Old 30th September 2023, 15:04   #41  |  Link
ingoldie
I mean I don't know how I can get a better result compared to the following results.
Originally Posted by ingoldie View Post
ingoldie is offline   Reply With Quote
Old 30th September 2023, 15:52   #42  |  Link
kedautinh12
By the way, the results without denoise filter I use
Result without denoising
https://www.mediafire.com/file/voxhx...ising.avi/file
Result without denoising 2
https://www.mediafire.com/file/dda1u...ing_2.avi/file
I don't see the difference between your sample without denoised and my script. Your samples were lost details and you blame denoised as the reason for lost detail?? check here:
Old 30th September 2023, 16:01   #43  |  Link
ingoldie
Does the denoised frame belong to result of
Originally Posted by kedautinh12 View Post
SMDegrain(6, 400, prefilter=6, ContraSharp=true, RefineMotion=true, plane=4, limits=false, DCTFlicker=false)
or
TemporalDegrain2(postFFT=4, fftThreads=2)
Old 30th September 2023, 16:11   #44  |  Link
kedautinh12
Old 30th September 2023, 16:15   #45  |  Link
ingoldie
Can you send both frames?
Old 30th September 2023, 16:29   #46  |  Link
kedautinh12
Do you mean the following files in the first post?
You don't need to denoised if you use a deinterlaced filter before upscale
Scripts I used with original sample before upscale
tfm(cthresh=10)
lanczos4resize(1024,768)
Old 30th September 2023, 16:31   #47  |  Link
kedautinh12
I compare between frame 2 for the image
Old 30th September 2023, 16:34   #48  |  Link
ingoldie
Have you tried to open two files via the same AvsPmod and view them sequentially(one by one, not side by side but on top of each other) to see all the difference between "Results without denoising" and denoised results ("SMDegrain Result", "TemporalDegrain2 Result 2")
Old 30th September 2023, 16:51   #49  |  Link
kedautinh12
As I told deformities cause video to be interlaced, you need to use deinterlaced filters before upscaling. Use my scripts with original video to fix that:
tfm(cthresh=10) # deinterlaced before upscale
ex_unsharp(0.3,Fc=width()/1.5,safe=true) # Remove some of the dreamy look
ex_unsharp(1.0,Fc=width()*2.0,safe=true) # Extra fine sharpness
Old 30th September 2023, 17:20   #50  |  Link
kedautinh12
I think we need to denoise before sharpening so I think this script is better for original1:
converttoyuv420
TemporalDegrain2(postFFT=4, ppSCD1=1, thSCD2=20, fftThreads=2) # denoised
Video: https://drive.google.com/file/d/1c3t...usp=drive_link
Old 30th September 2023, 17:44   #51  |  Link
kedautinh12
With original2, I think we can use this script for a good result:
converttoyuv420
YAHR3() # dehaloing
TemporalDegrain2(postFFT=4, fftThreads=2) # denoised
Video: https://drive.google.com/file/d/19v8...ew?usp=sharing
Old 1st October 2023, 01:14   #52  |  Link
anton_foy
YAHR3() # dehaloing
Looking very fresh! Good job!
anton_foy is offline   Reply With Quote
Old 1st October 2023, 06:05   #53  |  Link
kedautinh12
After comparing, your result is dirty than my script but the details look the same
Old 1st October 2023, 12:18   #54  |  Link
EHarlen
I can't find YAHR3 and ex_unsharp
EHarlen is offline   Reply With Quote
Old 1st October 2023, 13:24   #55  |  Link
Selur
Selur's Avatar
YAHR3: https://pastebin.com/LUErwWR8
iirc. ex_unsharp is a script from Dogway
Old 1st October 2023, 13:29   #56  |  Link
gispos
real.finder YAHRmods
https://raw.githubusercontent.com/re...p/YAHRmod.avsi
Dogway's ex_unsharp
https://github.com/Dogway/Avisynth-S...enersPack.avsi
Live and let live
gispos is offline   Reply With Quote
Old 1st October 2023, 14:11   #57  |  Link
gispos
I just don't know where there is a SmootUV 64bit dll. I can only find a SmoothUV2 from Asd-g.
real.finder's Zs_RF_Shared.avsi requires the old SmoothUV version. No idea if the new version is compatible.
Live and let live
Old 1st October 2023, 14:27   #58  |  Link
kedautinh12
Download ver 2.1.1, you can use beside latest smoothuv ver (change name SmoothUV2.dll to SmoothUV.dll from 2.1.1 cause avoid same name with SmoothUV2.dll from latest ver) cause ver 2.1.1 have name of function is only smoothuv()
https://github.com/Asd-g/AviSynth-Sm...ases/tag/2.1.1
Old 2nd October 2023, 11:41   #59  |  Link
EHarlen
converttoyuv420
converttoyuv420
YAHR3() # dehaloing
What editor/encoder and codec did you use for encoding?
Old 2nd October 2023, 11:53   #60  |  Link
kedautinh12
Megui with ffms2, x264, qaac, mkvmerge(mkvtoolnix)
