21st November 2004, 02:37 | #121 | Link |
Hi!! i'm just trying to make a xvcd with this great tool, but i have some questions about it:
Where i can found some explanations about the options like Mb decision (compare fn, least bits, rd), Compare fn (SAd and satd)and wich it's the best search size? i tried to make a simple comparasion with an xvid file to vcd, but if i want a loot of quality i need to put Min quant in 1 (but when it plays i see some artifacts). i tried this conf: gopsize 12 Min Quant:2 Max quant: 31 Md decision: Copmnf Compfn: SaTD Search size: Diamond 0 Aspect ratio 4:3 Noise reduction: 0 Rate control: 0.5 Min bitrate 300 Max bitrate 2500 CQ: 100 Any mini-howto-explanation? |
21st November 2004, 05:16 | #122 | Link |
SATD is slightly better quality than SAD.
least bits good for low bitrate while rate distortion(rd) may be better for high bitrates. diamond size should be atleast 1 really if you expect reasonable quality. higher should increase quality(slightly) each step. how technical do you want the information ? |
21st November 2004, 08:40 | #123 | Link |
High beam
Encountered problem with NuEnc01.01b mirror:
If <nuEnc.exe> don't run after installation, just go in the registry at 1)<HKey_LOCAL_MACHINE_/SOFTWARE/NuEnc> 2)<HKey_LOCAL_MACHINE_/SOFTWARE/QuEnc> 3)Delete both of them. It resets all default parameters. Last edited by freelock7; 28th November 2004 at 22:04. |
21st November 2004, 08:55 | #124 | Link |
dragongodz,
Thanks for the helpful hints. I tried the following and got much better results at low bit rates (and much longer encode times). Mode = VBR Passes = 2 Scene Detection = checked MB Decision = Least bits Compare Fn = SATD Search Size = Diamond 6 RC Variability = 0.5 Matrix = KVCD Notch Noise Reduction = 0 Use Trellis Quantisation = unchecked Turbo 1st Pass = checked |
21st November 2004, 10:45 | #125 | Link |
Just a Member
@Peter1234
A search size of 6 isn't worth the extra encode time. Try 3 or 4 (or less). The difference between 3 and 6 is small. @freelock7 The mirror is the exactly the same file. Shouldn't be any problems. @dragongodz Ok, first GOP will always start IP then. It isn't a good idea to have only 1 reference for b-frames . Some of the options in FreeEnc don't even refer to MPEG1 or 2. That is what I think is silly. |
21st November 2004, 12:13 | #126 | Link |
i'm looking the best (if it's possible) configuration for convert mpeg4 to mpeg 1 and 2.
Now tmpgenc offer better quality (i now it's relative). And if it's possible a doc with explanations about the options in Advanced. When a version with sse2-p4-ht? Cheers. Last edited by Fl0ppy; 21st November 2004 at 12:24. |
21st November 2004, 12:31 | #127 | Link | ||
i also checked their first GOP patterns and they all did IP. Quote:
21st November 2004, 12:59 | #129 | Link | |
21st November 2004, 13:31 | #130 | Link | |
hmm ok found this snippet
http://www.geocities.com/medinotes/vcd/chapters.html if you go down to the Tmpgenc part it says Quote:
still for dvd all GOPs should have sequence headers anyway. http://www.pioneeraus.com.au/compute...dvdInfo_9.html so long as sequence headers are neing written every GOP then i dont think it really matters. still as i said before it is strange that the other encoders do it aswell. |
21st November 2004, 13:41 | #131 | Link |
interlace this!
FWIW, premiere pro has problems with i-frames. editing is fine, but on export it places the b-frame after the i-frame on the other side of it, causing a kind of "double-take" at scenechanges. this only happens when the user has placed an edit on that scenechange.
i learnt this one the hard way. whether this has anything at all to do with sequence headers and p-frames immediately proceeding i-frames on closed GOPs, i don't know.
sucking the life out of your videos since 2004 |
21st November 2004, 19:36 | #132 | Link | |
HCenc author
If you create the first GOP as IPBBPBB... than the closed gop flag may be set to 0 or 1. But if the first GOP looks like IBBPBB... and the closed gop flag is not set, a lot of decoders and editors will complain even if the first B-frames are backward predicted so it could be decoded fine. According to the specs: closed_gop This is a one-bit flag which indicates the nature of the predictions used in the first consecutive B-pictures (if any) immediately following the first coded I-frame following the group of picture header . closed_gop is set to ‘1’ to indicate that these B-pictures have been encoded using only backward prediction or intra coding. This bit is provided for use during any editing which occurs after encoding. If the previous pictures have been removed by editing, broken_link may be set to ‘1’ so that a decoder may avoid displaying these B-Pictures following the first I-Picture following the group of picture header. However if the closed_gop bit is set to ‘1’, then the editor may choose not to set the broken_link bit as these B-Pictures can be correctly decoded. broken_link This is a one-bit flag which shall be set to ‘0’ during encoding. It is set to ‘1’ to indicate that the first consecutive B-Pictures (if any) immediately following the first coded I-frame following the group of picture header may not be correctly decoded because the reference frame which is used for prediction is not available (because of the action of editing). A decoder may use this flag to avoid displaying frames that cannot be correctly decoded. To be on the safe side and make the stream fully compatible with all decoders just create the first GOP in the same manner as after a scene change and make it IPBBPBB... and set the closed gop flag. |
22nd November 2004, 10:17 | #133 | Link |
Just a Member
AFAIK, closed GOP is about how a GOP ends, not how it starts.
Not Closed I B B P B B P B B I B B P B B Closed GOP I B B P B B P B P I B B P B B (In decoded or display order) The B-frames in bold are referencing a frame which is unrelated to the current frame - which is wasteful. A closed GOP means that a P frame precedes the next I frame. CCE and TMPGEnc both start: I B B P B B P in decoded order (or display order) 1 2 3 4 5 6 7 I P B B P B B in encoded order 1 4 2 3 7 5 6 Avcodec already does this, so I don't have to change anything there. Avcodec also inserts a sequence header with every I frame, regardless of whether the GOP is closed or not, so no problems there. |
22nd November 2004, 12:48 | #134 | Link | |
HCenc author
Also in the case of a scene change you start with a closed GOP so you can make a cut before that GOP. The order I was referring to was the encoding order so: IBBPBB --> open GOP --> temporal reference 2 0 1 5 3 4 IPBBPBB --> closed GOP --> temporal reference 0 3 1 2 6 4 5 If you write in display order I B B P B B P B B I B B P B B than the bold B-pics actually belong to the next GOP. If AVcodec starts with IPBBPBB... (encoding order) it's OK but I still think you should set the closed gop flag. |
22nd November 2004, 13:06 | #135 | Link |
wow what a can of worms i opened with 1 little observation.
actually something else i was thinking about Peter, would it be possible for you to make your RC a seperate and selecatable RC ? that way have both old RC and new usable from the 1 program. no need for Nic to release 2 versions of QuEnc for people to test and compare the 2 RC's then. i know Michael(from FFMpeg) said thats what he planned for a second ,better, RC but as far as i know he has still only half done it(the second RC that is). |
22nd November 2004, 13:40 | #136 | Link | |
Just a Member
EDIT: Since the B-frames are referring to 2 different GOPs, how can you say which GOP it belongs to. Is a bisexual person gay or straight? @dragongodz Can be easily done. I've finished the code for closed gop and it seems to work as it should. I'll separate RC next. Last edited by Peter Cheat; 22nd November 2004 at 13:44. |
22nd November 2004, 18:12 | #137 | Link |
Hi again
After severals tests (converting xvid and dvd to mpeg1) i tried nuenc 0.01b and tmpgenc. If in nuenc i put CQ 100, the quality is great, but if i put CQ 80 or 90 the quality in less than tmpgenc at same quality (80 or 90) And the file created by nuenc/ffmpeg is half of tmpgenc And the speed is 32fps (at 352x288 mpeg1) (i can wait) |
23rd November 2004, 00:56 | #138 | Link | |
two things to also remember. 1. mpeg1 encoding with avcodec is not meant to be the absolute best. 2. the CQ mode is brand new so will probably take a little time and tweaking to get towards optimal. |
23rd November 2004, 05:05 | #140 | Link |
interlace this!
also, TMPG uses a different scale. so 80 in TMPGenc ≠ 80 in QuEnc.
i'd be interested in seeing what equal sized encodes look like between TMPG and QuEnc.
