Old 19th March 2018, 17:31   #21  |  Link
videoh
Useful n00b
Thanks for your reply.
MT_NICE_FILTER crashes, and MT_MULTI_INSTANCE is as slow as not declaring the mode.
Old 20th March 2018, 15:38   #22  |  Link
videoh
Useful n00b
zimg is used in Vapoursynth so we can't blame this on zimg. Is it just the case that Avisynth+ multithreading is terminally deficient? Or is there some heavy penalty for not having the resizing in the core? Or both? If anyone cares about Avisynth+ there will have to be an answer and resolution.
Old 20th March 2018, 16:37   #23  |  Link
pinterf
Try eliminating dgsource for speed tests.
pinterf is offline   Reply With Quote
Old 20th March 2018, 16:50   #24  |  Link
videoh
Useful n00b
Huh? The same DGSource() executable is used for both Avisynth+ and Vapoursynth testing.
Vapoursynth: 13 seconds
Avisynth+ with z.lib: 45 seconds
Old 20th March 2018, 17:20   #25  |  Link
pinterf
I was asking you for benchmarks w/o dgsource (e.g. using a BlankClip instead) because Avisynth+ runs source filters in MT_SERIALIZED mode.
I don't know how it works in VapourSynth but that can be a difference, which could be eliminated by omitting source filter.
When a source filter would benefit from a specific MT mode, you have to set it for that specific filter manually. It would show then that DgSource with MT_SERIALIZED mode is bottleneck or not.
Old 20th March 2018, 17:27   #26  |  Link
videoh
Useful n00b
DGSource runs fine in MT_MULTI_INSTANCE but it makes no difference. I'll try with blank clip.
Old 20th March 2018, 17:31   #27  |  Link
DJATOM
DJATOM's Avatar
DGSource is actually handled as source filter inside VS's avisynth wrapper: https://github.com/vapoursynth/vapou...ompat.cpp#L378, so it should not be a bottleneck for tests.
Me on GitHub
PC Specs: Ryzen 5950X, 64 GB RAM, RTX 2070
DJATOM is offline   Reply With Quote
Old 20th March 2018, 17:53   #28  |  Link
videoh
Useful n00b
With BlankClip (specifying 10000 frames at 1000 fps and playing in VirtualDub2, just the format conversions):
Vapoursynth 14 sec
Avisynth+ 22 sec
The difference is not as large but is still quite significant. So there is a pure penalty in the conversions and another penalty in the handling of the source filter.
Setting DGSource MT_NICE_FILTER or MT_MULTI_INSTANCE makes no difference (DGSource is actually thread safe and CUVID supports multiple instances). So why does Vapoursynth apparently not suffer these penalties while Avisynth+ does? I tried a large value in SetMemoryMax() but again it made no difference.
Don't get me wrong; I've been a stalwart supporter of Avisynth(+) since year 2000 and have greatly appreciated your efforts along with everyone else. I just want to be able to continue using it in the UHD world.
MAGA (Make Avisynth Great Again)
Old 20th March 2018, 18:02   #29  |  Link
jpsdr
Are the speed test results from playing the same avs script in Avs+ and Vapoursynth, or, is it the avs script using z.lib vs Vapoursynth using internal conversion ?
If it's the second case, one possible explaination would be that the conversion is just faster in Vapoursynth than z.lib.
You're not alone thinking z.lib conversion is slow, also here.
My github.
Old 20th March 2018, 18:19   #30  |  Link
videoh
Useful n00b
Interesting, thanks for that confirmation.
It's the second case, of course. But avsresize (z.lib) is basically just a wrapper around zimg, and zimg is used by Vapoursynth. The difference I guess is in invoking it in the core versus an external filter. Hopefully pinterf can shed some light on things for us. zimg could be added to the Avisynth+ core. Things take time, it's not a surprise.
Old 20th March 2018, 20:03   #31  |  Link
Myrsloik
Professional Code Monkey
Myrsloik's Avatar
Nope, no "core" magic there. It's just an internal plugin and nothing more. No secrets.
Myrsloik is online now   Reply With Quote
Old 20th March 2018, 20:23   #32  |  Link
videoh
Useful n00b
Seems that Avisynth has reached end of life, but what do I know?
Old 20th March 2018, 21:23   #33  |  Link
jpsdr
Is the actual build of z.lib up to date with the zimg version ? Does Vapoursynth and this z.lib use the same zimg version ?
My github.
Old 20th March 2018, 21:35   #34  |  Link
videoh
Useful n00b
I rebuilt avsresize with the the latest version of zimg:
https://github.com/sekrit-twc/zimg
Old 20th March 2018, 22:53   #35  |  Link
poisondeathray
Were those observations based on your rebuilt avsresize, or "avsresize-r1c" provided in the 1st post ? or same results ?
Old 20th March 2018, 23:15   #36  |  Link
real.finder
you say that just because one filter run faster in vs?! there are another cases that avs is faster like https://github.com/Khanattila/KNLMeansCL/wiki/Benchmark
I think there are something in avsresize dll that case that slowness
See My Avisynth Stuff
Old 20th March 2018, 23:52   #37  |  Link
gonca
Apart from the fact that the benchmark is for 1080p, and not 4K as is being discussed, it actually shows that vpy can handle formats, channels and precisions that avs can't
gonca is offline   Reply With Quote
Old 21st March 2018, 02:35   #38  |  Link
videoh
Useful n00b
Results are the same for both.
Old 21st March 2018, 07:00   #39  |  Link
poisondeathray
How about avsmeter diagnostics ? changing prefetch values ? - check memory / cpu usage etc... is "prefetch(8)" the "best" number in that situation ? Personally I like the auto threading of vpy better.
Can you double check some other measurement tools? maybe vspipe to ffmpeg, vs. avs to ffmpeg for example .
I'll try to compare some other operations in avs vs. vpy tomorrow for z.lib/zimg , if sekrit-twc / s.savage doesn't post by then
Old 21st March 2018, 09:25   #40  |  Link
pinterf
Vapoursynth 14 sec
Avisynth+ 22 sec
Thanks, the difference is still big, worth investigating when I have time.
