10th May 2003, 18:26 | #341 | Link |
@karl
OK, play around enough with all the options in the audience file: I don't understand exactly what the quality setting does when you are using vbrbitrate for encoding. How does that get into effect? The only time I am seeing it doing anything is by using qualityvbr for encoding. |
10th May 2003, 18:46 | #342 | Link |
@wing1: you are right, the Quality setting does not affect anything in vbrBitrate mode.
This information is provided "AS IS" with no warranties, grants no rights, and reflects my personal opinion. |
11th May 2003, 16:35 | #344 | Link |
retired developer
Maybe with Quality-based encodes...
Detritus Software |
11th May 2003, 16:47 | #345 | Link |
RV9 compressibility test
AutoRV9 1.3b1 has a compressibility test.
The following requires an understanding of how the compressbility test works: The compressibility test requires a number of bits corresponding to "max quality". The problem is that the best possible quality with XviD (QP=2) is very different from the best quality in RV9. In RV9 a higher maximum fidelity is possible, but this also requires more bits, so if a max quality if vbrQuality=100 was used as the comp test reference, the compressibility test number would be way too small, like 10% or less. So the challenge was to find a suitable reference quality for RV9. I ran some experiments using the compressibility calculations, and found that vbrQuality=83 with no limit on max bitrate, is a good starting point. However, I have not tried AutoRV9 1.3b1 on enough samples to see how accurate it is. It is, however, a nice first step, so do give it a try and provide feedback as appropriate. Thanks!
This information is provided "AS IS" with no warranties, grants no rights, and reflects my personal opinion. Last edited by karl_lillevold; 11th May 2003 at 16:50. |
12th May 2003, 16:51 | #347 | Link |
it is working right now, monday morning, US Pacific time.
If you still have trouble, please send email to feedback@helixcommunity.org, and include your user id. Thanks!
21st May 2003, 01:03 | #351 | Link |
no, the new High Quality mode (with high complexity too though) will be included in the next milestone build.
21st May 2003, 01:54 | #352 | Link |
retired developer
Will it be backward-compatible with decoders?
Detritus Software |
21st May 2003, 06:18 | #355 | Link |
no, unfortunately, it's not that easy. The most general solution is to use the GUI to create a job file, save it as jobfile.rpjf, then run the new command line producer with producer -j jobfile.rpjf. Before this you can edit the job file and add the options for the new high quality mode.
I have also added reg keys though, for convenient settings of these options without editing the job file. I think I will also provide instructions for how to plug the new encoder DLL into the old GUI producer, then at least the improved compression efficiency will be availble (with the reg key settings).
21st May 2003, 13:18 | #358 | Link |
! - User - !
i am so goddam lazy sometimes
yet, i found only something about the high complexity mode is this synonymous with high quality mode. Btw is this related to what xvid does with vhq? @Dark Cracker? I hope there will be a checkbox for this nice thingy. sorry, couldN#t resist
Keep your tone warm and your sigs decent! Last edited by kilg0r3; 21st May 2003 at 13:30. |
21st May 2003, 14:08 | #359 | Link |
Even though the custom codec option exists in the current milestone, it does not yet have the intended behavior, and the result is a slower encoder, without all the improvement. This will be included in the next Milestone, at which point I will also publish some details as to the differences between the different numbers above 65. I hope a setting will be included in AutoRV9, but it will also be available with a simple reg key, for backwards compatibility with the GUI Helix Producer and older versions of other tools.
21st May 2003, 16:15 | #360 | Link |
retired developer
As soon as the next milestone will be out, zadude will include in in RMFactory.
Detritus Software |
