Link
prologic
I use bdrebuilder these days , to take out unwanted streams , I have been testing the new UHD versions , in its beta stages ..the latest one BD Rebuilder v0.60.23 worked fine on my test , were others failed ..
I picked a movie at random ..Pirates of the carribean - dead mans tales .. took all the unwanted audios, and subtitles out , and it worked fine .. my next test will be blancing out extras .Good work !!!
I also use it very regulary on normal bluray ..
prologic is offline   Reply With Quote
Old 24th September 2019, 16:18   #28794  |  Link
Michi
The UHD mpls Bug isn't fixed with the new version. All reauthored UHD discs are some minute shorter than the original disc.
Michi is offline   Reply With Quote
Old 27th September 2019, 13:15   #28795  |  Link
jdobbs
Can you give me a better explanation of what you are reporting? It isn't making sense to me.
Is is a full backup? Movie-Only? I haven't seen anything like what you are describing in my backups.
Old 27th September 2019, 16:50   #28796  |  Link
Michi
The bug is on all full backups. The m2ts file has the regular length, but the mpls-file is shorter.
https://forum.doom9.org/showthread.p...47#post1882347
This bug is on all full backups. Since I found this bug, I stopped all testing.
Old 27th September 2019, 17:05   #28797  |  Link
jdobbs
That's the part that throws me. The original MPLS is used in a full backup. The only MPLS changes would be if the encode involved resolution change or if it was reencoded to a different format (like VC-1 to AVC). The chapter information, etc, is never changed. I'll go back through the code to make sure... but I'm pretty confident that's the case.
Also, no one else is reporting this issue. I think if the end of the movie was missing people would notice/report it???
A movie-only backup would be different. BD-RB generates the MPLS from scratch in that case.
Are you doing any external editing or modifications?
Old 27th September 2019, 17:43   #28798  |  Link
Michi
I made over twenty UHD full backups and all backups have this bug.
Old 27th September 2019, 18:15   #28799  |  Link
jdobbs
You never answered my question.
Are you doing any external editing or modifications? Are you involving any software at all beyond BD Rebuilder?
Have you looked at the original discs in the same way (by looking at the MPLS time and the M2TS time)?
[Edit] I'm also not sure you should trust what TSMUXER reports when it opens an MPLS. I tried a disc with a 2 (or so) hour movie that are reported as 16 hours long -- and has a filename glitch in the reporting. I looked at another where there is a discrepancy of a minute between the time of the M2TS and the MPLS. Both of those are original discs, not processed ones! That's on the first two discs I opened... it wouldn't surprise me if they all show different times.
[Edit again] Yeah. It has to be the reporting. I just tried a third disc and the M2TS report says it is a minute longer than the MPLS also. Again this was an original disc, not one processed by BD-RB. My guess is TSMUXER is just guessing at the times or giving an estimate when it reports.
[Edit] ...and a fourth. So far the MPLS and M2TS lengths haven't matched on a single disc I've tried.
Old 27th September 2019, 18:47   #28800  |  Link
Michi
I'm not doing any external editing or modifications.
Here the mpls-file from the main film. The first is the reauthored BD-Rebuilder and the second is the original file.
My Sony Player stops the film at the end of the reauthored mpls-file.
