18th January 2006, 14:32 | #181 | Link | |
BeHappy/MeGUI developer
BeHappy - AviSynth-based audio transcoding tool Audio encoding via AviSynth On2 VP7 is great in quality but it is unusable for long-term video backup puposes! Sincerely Yours, MCPD/MCTS |
18th January 2006, 14:55 | #182 | Link |
@berrinam
Thankyou for the updates noticed them also on the dev thread. One question left. Where can I find 0.2.3.2033, or are I'm just too hasty and they show up at sourceforge at some point? Just eager to try out new version |
18th January 2006, 16:33 | #183 | Link | |
I have queued this job:
18th January 2006, 17:33 | #184 | Link | ||
clueless n00b
18th January 2006, 17:50 | #185 | Link | |
Just a test 1) start the encoding 2) press the pause button at 0.3% of percentage of the encoding 3) after 10 minutes x264 process still eating 50% of CPU's time (P4 3.4 with dual channel memory 1 GB) 3) resume the encoding 4) the percentage of the encoding jumps to 3,4% Sorry Doom9, for me the pause button doesn't function! |
18th January 2006, 18:25 | #186 | Link | |
clueless n00b
well.. I just can't reproduce that on either of my machines (an X2 and a regular P4 without any HT).. it stops shortly after being told to stop.
Even if I set 2 threads on my P4, it still pauses.. it takes a while, perhaps 30 seconds (and it encoded a good 300 frames in the meantime), but then it does what it's been told to.
18th January 2006, 18:36 | #187 | Link | |
I'am not sure but perhaps the ManualResetEvent isn't the best choice; I have thinked about the Semaphore class. Ciao |
18th January 2006, 18:53 | #188 | Link |
I have found this sample:
using System; using System.Threading; using System.Timers; using System.Runtime.InteropServices; // Sample application to demonstrate CPU imbalance on Hyper-Threading enabled processors namespace cpuimbalance { public class ParameterBlock { public uint id; public uint threadOption; public uint loops; public ManualResetEvent ev; } sealed public class SampleApp { static ParameterBlock[] blocks; static uint numberOfThreads; static uint threadOption; // VTune API which supports VTPause and VTResume data collection feature. // VTune is started in pause data collection mode until we are ready to begin // event sampling. [DllImport("vtuneapi.dll")] static extern void VTResume(); public static void ThreadProcess(object parameterBlock) { ParameterBlock x = parameterBlock as ParameterBlock; uint sum = 0; uint i = 0; // Wait to be signal before entering infinite loop. x.ev.WaitOne(); // Simple loop to keep thread busy. while (true) { // Add OS kernel call which provides the OS with an opportunity to // context-switch this thread sooner than it may otherwise. if (threadOption == 1) x.ev.WaitOne(); sum = sum + i*i; i += 1; x.loops += 1; } } static void Main(string[] args) { if (args.Length != 2) Console.WriteLine ("Invalid argument: [number of threads] [thread option]"); numberOfThreads = uint.Parse(args[0]); threadOption = uint.Parse(args[1]); blocks = new ParameterBlock[numberOfThreads]; blocks[0] = new ParameterBlock(); blocks[0].id = 0; blocks[0].threadOption = threadOption; blocks[0].ev = new ManualResetEvent(false); for (uint i = 1; i < numberOfThreads ; i++) { blocks[i] = new ParameterBlock(); blocks[i].id = i; blocks[i].threadOption = threadOption; blocks[i].ev = new ManualResetEvent(false); // Queue up worker threads. ThreadPool.QueueUserWorkItem (new WaitCallback(ThreadProcess), blocks[i]); } // Signal threads to begin. for (uint i = 0; i < numberOfThreads; i++) blocks[i].ev.Set(); // Signal VTune Performance Analyzer to begin collecting data VTResume(); // Using main thread as a worker thread. Begin processing ThreadProcess (blocks[numberOfThreads - 1]); // Should never get here since the threads running in infinite loop by design! // Exit controlled by VTune when it terminates this process after data collect. // Alternatively, user can kill the process through Cntrl-C. } } } Also found this article: http://www.yoda.arachsys.com/csharp/multithreading.html Ciao Last edited by max-holz; 18th January 2006 at 19:11. |
18th January 2006, 19:09 | #189 | Link | |
clueless n00b
18th January 2006, 19:29 | #190 | Link | |
At later |
18th January 2006, 22:33 | #191 | Link |
I have done the debug Doom9.
This is the 2 pass 1° pass same settings as described in my above post. In Form1.cs App performs Code:
private void pauseButton_Click(object sender, System.EventArgs e) { if (!this.paused) // we're encoding { paused = true; string error; if (vEnc != null) // currently encoding video vEnc.pause(out error); Code:
public virtual bool pause(out string error) { error = null; return encoder.pause(out error); } Code:
public override bool pause(out string error) { error = null; if (mre.Reset()) return true; else { error = "Could not reset mutex. pause failed"; return false; } } Ciao |
18th January 2006, 23:05 | #192 | Link |
I'm not sure if this is a feature request or a bug, but here goes
when using the Avisynth script creator, i load in a .d2v file that has a aspect ratio of 4:3. the output resolution vaules in the "resolution crop" section stays at 640x272. shouldn't this value be the correct ratio when the .d2v file is loaded? 4:3 = 640x480 16:9 = 640x352 or maybe a good idea to set the "suggest resolution" to be on for 4:3,16:9 and 1:1 and off for custom? please move this post if it is in the wrong place Last edited by AMED; 18th January 2006 at 23:08. |
18th January 2006, 23:12 | #193 | Link | ||
clueless n00b
18th January 2006, 23:18 | #195 | Link | |
Mr. Sandman
18th January 2006, 23:28 | #196 | Link | |
clueless n00b
18th January 2006, 23:34 | #197 | Link | |
18th January 2006, 23:58 | #198 | Link |
here is a audio extension bug i just stumbled across,
how to reproduce on the input tab, set the audio portion to MP3 and set the Video output type to MKV open up the dgindex, load in a vob, and choose "select audio streams to demux" and select any language, but leave track 2 empty, check both check boxes at the bottom of the dgindex window and click queue goto the queue tab and click start and wait for the avisynth script creator to open, don't change anything in this window and click save on the megui window, go back to the input tab and look at the extension of the audio output file, it will be called *.mp4 |
19th January 2006, 09:02 | #199 | Link | |||
clueless n00b
19th January 2006, 09:28 | #200 | Link | |
after fixing the extension of the audio file and i use the autoencode button, i get this error it doesn't seem to do anything because all the files show in the queue tab as they should and encoding of the video, audio, muxing and playback works fine. Last edited by AMED; 19th January 2006 at 09:31. |
