Old 17th September 2023, 22:56   #10221  |  Link
Sunspark
Am I correct in assuming that it's unnecessary to check "VSync" in frame synchronization for evr-cp if one is already using autochange fullscreen to match refresh rates?
I don't see any change in the red lines with the ctrl-t test with VSync checked or unchecked.
When is it best used?
Old 18th September 2023, 06:42   #10222  |  Link
v0lt
There is no best solution. If you have problems with the smoothness of frame output, then you can try turning on the "VSync" settings. Which combination will be best for your configuration is determined by tests.
v0lt is offline   Reply With Quote
Old 18th September 2023, 18:37   #10223  |  Link
Sunspark
Color management checkbox for evr-cp doesn't work here. Shifts the hue to yellow whether windowed or fullscreen. Exclusive mode on or off doesn't make a difference.
Old 19th September 2023, 07:05   #10224  |  Link
v0lt
It works. For the window it is used twice (using a shader and display profile). For a full screen once (using a shader).
I could probably fix this (turning off for the window), but users will be unhappy. This issue was discussed several times in the topic.
Old 19th September 2023, 16:32   #10225  |  Link
Sunspark
I do use a colour profile and have it applied system-wide (as well as a non-2.2 gamma). Are these users who would be unhappy, users that don't have colour profiles?
I did look at the search, but it wasn't clear to me what the issue is that it functions in this manner. My assumption is that the code would simply just call and check if there's a profile installed, and if so, take it into account, else proceed as it has been doing already.
Old 20th September 2023, 10:43   #10226  |  Link
v0lt
If a display profile is not used, MPC-BE will not be able to use Color Management.
Which display profile Color Managment uses will be visible in the EVR-CP statistics in MPC-BE 1.6.9.103.
Old 22nd September 2023, 23:43   #10227  |  Link
s0meone_new
Hungarian translation updated:
https://easyupload.io/dsw16y
s0meone_new is offline   Reply With Quote
Old 23rd September 2023, 06:57   #10228  |  Link
Klaus1189
Updated german translation
Old 23rd September 2023, 15:17   #10229  |  Link
cmhrky
Will there be "App paths" support for ffmpeg.exe?
cmhrky is offline   Reply With Quote
Old 23rd September 2023, 16:13   #10230  |  Link
v0lt
Do you need it?
Old 23rd September 2023, 16:27   #10231  |  Link
cmhrky
If it can be used for youtube-dl and yt-dlp, it might be good to support ffmpeg as well.
Old 23rd September 2023, 16:37   #10232  |  Link
wushantao
https://files.catbox.moe/q9yzk3.7z
Update Simplified Chinese:)
wushantao is offline   Reply With Quote
Old 23rd September 2023, 17:48   #10233  |  Link
v0lt
Thanks everyone. Translations have been updated.
"App paths" support for "ffmpeg.exe" has been added.
Old 23rd September 2023, 19:13   #10234  |  Link
cmhrky
It would be nice to set a location for ffmpeg.exe with "App Paths".
Thank you @v0lt. Another wish of mine has come true. 🎉
Old 30th September 2023, 14:05   #10235  |  Link
wushantao
https://files.catbox.moe/l7wpev.7z
Old 30th September 2023, 16:19   #10236  |  Link
Klaus1189
How do I enter the dialog with the new translation? I need to check if it fits.
Old 1st October 2023, 04:53   #10237  |  Link
s0meone_new
https://easyupload.io/bpgo4h
Old 1st October 2023, 05:24   #10238  |  Link
v0lt
Old 2nd October 2023, 05:01   #10239  |  Link
v0lt
This is for the YouTube clip saving dialog. You probably won't see the "Merging files..." line because ffmpeg.exe merges DASH streams very quickly.
Old 2nd October 2023, 15:56   #10240  |  Link
beter
Translation Update for Traditional Chinese and Dutch:
https://www.sendspace.com/file/3jj0et
beter is offline   Reply With Quote
