1st September 2009, 21:29 | #9481 | Link | |
I don't say that it's not caused by minute refreshrate difference between reported and actual, as you say, but it seems to be a very complex cause compared with the simpler one of low gpu power... |
1st September 2009, 22:17 | #9482 | Link | |
It seems like it might be a VSync issue, and I've tried to find one good combination that works out of all aspects, but I just can't do it. Here's what I have so far: VMR9 (renderless), VMR9 mixer mode enabled: No tearing, but stuttering. VMR9 (renderless), VMR9 mixer mode disabled: No tearing, no stuttering, but then the hardware de-interlacing doesn't work. VMR9 (renderless), VMR9 mixer mode enabled, Alternative VSync enabled: No stuttering, but tearing instead. VMR9 (renderless), VMR9 mixer mode enabled, D3D Fullscreen w/ GUI Support: No tearing, but stuttering. VMR9 (renderless), VMR9 mixer mode enabled, D3D Fullscreen: No tearing, no stuttering, everything works perfectly. So essentially the D3D Fullscreen mode with no GUI is the only way I can properly play 1080i files, which is a shame as that mode is seriously annoying. |
1st September 2009, 23:05 | #9483 | Link | |
MPC-HC 2.1.7.2 |
2nd September 2009, 01:57 | #9484 | Link | |
PS When I first tried Beliyaal's version, the first thing suggested (by Testuo55 IIRC) was to not use bicubic, and actually the direction of resizing is such that bilinear is not a problem, so I switched permanently to that. PPS I have nothing against Beliyaal and acknowledged that he has fixed a number of things. My only problem with him is that he has vanished, with still some remaining issues in the code.
s/w: Vista Home Basic 32bit (no Aero), MPC-HC, EVR Custom Presenter, CoreAVC Pro, ffdshow, SPDIFer h/w: Antec 2480 case, Gigabyte GA-MA69GM-S2H, 4200+, 2.5gb+512mb, ATI x1250 IGP, MS MCE remote |
2nd September 2009, 04:03 | #9486 | Link |
Hardware Aspirin
is there a subtitle editor or subtitle resync function in MPC HC ?
Stream video on web in your quality |
2nd September 2009, 06:33 | #9487 | Link | ||
MPC-HC Project Manager
But we need the screenshot to be able to take any further steps. Quote:
MPC-HC, an open source project everyone can improve. Want to help? Test Nightly Builds, submit patches or bugs and chat on IRC Last edited by tetsuo55; 2nd September 2009 at 06:35. |
2nd September 2009, 07:24 | #9488 | Link | |
C.U. NanoBot |
2nd September 2009, 08:27 | #9491 | Link | |
Intel UHD Graphics 750; Win 10 22H2 |
2nd September 2009, 14:15 | #9492 | Link | |
I wonder what the difference is. I have a nvidia 7600GT. haali media splitter installed (don't know if that matters.) The OSD does not show with any type of media. |
2nd September 2009, 14:33 | #9493 | Link |
MPC-HC in MS Visual Studio 2008
Hallo and thanks for great player.
I wonder if is possible to use MPC-HC in M$ Visual Studio 2008 similarly like windows media player or for example VLC via COM components. Im sorry if this subject was discussed earlier, but I didn't find it. |
2nd September 2009, 15:42 | #9494 | Link |
Issues with Catalyst > 9.5 and Mobility HD3650 DXVA
Hi, as I reported before, I have artifacts with some video (with external subtitle) and I tried various program settings (as suggested here: http://nunnally.ahmygoddess.net/watc...os-using-dxva/) but with no result...then I wanted to see if it is a driver problem and it was: with Catalyst 9.4 (DNA) and Catalyst 9.5 there is no problem...so what is the thing that generates artifacts with newer driver???
I'm very confused... MPC-HC 1249 gold release tested |
2nd September 2009, 15:57 | #9495 | Link | |
I remember that, with my previous PC, I had some stuttering problems that were caused when I simply opened the WMP. After that, I had to re-install the SP2 of XP to solve the problem, because it reset WMP and everything worked fine again (I used Zoomplayer for my viewings). Currently, with my more powerfull cpu and graphics card, the problem disappeared. Maybe SP3 also helped a little, but in the end, I think the problem is related to living in the edge... ADude, don't you know someone that could borrow you a graphics card just for ruling that out? |
2nd September 2009, 19:22 | #9496 | Link | |
ATI x1250 is a newer more powerful videocard. It is rated to play Blu-Ray discs. I bought it brand new, as a recent product, after the release of MPC-HC. Previously, I had been playing 720p HD videos just fine with MPC-HC with an ATI mobile Radeon 7500, also with no tearing. Tearing has nothing to do with processor speed of any sort, and MPC-HC build 1043 has no tearing. Or is build 1043 now considered "old" ??
2nd September 2009, 19:35 | #9497 | Link | |
For example, if I play a video where the display rate cannot be a multiple of video fps, then: - Build 1043 does not tear - Later builds (with Beliyaal's sync code) tears - Gothsync tears - Gothsync with recent code for situations that are not a multiple ("Present at Nearest Vsync") does not tear. I am hoping that ar-jar can spare enough time to verify that build 1043 and earlier did have such code that was removed.
2nd September 2009, 19:40 | #9498 | Link | ||
2 years is sometimes less than the amount of time that a product is delayed by a minor series of bugs. It is also less than the amount of time this thread has been going: Quote:
2nd September 2009, 23:00 | #9499 | Link |
Guys, please stop this nonsense discussion about hardware. GPU performance is clearly NOT the issue. Tearing is all about timing and can even occur with the next generation uber-powerful cards.
MPC-HC 2.1.7.2 |
2nd September 2009, 23:07 | #9500 | Link |
@Casimir666
MPC Video Decoder doesn't fallback to libavcodec (Software Decoding) when playing x264 lossless bitstreams (G92/VP2) Result =
all my compares are riddles so please try to decipher them yourselves :) It is about Time Join the Revolution NOW before it is to Late ! http://forum.doom9.org/showthread.php?t=168004 |
