Old 28th July 2023, 00:55   #21  |  Link
anton_foy
Originally Posted by ingoldie View Post
This script belongs to you, so you know best how to use it.
Can you edit all parameters in Clay for the results?
Sure go ahead and tweak all you want.
anton_foy is online now   Reply With Quote
Old 28th July 2023, 16:48   #22  |  Link
EHarlen
Originally Posted by EHarlen View Post
Yes it really looks natural. But what about the noise all over the video.
It would be perfect if the noise is removed.
Also results are weak in terms of upscaling.
EHarlen is offline   Reply With Quote
Old 30th July 2023, 13:16   #23  |  Link
ingoldie
You're right.
You're right again.
ingoldie is offline   Reply With Quote
Old 21st September 2023, 13:47   #24  |  Link
ingoldie
I tried many AviSynth denoisers but can't get a result without loss of detail.
Can I see your effort please?
Result(1024x768)
https://www.mediafire.com/file/o8py8...ult20.avi/file
Result2(1024x768)
https://www.mediafire.com/file/kj713...ult21.avi/file
Old 23rd September 2023, 03:05   #25  |  Link
kedautinh12
Result(1024x768)
Result2(1024x768)
try
SMDegrain(6, 400, prefilter=6, ContraSharp=true, RefineMotion=true, plane=4, limits=false, DCTFlicker=false)
or
TemporalDegrain2(postFFT=4, fftThreads=2)
Old 24th September 2023, 15:31   #26  |  Link
ingoldie
By the way, the results without denoise filter I use
Result without denoising
https://www.mediafire.com/file/voxhx...ising.avi/file
Result without denoising 2
https://www.mediafire.com/file/dda1u...ing_2.avi/file
Old 25th September 2023, 14:25   #27  |  Link
ingoldie
What do you think about denoising effort of the results?
Old 26th September 2023, 14:00   #28  |  Link
EHarlen
What about the results of
and
Old 26th September 2023, 15:55   #29  |  Link
kedautinh12
With
clip: https://drive.google.com/file/d/1IGg...usp=drive_link
clip2: https://drive.google.com/file/d/1f6s...usp=drive_link
With
clip: https://drive.google.com/file/d/1q8F...usp=drive_link
clip2: https://drive.google.com/file/d/1_BD...usp=drive_link
Old 26th September 2023, 15:58   #30  |  Link
kedautinh12
I wonder why both of you don't try and test. I'm lazy and just suggestions. You need to try before ask someone result
Old 29th September 2023, 14:38   #31  |  Link
ingoldie
With
With
Both are very bad. Detail loss, multiple deformities, etc.
Old 29th September 2023, 15:52   #32  |  Link
kedautinh12
Can you screenshot where detail lost between original and denoised video? And deformities relate interlaced not noised. Denoised script can't fix interlaced, you need use Deinterlaced script to fix that
Old 30th September 2023, 12:42   #33  |  Link
ingoldie
Open two files via the same AvsPmod and view them sequentially to see all the difference between "Results without denoising" and denoised results ("SMDegrain Result", "TemporalDegrain2 Result 2")
SMDegrain Result
There is also a general loss of detail.
Old 30th September 2023, 12:50   #34  |  Link
kedautinh12
Can you compared with original video???
Old 30th September 2023, 13:23   #35  |  Link
ingoldie
Here is the Original upscaled(lanczos4resize(1024,768)) to compare with SMDegrain Result
Original (1024,768)
https://www.mediafire.com/file/dvv6k...%2529.avi/file
SMDegrain Result
https://drive.google.com/file/d/1IGg...RIDiIQGXR/view
As I told open two files via the same AvsPmod and view them sequentially to see all the difference.
Old 30th September 2023, 13:36   #36  |  Link
kedautinh12
Compare here, this is sample you share me not sample above
Old 30th September 2023, 13:51   #37  |  Link
kedautinh12
And can you share me sample before upscale?? I think you need Deinterlaced before upscale to get progressive frame
Old 30th September 2023, 13:56   #38  |  Link
ingoldie
Do you mean the following files in the first post?
Old 30th September 2023, 13:56   #39  |  Link
ingoldie
By the way, when I play the following video, deformities occur in the places I marked.
SMDegrain Result
SMDegrain Result
Old 30th September 2023, 14:24   #40  |  Link
ingoldie
When I upscale(lanczos4resize(1024,768)) or zoom 200% the following Original(512x384) files in the second AvsPmod and compare them with the Results without denoising, I can't see any problem except noises.
If you pay attention, the results look very natural and I don't know how I can remove the noises without loosing this naturalness.
