Old 19th September 2023, 12:26   #25041  |  Link
nevcairiel
I plan on updating it soon.
Old 22nd September 2023, 21:33   #25042  |  Link
Balling
Originally Posted by v0lt View Post
@nevcairiel
Please update FFmpeg. The developers recently eliminated a very unpleasant noise when playing APE 24-bit files.
Partially eliminated. https://trac.ffmpeg.org/ticket/10323
Balling is offline   Reply With Quote
Old 30th September 2023, 09:20   #25043  |  Link
lvqcl
LAVFilters-0.77.2-7.exe wasn't built/uploaded properly? Its size is 624K.
lvqcl is offline   Reply With Quote
Old 30th September 2023, 12:18   #25044  |  Link
Siso
Soul Seeker
Siso's Avatar
+ 1. Can't install it.
Old 30th September 2023, 15:15   #25045  |  Link
nevcairiel
Seems like there was a network error, I've restarted the latest nightly.
Old 30th September 2023, 15:36   #25046  |  Link
Siso
Soul Seeker
Siso's Avatar
Thank you, nev. It works now.
Old 30th September 2023, 20:54   #25047  |  Link
Mercury_22
D3D11 is crashing with the latest build LAVFilters-0.77.2-7 (DXVA2 it's working though)
Intel Graphics Driver 31.0.101.4826
Intel UHD Graphics 750; Win 10 22H2
Mercury_22 is offline   Reply With Quote
Old 30th September 2023, 21:15   #25048  |  Link
Spunkmeyer
Same on AMD, reverted to 0.77.2-3.
Spunkmeyer is offline   Reply With Quote
Old 30th September 2023, 21:39   #25049  |  Link
Siso
Soul Seeker
Siso's Avatar
It crashes for me too with dxva cp.
Old 30th September 2023, 21:55   #25050  |  Link
nevcairiel
That should be fixed in the next build. Its still rather work-in-progress, so any testing is appreciated.
Old 1st October 2023, 01:26   #25051  |  Link
clsid
Can you also build a new mingw gcc toolchain pack?
Thanks
MPC-HC 2.1.2
Old 1st October 2023, 06:08   #25052  |  Link
ryrynz
ryrynz's Avatar
072.1.8 working fine here with DXVA, .7 previously crashed for me. Thanks.
Old 1st October 2023, 13:03   #25053  |  Link
Siso
Soul Seeker
Siso's Avatar
Works fine for me.
Old 5th October 2023, 12:14   #25054  |  Link
clsid
dav1d 1.3.0 has been released
MPC-HC 2.1.2
Old 9th October 2023, 08:56   #25055  |  Link
Siso
Soul Seeker
Siso's Avatar
There is again problem with LAVFilters-0.77.2-16. The exe is corrupted. 3.9M only.
Old 10th October 2023, 09:41   #25056  |  Link
ryrynz
ryrynz's Avatar
I think your connection might've timed out. I'm experiencing download speeds slower than what I'd get at home if I went back to 1995
It timed out but I resumed and installed it okay. That server needs a rest.
Old 13th October 2023, 23:47   #25057  |  Link
clsid
Crash:
https://drdump.com/DumpGroup.aspx?DumpGroupID=2481628
Could this not be handled more gracefully by just returning error value instead of doing a hard abort?
The dump does not contain much useful information due to being in GCC compiled code. All I know it was MP4 container.
And another old one that happens a lot:
https://drdump.com/Problem.aspx?ProblemID=743788
https://drdump.com/Problem.aspx?ProblemID=887238
On the very rare occasion that I get a sample file, I can not reproduce any issues. So maybe due to driver TDRs or running out of GPU mem.
MPC-HC 2.1.2
Old 14th October 2023, 00:53   #25058  |  Link
nevcairiel
The crash dumps are not public. Also, good fixes require user reports and samples. Thats why automatic crash reporting is rather lacking.
And no, you cannot "handle" crashes.
Old 14th October 2023, 01:24   #25059  |  Link
clsid
The first one "crashes" due to calling abort() in av_assert0(). Why not return an AVERROR value and stop decoding?
https://imgur.com/a/4q1dPpl
MPC-HC 2.1.2
Old 14th October 2023, 01:45   #25060  |  Link
nevcairiel
asserts check conditions that are impossible, unless a decoder has a bug in its behavior. This is unrelated to the validity of the input.
Either way, I can't download the crash dump, I have no sample, or any information what decoder it even might be.
