Old 19th February 2018, 20:18   #6021  |  Link
Barough
Barough's Avatar
Good to hear u found the issue.
Will there be an update/fix or you gonna leave it as it is?
Old 19th February 2018, 21:34   #6022  |  Link
Zathor
It will be changed for sure. I assume you get this because of the multi-angle disc.
Zathor is offline   Reply With Quote
Old 19th February 2018, 21:40   #6023  |  Link
Barough
Barough's Avatar
As u said.... It was an multi-angle disc.
Old 19th February 2018, 22:20   #6024  |  Link
Zathor
2826 should hopefully fix it (I could not reproduce it with my test discs)
Old 19th February 2018, 22:25   #6025  |  Link
Barough
Barough's Avatar
Thnx for the quick fix.
I'll try and test it tomorrow if i get some time over or so will i do it on Wednesday.
Sent from my SM-G935F via Tapatalk
Old 22nd February 2018, 13:12   #6026  |  Link
Barough
Barough's Avatar
@Zathor - Ur fix works fine.
x265 v2.7 is released.
x265 v2.7+1-2aa737a99f51 (GCC 7.3.0, 32 & 64-bit 8/10/12bit Multilib Windows Binaries)
https://bitbucket.org/multicoreware/x265/commits/all
Old 24th February 2018, 18:41   #6027  |  Link
Barough
Barough's Avatar
MKVToolNix v21.0.0.0 is released
Old 25th February 2018, 00:29   #6028  |  Link
LeMoi
What are the new conditions for using DSS ? I tried to open an m2ts file, an mkv and an mp4 in the AVS script creator, it was not available... Option is checked in the settings.
LeMoi is offline   Reply With Quote
Old 25th February 2018, 20:11   #6029  |  Link
LigH
LigH's Avatar
MeGUI 2826, DirectShowSource enabled in settings: It's available for me, testing with one MP4 file. Maybe MeGUI detected that your system is unable to build an automatic DS filter graph due to missing filters? Do you possibly have a log file of your attempt to open such a file? Maybe there are details logged why it failed, and DirectShowSource was withheld?
New German Gleitz board
Old 26th February 2018, 22:46   #6030  |  Link
LeMoi
Sorry I don't know what happened, I just closed and opened MeGUI and it worked again... It looks some filter was busy or not recognized, but when I restarted MeGUI I had no problem using DSS
Old 3rd March 2018, 12:34   #6031  |  Link
legal
I have windows 10 Pro Workstations (1709) and megui refuses to start it gives allways error (tested with x86 and x64).
I have MeGUI 2826 DEVELOPEMENT UPDATE SERVER (tested with stable versions and gives allways the same error).
legal is offline   Reply With Quote
Old 3rd March 2018, 12:38   #6032  |  Link
Zathor
Please post more details e.g. if something is written to the log the log and/or a screenshot of the error.
Old 3rd March 2018, 17:20   #6033  |  Link
legal
After double click on megui it shows this error on desktop:
Windows event's (it's in Portuguese):
Aplicação: MeGUI.exe
Versão do Framework: v4.0.30319
Descrição: O processo foi terminado devido a uma excepção não processada.
Informações da Excepção: System.NullReferenceException
em MeGUI.OSInfo.GetOSName()
em MeGUI.MainForm.getVersionInformation()
em MeGUI.MainForm..ctor()
em MeGUI.MainForm.Main(System.String[])
Nome da aplicação com falha: MeGUI.exe, versão: 1.0.2826.0, carimbo de data/hora: 0x5a8b3f4e
Nome do módulo com falha: unknown, versão: 0.0.0.0, carimbo de data/hora: 0x00000000
Código de exceção: 0xc0000005
Desvio de falha: 0x00007fff0b300e9f
ID do processo com falha: 0x296c
Hora de início da aplicação com falha: 0x01d3b30a118e58d0
Caminho da aplicação com falha: C:\Portable\MeGUIx64\MeGUI.exe
Caminho do módulo com falha: unknown
ID do Relatório: 4a4a6a6c-85d9-4ac6-920c-351de3378f7e
Nome completo do pacote com falha:
ID da aplicação relativa ao pacote com falha:
Old 4th March 2018, 12:43   #6034  |  Link
Zathor
Please extract these files (choose x64 subfolder if your are using the 64bit one) and replace the existing ones. The error will still be there but it should show in which lines in code it does not work. I will then provide a fix.
http://megui.org/megui_debug.7z
Old 4th March 2018, 17:26   #6035  |  Link
legal
Hi Zathor, Windows 10 Pro for Workstations file with report (cloud: Mega):
https://mega.nz/#!KVoxABBR!HyxZjEisF...0kII0v4Wuq6YBo
MeGUI LogFile (cloud: Mega):
https://mega.nz/#!XYQxALqQ!OcxNeQhGw...rrTAJlvSAQuEnE
Windows Event's:
Error 1026
Error 1000
Desvio de falha: 0x00007fff01780e9f
ID do processo com falha: 0x1ac4
Hora de início da aplicação com falha: 0x01d3b3d475d9379e
ID do Relatório: 5c2e15cf-0002-442d-96d5-bd8c1b835524
Zathor, if you need more log's or information just tell me and i will give ASAP.
Windows 10 for Workstations is a new version from microsoft:
https://blogs.windows.com/business/2...-workstations/
Old 4th March 2018, 19:11   #6036  |  Link
Zathor
Thanks, 2827 is online which should fix the issue.
Old 4th March 2018, 20:33   #6037  |  Link
Zetti
What about updates in post #6026 and #6027 ??
Zetti is offline   Reply With Quote
Old 4th March 2018, 21:04   #6038  |  Link
legal
This new version (2827) works with Windows 10 Pro Workstations but not with the others windows (Tested in one virtual machine with windows 7 x64).
Edit: it's working now.
Old 4th March 2018, 21:09   #6039  |  Link
Zathor
Please post the log
EDIT: Ok, seems to work :-)
Old 4th March 2018, 21:11   #6040  |  Link
Zathor
Thanks for the reminder
Thank you very much, packages updated
