Old 27th February 2008, 00:26   #401  |  Link
jamos
Hey Now!
Originally Posted by Rectal Prolapse View Post
New hdsup2bdn:
http://www.sendspace.com/file/1oij4n
Allowed options:
  --help                produce help message
  --version             print version number
  --original            output PNG images in the original size (suitable for
                        OCR)
  --fullpng             output 1920x1080 PNG images [DEFAULT]
  --nobdnfixtimes       do not divide BDN times by 1.001 (BDN output only)
  --bdnfixtimes         divide BDN times by 1.001 (BDN output only) [DEFAULT]
  --srtfixtimes         divide SRT times by 1.001 (SRT output only)
  --nosrtfixtimes       divide SRT times by 1.001 (SRT output only) [DEFAULT]
  --framerate arg       frame rate [DEFAULT: 29.97]
  --input-file arg      input file
  --srt                 output SRT file
  --xml                 output Scenarist HDMV BDN file
  --forcedsubs          make all subtitles forced (BDN output only)
  --dropframes          flag all subtitle times as drop frames (BDN output
                        only)
  --nopng               don't generate any PNGs
  --blackbackground     always make the transparent background black (index 0)
                        [RGB 0,0,0]
  --blackemphasis       make the HD-DVD emphasis pixels (index 2 and 3) black
  --enhancecontrast     make all pixels with Y < 127 black, and pixels with Y
                        >= 128 white (easier to OCR). Also forces background to
                        black.
Example usage:
C:\My Downloads\Subtitles\Mr. Bean's Holiday>C:\Projects\Blu-ray\hdsup2bdn\release\hdsup2bdn.exe --xml --enhancecontrast FEATURE_1_MERGED.Subpicture.14.sup
XML (BDN) output selected
Force all pixels to black except the main pattern
framerate defaults to 29.97
Input files are: FEATURE_1_MERGED.Subpicture.14.sup
hdsup2bdn version 1.04
--enhancecontrast forces all colors with Y < 127 to be black, and all other colors to be white. This is a cheap hack but hopefully works for most people!
looks good how would i get 1280x720 subpictures from a 1080p source?
jamos is offline   Reply With Quote
Old 27th February 2008, 00:37   #402  |  Link
jamos
Hey Now!
i am getting a error using your program rectal-> No SP found in header. with the same file supread can read it fine.
Old 27th February 2008, 18:24   #403  |  Link
Rectal Prolapse
jamos, hdsup2bdn only works on hd-dvd .sup files. It won't work on blu-ray .sups (yet - no ETA for that). The intent of hdsup2bdn is to create subtitles from HD-DVDs for authoring on Blu-ray disc.
I haven't tested on 1280x720p .sup files - it probably won't work!
Rectal Prolapse is offline   Reply With Quote
Old 27th February 2008, 19:41   #404  |  Link
Pelican9
Coder
Pelican9's Avatar
New version of SUPread (v0.51b)
Changes for v0.51
- New option: OCR export black and white only
- export 8 bit PNG (Scenarist compatible)
Change for v0.50
- New option: export png at 720p
You have to download the abc.png, because it's changed from PNG24 to PNG8 too.
I'm too tired to testing it accurately so any feedback is helpful.
Pelican9 is offline   Reply With Quote
Old 27th February 2008, 22:05   #405  |  Link
laserfan
Aging Video Hobbyist
Been using SUPread successfully on a few HD DVDs (thanks Pelican9) but have run into a problem. Has anyone here tried SUPread on Pan's Labyrinth (English track)? Between ST572 and 573 the time position goes from 1:09 to 00:01 as though a glitch exists in the joined evo (tried both evodemux and eac3to to join and both fail). Guess I can repair the timings but was hoping for an easier way out.
Also, SUPread doesn't OCR the odd bitmaps Pan's seems to use as well as on other discs. Is the Skew option explained somewhere so that I can try to tinker w/the setting and maybe OCR a bit better?
laserfan is offline   Reply With Quote
Old 27th February 2008, 23:30   #406  |  Link
marco_ooo
Originally Posted by Pelican9 View Post
Changes for v0.51
Change for v0.50
tested the latest version on the hd dvd from red dragon
the png are 1280x720
but the xml tell that they are 1920x1080 so scenarist give a error at the muxing point
a small part of the xml looks like this
<?xml version="1.0" encoding="UTF-8" ?>
- <BDN Version="0.93" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:noNamespaceSchemaLocation="BD-03-006-0093b BDN File Format.xsd">
- <Description>
<Name Title="FEATURE_1_MERGED.Subpicture.10" Content="" />
<Language Code="eng" />
<Format VideoFormat="1080p" FrameRate="23.976" DropFrame="False" />
<Events Type="Graphic" FirstEventInTC="00:00:54:04" LastEventOutTC="02:00:07:03" NumberofEvents="1334" />
</Description>
- <Events>
- <Event InTC="00:00:54:04" OutTC="00:00:56:20" forced="False">
<Graphic Width="1920" Height="1080" X="0" Y="0">line0001.png</Graphic>
</Event>
marco_ooo is offline   Reply With Quote
Old 28th February 2008, 00:31   #407  |  Link
Pelican9
Coder
Pelican9's Avatar
Bugfix
Thank you.
Fixed. The new version is available (v0.51b2)
Old 28th February 2008, 01:01   #408  |  Link
marco_ooo
Thank you.
wow thats fast
Old 28th February 2008, 04:28   #409  |  Link
chrkou
Pelican9: Great work!
You said something about, other languages png files, have you done anything with Greek?
chrkou is offline   Reply With Quote
Old 28th February 2008, 10:27   #410  |  Link
Pelican9
Coder
Pelican9's Avatar
"I can only show you the door. You're the one that has to walk through it. ..."
Old 28th February 2008, 11:12   #411  |  Link
marco_ooo
uhmmm scenarist is doing ok now but
if i play the movie the screen goes black with the subtitle in it
as soon the sub title goes the picture comes back
the png from subtitle workshop have a white background
mayby that has to do with it
Old 28th February 2008, 12:03   #412  |  Link
Pelican9
Coder
Pelican9's Avatar
It means that the subpicture image is not transparent.
Could anybody tell me what Scenarist needs exactly?
Transparent or white background?
Or transparent and white?
Is the OCR unchecked anyway?
Old 28th February 2008, 12:14   #413  |  Link
marco_ooo
i have attached a working png maybey you know what to do with it
Old 28th February 2008, 12:42   #414  |  Link
FalconIA
I dump a sup from a bd by tsMemux 0.0.2.0 and try to save images by SUPread 0.51b3.
But the SUPread crashed at the 61th image.
Is anyone know the reason of that?
Thanks a lot.
SUP HERE
FalconIA is offline   Reply With Quote
Old 28th February 2008, 12:59   #415  |  Link
jamos
Hey Now!
I get the same thing no transparent color just a white background. Do I need the palette check box clicked? OCR is unchecked because this is coming from a sup file.
the file you posted before above pelican works correctly with transparency although its font color was transparent when it should be white, though as you said its ugly, but you could use it to see how it is different than your current output.
http://forum.doom9.org/showpost.php?...&postcount=387
Also the .png I sent you in that email works correctly.
Old 28th February 2008, 13:52   #416  |  Link
DELPHIINES
hd sup file
I have tried to create a .png file for greek,with no luck.So i have managed to find another way to bypass the whole .png file issue.I am using subtitle creator to create a sup file from srt and then i use supread to create a hd sup.The hdsup is usually 5 times larger than sdsup.aproximately 5 mg.Is this as large as a hd sup file should be?I can test it i am still waiting for to tsremux or tsmuxer to add support for the stream of supread.Anyway thanks pelican for this great tool
DELPHIINES is offline   Reply With Quote
Old 28th February 2008, 22:32   #417  |  Link
jamos
Hey Now!
Pelican do you need me to test anything for you? current version is still not working with scenarist.
thanks
Old 29th February 2008, 03:36   #418  |  Link
Rectal Prolapse
It only requires transparent background. The output from hdsup2bdn didn't help you? hdsup2bdn outputs the PNG format scenarist wants.
hdsup2bdn also preserves the index table (including the color + alpha channel) that the original HD-DVD subtitle has - so maybe Scenarist requires index 0 to be fully transparent?
Old 29th February 2008, 09:07   #419  |  Link
Pelican9
Coder
Pelican9's Avatar
SUPread makes the same, preserves the original palette and transparency info, simply put to a png file. I'll check it again.
DELPHIINES:
Your subtitle stream has a subtitle with two windows (and some error). I've never seen this structure before that's why SUPread cannot handle it correctly.
I'm working on the solution.
jamos:
Thanks, but I've no idea what's wrong, because SUPread produce the same type of PNG which has worked before...
Old 29th February 2008, 11:44   #420  |  Link
Pelican9
Coder
Pelican9's Avatar
New beta.
PNG transparency fixed(?), please try with Scenarist.
DELPHIINES:
Does the 61st subtitle contain two text simultaneously?
Window positions:
id: 0 [1560,58] - [1625,309] it's a vertical at top right
id: 1 [623,915] - [1295,1018] it's a horizontal at the bottom
You can check during playback of the movie (at 00:17:00).
I'm looking for subtitle stream with multiple text at the same time.
I would like to know if DELPHIINES's subtitle is correct or not.
supread, suprip
