Old 21st March 2018, 10:29   #41  |  Link
videoh
Useful n00b
No comment on the source filter handling penalty? That appears more serious than the avsresize slowness.
Old 21st March 2018, 12:46   #42  |  Link
videoh
Useful n00b
Originally Posted by poisondeathray View Post
How about avsmeter diagnostics ?
Can't work with Vapoursynth, so comparison would not be possible.
changing prefetch values ? - check memory / cpu usage etc... is "prefetch(8)" the "best" number in that situation ? Personally I like the auto threading of vpy better.
Prefetch 4 or 8 made no difference. Anyway, if users are forced to tweak things like this then it is just braindead, IMHO.
Can you double check some other measurement tools? maybe vspipe to ffmpeg, vs. avs to ffmpeg for example .
Never used those and don't see the relevance.
Old 21st March 2018, 12:59   #43  |  Link
videoh
Useful n00b
I want to demonstrate the source filter handling penalty of Avisynth+. Recall that the same DGSource executable is used by both Vapoursynth and Avisynth+. Here are the two scripts:
Vapoursynth:
import vapoursynth as vs
core = vs.get_core()
core.avs.LoadPlugin(path="D:/Don/Programming/C++/DGDecNV/DGDecodeNV/x64/release/DGDecodeNV.dll")
video = core.avs.DGSource('THE GREAT WALL.dgi',fulldepth=True)
video=core.std.AssumeFPS(video,fpsnum=1000, fpsden=1)
video.set_output()
Avisynth+:
loadplugin("d:\don\Programming\C++\dgdecnv\DGDecodeNV\x64\release\dgdecodenv.dll")
SetFilterMTMode("DGSource", MT_MULTI_INSTANCE)
dgsource("THE GREAT WALL.dgi",fulldepth=true)
assumefps(1000.0)
prefetch(8)
Results playing in VirtualDub2:
Vapoursynth: 6 seconds
Avisynth+: 12 seconds
If I remove the prefetch then Avisynth+ finishes in 7 seconds. But that will disable multithreading for anything else in the script.
This together with the inefficient conversions makes Avisynth+ unusable for me. I remind of the overall result for the simple process of tonemapping a UHD stream:
Vapoursynth: 13 seconds
Avisynth+ with avsresize: 45 seconds
Which one do you think a sensible person would use?
Old 21st March 2018, 16:55   #44  |  Link
TheFluff
Excessively jovial fellow
As much as I approve of demonstrating the superiority of Vapoursynth, I really don't think setting a source filter to MT_MULTI_INSTANCE is a good idea. MT_SERIALIZED forces everything upstream of the filter to be synchronous and single threaded, but source filters have no upstream so it doesn't matter. VS source filters tend to be serial in nature too.
Old 21st March 2018, 16:56   #45  |  Link
Stephen R. Savage
Stephen R. Savage's Avatar
It is because the avsresize was never tested with gamma function operations. It is missing this statement from the VS z.lib filter that enables certain speed-ups:
vsresize.cpp:L683: m_params.allow_approximate_gamma = 1;
Stephen R. Savage is offline   Reply With Quote
Old 21st March 2018, 16:59   #46  |  Link
videoh
Useful n00b
I'm sure you're right, but the setting doesn't seem to have any effect at all. I'm not familiar with Vapoursynth internals.
Old 21st March 2018, 17:01   #47  |  Link
poisondeathray
You would expect prefetch(2) should be faster in that script
For the src filter threading issue, it did not affect the old avisynth(-) mt (at least no reports as bad as this) - what is different about the threading model here in avisynth(+) ?
Old 21st March 2018, 17:01   #48  |  Link
videoh
Useful n00b
Thanks, I will try adding that. Of course, that may remove one penalty but not the source filter penalty.
Old 21st March 2018, 17:14   #49  |  Link
videoh
Useful n00b
Bravo Stephen! With that change, avsresize performance is the same as Vapoursynth. Will you release an update with this change?
Now let's try to figure out the second issue.
Old 21st March 2018, 17:23   #50  |  Link
poisondeathray
For the src filter issue - it doesn't appear to be a GPU latency /transfer issue, because avs+ prefetch(4) incurs no significant penalty with dss/dss2 cuvid
Old 21st March 2018, 17:24   #51  |  Link
videoh
Useful n00b
I ran the entire HDR->SDR process again with the avsresize fix. Here is the script:
loadplugin("D:\Don\Programming\C++\Avisynth filters\ToneMap float\x64\release\tonemap.dll")
loadplugin("D:\Don\Programming\C++\avsresize-r1c\x64\release\avsresize.dll")
SetFilterMTMode("z_ConvertFormat", MT_MULTI_INSTANCE)
z_ConvertFormat(pixel_type="RGBPS",colorspace_op="2020ncl:st2084:2020:l=>rgb:linear:2020:l", dither_type="none")
tonemap()
z_ConvertFormat(pixel_type="YV12",colorspace_op="rgb:linear:2020:l=>709:709:709:l",dither_type="ordered")
prefetch(2)
The overall performance is now the same as Vapoursynth!
The prefetch number didn't affect the timing but value 2 made things smooth and 8 made it go in stops and starts.
So, hey, Avisynth+ lives on. but
Old 21st March 2018, 17:32   #52  |  Link
videoh
Useful n00b
I'll release an Avisynth+ port of Phillip Blucas's tonemap filter within a few days (with some performance improvements). Then there will be a full HDR->SDR solution for Avisynth+.
It's close to being realtime for UHD (22fps on my machine) when playing in VirtualDub2. It would be nice if we could squeeze a little more performance out of zimg (or port equivalent conversions to CUDA).
Old 21st March 2018, 17:38   #53  |  Link
Sharc
Originally Posted by videoh View Post
so, hey, avisynth+ lives on. But
oh happy day
Old 21st March 2018, 17:49   #54  |  Link
TheFluff
Setting the source filter to MT_MULTI_INSTANCE with prefetch(2) is functionally much like doing something like
src1 = dgsource("file.dgi")
src2 = dgsource("file.dgi")
interleave(src1.selecteven(), src2.selectodd())
So if you have too many instances you'll start trashing the disk because you'll have many threads reading from the same file. Depending on the filter chain, it may or may not be beneficial to do this. You'll get as many instances as you have threads whether you want to or not. On the other hand if the source filter is MT_SERIALIZED there'll only be one instance of it and it'll only process one frame request at a time, but other filters that are requesting frames from it may run in parallel in various ways. The requesting thread will always block and wait for the request to complete though because that's just how the API is designed.
In VS, all Avisynth filters are always run single threaded and in a single instance, but VS attempts to fit them into its nonblocking frame request framework as well as it can, and it will also automatically attempt to request frames from source filters linearly in order. I'd expect it to run most source filters slightly faster than Avs+ would with MT_SERIALIZED.
I wrote a very long and boring attempt to explain the differences between the concurrency models here a while ago.
Old 21st March 2018, 18:01   #55  |  Link
videoh
Useful n00b
Thanks for that explanation. I tried to read your link some time ago, but I fell asleep.
Is there anything to be gained by making a Vapoursynth-native version of DGSource()?
Old 21st March 2018, 18:14   #56  |  Link
TheFluff
For a source filter I don’t think there’s anything significant to gain performance-wise, no. Not sure about how complete the VS compatibility layer is in terms of various exotic colorspaces and/or bitdepths though.
Old 21st March 2018, 18:16   #57  |  Link
DJATOM
DJATOM's Avatar
Yes. Autoloading is great!
Me on GitHub
PC Specs: Ryzen 5950X, 64 GB RAM, RTX 2070
DJATOM is offline   Reply With Quote
Old 21st March 2018, 18:17   #58  |  Link
videoh
Useful n00b
Thank you. All I need is YUV420P016 and that is covered now.
Old 21st March 2018, 18:17   #59  |  Link
videoh
Useful n00b
Alrighty then, I'll do it. Actually I already have it from a while ago, just have to add a few fixes that flowed under the bridge since then.
Old 21st March 2018, 22:04   #60  |  Link
videoh
Useful n00b
Please give the script that plays that fast for UHD content (3840x2160 16-bit). Just to be clear, I am talking about playing the script in VitualDub2.
Will you release a fixed avsresize so I don't have to include one? Thanks.
