Old 19th September 2015, 17:08   #41  |  Link
Boulder
Pig on the wing
Boulder's Avatar
While you're designing the native VS build, I have a question regarding Vapoursynth's multithreading and DGSource. Is it generally safe to allow multithreading for DGSource or is it better to use core = vs.get_core(threads=1) before it and core = vs.get_core(threads=-1) afterwards? I assume it's mostly up to the GPU driver but there's no general opinion on this matter.
Old 19th September 2015, 17:17   #42  |  Link
Myrsloik
Professional Code Monkey
Myrsloik's Avatar
This isn't avisynth. All filters have to specify how they want to be threaded. Only the first get_core() call matters, all arguments are ignored for later calls (you should never need to use any of the arguments apart from when debugging or developing).
Myrsloik is offline   Reply With Quote
Old 19th September 2015, 18:05   #43  |  Link
Boulder
Pig on the wing
Boulder's Avatar
What about in the case of an Avisynth plugin loaded in Vapoursynth?
Old 19th September 2015, 18:18   #44  |  Link
Myrsloik
Myrsloik's Avatar
It's still not avisynth.
Old 19th September 2015, 20:46   #45  |  Link
videoh
Useful n00b
I don't know enough about Vapoursynth yet to comment with respect to DGSource(). I'll let you know what I discover about it.
Old 19th September 2015, 22:38   #46  |  Link
videoh
Useful n00b
Things are looking real good, guys and gals. I am playing video with random access from a .vpy script with 64-bit DGDecodeNV.dll.
The only stuff left is to change the bitblt's for pulldown to Vapoursynth ones (AVSenv->BitBlt is obviously not available) and to implement the debug overlay. Then it's done!
Old 19th September 2015, 22:45   #47  |  Link
Reel.Deel
Awesome!
Old 19th September 2015, 22:48   #48  |  Link
MeteorRain
結城有紀
OMG that's so awesome!
Projects
x265 - Yuuki-Asuna-mod Download / GitHub
TS - ADTS AAC Splitter | LATM AAC Splitter | BS4K-ASS
Neo AviSynth+ filters - F3KDB | FFT3D | DFTTest | MiniDeen | Temporal Median
MeteorRain is offline   Reply With Quote
Old 20th September 2015, 02:04   #49  |  Link
videoh
Useful n00b
Here is some tasty DGDecodeNV cooked Vapoursynth-style. Your test results will be appreciated. The standard DGIndexNV should be used for indexing. Note that hinting is gone for Vapoursynth as it will be converted to use Vapoursynth per-frame properties.
http://rationalqm.us/misc/DGDecodeNV_Vapoursynth.zip
This is a dual-function DLL for both Avisynth and Vapoursynth. Sample script:
import vapoursynth as vs
core = vs.get_core()
core.std.LoadPlugin('dgdecodenv_vs64.dll')
ret = core.dgdecodenv.DGSource('alba.dgi',debug=1)
ret.set_output()
Old 20th September 2015, 05:51   #50  |  Link
MeteorRain
結城有紀
Did a quick test to load a random ts file and a bluray file and it works like a charm. MPEG2 and H.264 source.
Projects
Old 20th September 2015, 13:19   #51  |  Link
videoh
Useful n00b
Sweet. Thank you for the testing.
Old 20th September 2015, 15:45   #52  |  Link
sl1pkn07
Pajas Mentales...
any plans to get plugin for non-windows systems?
sl1pkn07 is offline   Reply With Quote
Old 20th September 2015, 16:06   #53  |  Link
videoh
Useful n00b
Currently, no, but it's not ruled out in the future.
Old 20th September 2015, 18:00   #54  |  Link
Boulder
Pig on the wing
Boulder's Avatar
Thanks for the test build Unfortunately it might take me a while to get to test it so you'll probably end up releasing a final build before that.. Nevertheless, great job once again!
Old 22nd September 2015, 16:11   #55  |  Link
videoh
Useful n00b
I did in fact release it as DGDecNV 2050.
Old 3rd October 2015, 10:04   #56  |  Link
Boulder
Pig on the wing
Boulder's Avatar
I didn't want to open a new thread so I'm posting this here since it seems to concern DGSource.
With a simple script,
clp = core.dgdecodenv.DGSource('L:\ALL_ABOUT_EVE\eve.dgi')
clp.set_output()
vspipe throws an error "Specified filter framerate must be normalized" and gives the Windows crash report window. It points to ucrtbase.DLL.
I checked on a different source I happened to have on my computer, and it doesn't have any problems.
I'm using Vapoursynth R28RC1 with Python 3.5 and the latest slipstream of DGDecNV. Can you verify if this is more likely related to VS itself or DGDecNV?
Old 3rd October 2015, 10:43   #57  |  Link
Myrsloik
Myrsloik's Avatar
I added an extra check in r28 to make sure a certain framerate only has one representation. It makes checking for the same framerate much easier. Use vs_normalizeRational on the framerate field and it will work.
This change was made to fix things like 60000/2002 not being considered equal to 30000/1001.
Old 3rd October 2015, 11:05   #58  |  Link
foxyshadis
ангел смерти
foxyshadis's Avatar
So we need to include VSHelper.h and call vs_normalizeRational() anytime the framerate is set? Seems odd to error out and core dump on that, when setVideoInfo calls it anyway.
Old 3rd October 2015, 12:15   #59  |  Link
videoh
Useful n00b
It's more than odd. Vapoursynth now breaks working filters "to make things easier". It's a terrible precedent that evolution of Vapoursynth can break filters.
If Vapoursynth detects a "non-normalized framerate" (whatever that may be, I have seen no formal explanation) then why can't Vapoursynth normalize it internally if it needs to do so? Instead of having the code once, you require every source filter writer to do it? And for me it's not just the source filter; the indexer component will need to be changed as well (I'm not going to report one frame rate through the GUI and index file and then give a different one to Vapoursynth). Vapoursynth has code to detect a non-normalized rate and throw an error, but not to normalize it? Vapoursynth can't call vs_normalizeRational() itself on the incoming frame rate? That is bizarre.
And what if a stream actually carries a non-normalized framerate? The source filter has to lie about it? I'm not just talking about multiples but also small deviations from exact rates.
Speaking for myself, I have no intention of modifying DGDecNV this way, so if things stand then DGDecNV will be unusable in Vapoursynth (and I'll have a bad taste in my mouth about spending my time supporting Vapousynth). At least I'll save some time by not having to do it again for DGDecIM.
Old 3rd October 2015, 13:24   #60  |  Link
jackoneill
unsigned int
jackoneill's Avatar
Oh, come on. It's not the end of the world.
This isn't about small deviations from "exact" rates. You simply need to pick the smallest pair of numbers that represent your frame rate, e.g. 24000/1001 rather than 120000/5005. That's all there is to it.
It's one additional line in the VapourSynth filter, and maybe 10 in the indexer, if you copy vs_normalizeRational..
Buy me a "coffee" and/or hire me to write code!
jackoneill is offline   Reply With Quote
