Old 14th March 2013, 15:16   #2941  |  Link
magsoud
magsoud's Avatar
Originally Posted by LigH View Post
Manually: Add an instance of Tweak() with matching parameters to the generated script.
Please Explain more...
magsoud is offline
Old 14th March 2013, 15:29   #2942  |  Link
LigH
LigH's Avatar
While using the "AVS Script Creator" to import your video source, switch to the tab "Script", and type in there, where it is useful, a line with the Tweak or Levels or ColorYUV filter, whatever may suit your needs...
Or do you expect Zathor to add sliders to the preview window?
New German Gleitz board
LigH is offline
Old 14th March 2013, 15:46   #2943  |  Link
magsoud
magsoud's Avatar
@LigH
I did not understand this section.
magsoud is offline
Old 14th March 2013, 16:01   #2944  |  Link
LigH
LigH's Avatar
[–·····«¦¦»·····+] Brightness
[–·····«¦¦»·····+] Contrast
^ Sliders
But I doubt MeGUI needs that. Usually, the video is fine; if it looks wrong, your display may need a calibration, not the movie.
If the video is really wrong, then you may need more than sliders, like a colorimeter, a phase display, tools to measure the color shift before trying to fix it...
LigH is offline
Old 14th March 2013, 16:50   #2945  |  Link
magsoud
magsoud's Avatar
^ Sliders
I'm Sorry
I could not get it to run!
I'm not found Sliders!!!
magsoud is offline
Old 14th March 2013, 17:02   #2946  |  Link
LigH
LigH's Avatar
Because they are not implemented.
The question was:
Would you want any?
Do you expect Zathor to make them?
I would not be surprised if he did not want to make any.
LigH is offline
Old 14th March 2013, 17:15   #2947  |  Link
magsoud
magsoud's Avatar
The question was:
Would you want any?
Yes
LigH
magsoud is offline
Old 7th April 2013, 16:57   #2948  |  Link
AGKnotUser
No Chapters with the Manual MKV Muxer with MeGUI 2341
Even though I have selected a chapter file in the Manual MKV Muxer window there are no chapters in the output MKV file. In fact, I see "--no chapters" in the command line in the logs. Am I doing something wrong?
AGKnotUser is offline
Old 7th April 2013, 17:10   #2949  |  Link
simcut
am using the development update server and megui tells me to update from 2338 to 2341 but when I try restarting MeGUI it comes up with:-
"Couldn't run updater"
any ideas? is it just me?
Cheers.
simcut is offline
Old 7th April 2013, 17:46   #2950  |  Link
Zathor
I do not have this problem, sorry.
Zathor is offline
Old 7th April 2013, 18:10   #2951  |  Link
simcut
Hm, that's odd, I'll try a reinstall of MeGUI then I guess, see if it continues
simcut is offline
Old 8th April 2013, 18:42   #2952  |  Link
nekrovski
nekrovski's Avatar
One quick question.
When I'm in the process before encoding with megui, this question about color space YV12 or something always pops up and my answer is always yes.
There's a checkmark that says "dont show this dialog next time".
Now if I check that, will it automatically answer all future dialogs with what I chose last?
Or?
nekrovski is offline
Old 8th April 2013, 21:25   #2953  |  Link
Zathor
Yes, that's correct.
Zathor is offline
Old 9th April 2013, 16:24   #2954  |  Link
nekrovski
nekrovski's Avatar
Thank you for the answer.
Old 13th April 2013, 01:22   #2955  |  Link
AGKnotUser
Is there a way to change the Muxer settings of the MKV Muxer? I've checked the .xml files and have not found anything to change.
Old 15th April 2013, 09:55   #2956  |  Link
LigH
LigH's Avatar
Do you want to add multiplexing parameters to enhance compatibility to specific hardware players?
LigH is offline
Old 15th April 2013, 18:47   #2957  |  Link
Zathor
Sorry, forgot about your message. Please provide the chapter file.
Zathor is offline
Old 15th April 2013, 22:45   #2958  |  Link
AGKnotUser
No Problem. I must have done something wrong. I ran it again and the file had chapters. Thanks for getting back to me.
Old 16th April 2013, 15:49   #2959  |  Link
AGKnotUser
Actually a software players. TMT 6 is more fussy about the newest features of mkvmerge 6.1.0. So I'd like more control over the parameters.
Old 16th April 2013, 23:08   #2960  |  Link
Zathor
Sorry, currently not possible. Which command do you want to add?
Zathor is offline
