Old 20th September 2018, 05:21   #6461  |  Link
hello_hello
Does videoh = neuron2?
Old 20th September 2018, 06:33   #6462  |  Link
Morku
@videoh
Thank you for your clarification, it makes sense. So thats why MeGUI changes the value to 1? I still wonder why it did not happen, when I updated to 159, but it seems to be an hiccup of my PC. With value 1, everything works fine and as expected.
@hello_hello
Who knows, but if so, he normally would refuse any support to me.
Morku is offline   Reply With Quote
Old 20th September 2018, 07:38   #6463  |  Link
LigH
LigH's Avatar
*Is
He already confirmed that.
New German Gleitz board
Old 21st September 2018, 18:51   #6464  |  Link
Morku
Today, it happen again that MeGUI changed the ini to Full_Path_In_Files=0 when I started Indexing.
I made absolutly sure, that Full_Path_In_Files was set to 1, so I think there is something in the MeGUI behaviour.
Is there any trigger in MeGUI, why it sometimes is changed to 1 and in the next time to 0?
Since years I do it the same way to let create dgi the same path as the file input (in this case mpls) and the place of my avs file is another than of the source.
I edited the dgi to absolute path, so I didn't need to Index again.
Old 21st September 2018, 20:03   #6465  |  Link
Zathor
MeGUI does set it always to 1. There is not a single line of code where it will be set to 0. For each start of the index process it will be checked and corrected if necessary. Do you have any idea when it does change?
Zathor is offline   Reply With Quote
Old 21st September 2018, 20:40   #6466  |  Link
videoh
DGIndexNV creates new INI files with full paths enabled, so even deleting the INI file won't cause this.
There have been changes to the INI file format in the past, so maybe it is worth checking that MeGUI is up-to-date with the current format.
Old 21st September 2018, 20:58   #6467  |  Link
Zathor
Thanks, MeGUI has to create a new dgindexnv.ini if it does not exist as not all parameters are by default correct (for use with MeGUI).
This is what currently will be written:
                    sb.AppendLine("Version=");
                    sb.AppendLine("Window_Position=0,0");
                    sb.AppendLine("Info_Window_Position=0,0");
                    sb.AppendLine("Process_Priority=2");
                    sb.AppendLine("Playback_Speed=3");
                    sb.AppendLine("AVS_Template_Folder=");
                    sb.AppendLine("AVS_Template_File=template.avs");
                    sb.AppendLine("AVS_Template_File_Index=0");
                    sb.AppendLine("AVS_Enable_Template=1");
                    sb.AppendLine("AVS_Overwrite=0");
                    sb.AppendLine("Full_Path_In_Files=1");
                    sb.AppendLine("MRUList[0]=");
                    sb.AppendLine("MRUList[1]=");
                    sb.AppendLine("MRUList[2]=");
                    sb.AppendLine("MRUList[3]=");
                    sb.AppendLine("Enable_Info_Log=1");
                    sb.AppendLine("Loop_Playback=0");
                    sb.AppendLine("AVC_Extension=264");
                    sb.AppendLine("MPG_Extension=m2v");
                    sb.AppendLine("VC1_Extension=vc1");
                    sb.AppendLine("HEVC_Extension=265");
                    sb.AppendLine("Deinterlace=0");
                    sb.AppendLine("UsePF=0");
                    sb.AppendLine("AlwaysCrop=1");
                    sb.AppendLine("UseD3D=0");
                    sb.AppendLine("Snapped=0");
                    sb.AppendLine("ResponseOnAudioMismatch=1");
                    sb.AppendLine("Enable_Audio_Demux=1");
                    sb.AppendLine("CUDA_Device=255");
                    sb.AppendLine("Decode_Modes=0,0,0,0");
                    sb.AppendLine("Full_Info=1");
                    sb.AppendLine("Bare_Demux=0");
                    sb.AppendLine("Disable_Encrypted_Audio_Warning=0");
                    sb.AppendLine("Fine_Cropping=0");
                    sb.AppendLine("Force_Zoom=0");
                    sb.AppendLine("StrictAVC=0");
After DGIndexNV closes there is a new line at the end and some other line changes but Full_Path_In_Files=1 stays.
So back to Morku - do you have a way to reproduce that?
Old 21st September 2018, 22:13   #6468  |  Link
videoh
There is one additional line at the end for the latest version:
StrictAVC=1
PGSForcedOnly=0
That shouldn't cause a problem.
Old 21st September 2018, 22:56   #6469  |  Link
Morku
What I did this time is:
I started DGIndexNV GUI to check settings, if Full paths is checked. I double checked the ini file, it was set to 1.
Good, I thought, lets start Indexing with MeGUI and AVS Script Creator, loaded my mpls, started Indexing with DGIndexNV -> again I got the no input error.
I checked the ini file and it was set to 0.
Than, I started to Index the next mpls, this time, no issue and the value weas set to 1.
I will need some time to figure out, if I can find a way which requirements are necessary to be able to always reproduce the problem.
Maybe one of the recent changes in MeGUI Build at the same time when DGIndexNV 159 was uploaded? Thats why I accidentally reported that version with some issue.
The thing is: I didn't start the DGIndexNV GUI the last months and didn't also touch the ini. I didn't even know about the full path option before when I reported it. I always index with MeGUI.
idea: why not just add relative and absolute path into the dgi file as if/else?
Old 21st September 2018, 23:25   #6470  |  Link
videoh
I don't understand what you mean.
Old 22nd September 2018, 07:53   #6471  |  Link
Morku
To add in dgi:
..\STREAM\00005.m2ts 17500932096
..\STREAM\00000.m2ts 18432
and
D:\Temp\BluRay\CABINFEVER2\BDMV\STREAM\00005.m2ts 17500932096
D:\Temp\BluRay\CABINFEVER2\BDMV\STREAM\00000.m2ts 18432
if one path is not true, use the other. And with the ini you only control which path is primary wanted.
Old 22nd September 2018, 19:20   #6472  |  Link
Zathor
2882 [OneClick]             fixed only using at maximum 2 audio/subtitle tracks in batch mode (regression of 2861). bug #927
2881 [HD Streams Extractor] force "-keepDialnorm" if required for a E-AC3 tracks
Old 23rd September 2018, 16:06   #6473  |  Link
Zathor
2884 [Worker]               changed worker handling
                            - in "workers\settings" worker rule sets can be specified
                              based on those rules it is determined how many jobs of which type are allowed to run in parallel
                              also on that page the maximum number of workers can be set (default: 2)
                            - temporary workers ignore all restrictions
                            - removed several obsolete worker windows and options
2883 [IFOParser]            improved subtitle detection. bug #925
Old 26th September 2018, 11:17   #6474  |  Link
Zetti
x264 r2935 is released.
Zetti is offline   Reply With Quote
Old 26th September 2018, 21:01   #6475  |  Link
Zetti
MKVToolNix v27.0.0 is released.
Old 29th September 2018, 15:36   #6476  |  Link
Zathor
Thanks, Zetti! Both have been updated.
2886 [Jobs]                 fixed abort of suspended jobs (regression of 2818)
2885 [Preset Exporter]      fixed overwrite of output files
Old 29th September 2018, 16:58   #6477  |  Link
Zetti
Thanks
Old 30th September 2018, 07:44   #6478  |  Link
wthreex
E-AC-3 @ 1280 kb/s
is this new ? How do i add this codec ?
wthreex is offline   Reply With Quote
Old 30th September 2018, 08:48   #6479  |  Link
Zathor
Sorry, I do not get it. Where do you have the issue?
Old 30th September 2018, 14:27   #6480  |  Link
wthreex
not issue, just saw that detail on some encodes. cuze my AC3 codec only support 640Kbps at maximum .
