Old 8th April 2015, 22:01   #61  |  Link
Great Dragon
Great Dragon's Avatar
v2.00 even doesn't work as it should with default settings
Great Dragon is offline   Reply With Quote
Old 9th April 2015, 00:08   #62  |  Link
Overdrive80
Anime addict
Overdrive80's Avatar
I can not reproduce it.
function maa2(clip c, int "mask", bool "chroma", float "ss", int "aa", int "aac", int "threads", int "show", int "maskt")
    chroma = Default(chroma, false)
    mask   = Default(mask, 1)
    maskt   = Default(maskt, 1)
    mtresh = (mask < 0) ? -mask : 7
    show   = Default(show, 0)
    uv     = (chroma) ? 3 : 1
    Assert(c.IsY8 || c.IsYV12 || c.IsYV24 || c.IsYV16, "MAA2: Input must be Y8, YV12, YV16 or YV24")
    Assert(0 <= show <= 2, "MAA2: Parameter 'show' must be between 0 and 2")
    # create mask
    if (mask != 0) {
        m = (maskt != 1) ? c.mt_edge("min/max", 0, mtresh, 0, mtresh-6, u=uv, v=uv).mt_inflate(u=uv, v=uv) : c.mt_edge("sobel", mtresh, mtresh, mtresh-6, mtresh-6, u=uv, v=uv).mt_inflate(u=uv, v=uv)
    # run sangnom2-based aa
    if (!chroma || show > 0) {
        c_aa = c.ConvertToY8().Sangnom2AA(ss, aa, threads=threads)
    else if (c.IsYV16) {
        c_aa_u = c.UtoY8().Sangnom2AA(ss, aac, threads=threads)
        c_aa_v = c.VtoY8().Sangnom2AA(ss, aac, threads=threads)
        c_aa = YToUV(c_aa_u, c_aa_v, c.ConvertToY8().Sangnom2AA(ss, aa, threads=threads))
    else { c_aa = c.Sangnom2AA(ss, aa, aac, threads) }
    # prepare chroma planes for mask overlay
    if (show == 1) {
        c_aa = (c.IsY8) ? c.ConvertToYV12().mt_lut(y=2, u=0, v=0)
                      \ : c.mt_lut("x 2 /", y=2, u=3, v=3)
    else if (show == 2) {
        c_aa = (c.IsY8) ? c_aa.ConvertToYV12().mt_lut(y=2, u=0, v=0)
                      \ : YtoUV(c.UtoY8(), c.VtoY8(), c_aa).mt_lut("x 2 /", y=2, u=3, v=3)
    # merge aa'ed lines into source
    if (mask == 0) {
        return mt_logic(c_aa, "and", y=4, u=2, v=2)
    else if (show > 0) {
        if (c.IsYV16) {
            m_uv = BilinearResize(m, m.width/2, m.height)
            return mt_merge(c, c_aa, YtoUV(m_uv, m_uv, m), u=3, v=3)
        else {
            return (c.IsYV24) ? mt_merge(c, c_aa, m.YtoUV(m,m), u=3, v=3)
                            \ : mt_merge(c.ConvertToYV12(), c_aa, m, u=3, v=3, luma=true)
    else {
        return (chroma) ? mt_merge(c, c_aa, m, u=3, v=3)
                      \ : mt_merge(c, c_aa, m, u=2, v=2)
This function not use avisynth language, I think.
EDIT: I am using avisynth 2.6 and I dont get error with my source that is yv12 (if use converttoyv24 or converttoy8 get error because lsfmod is limited yv12 colourspaces but not for maa2).
Is possible that you didn't remove dll of removegrain, repair, etc... from pack of kassandro?? Please, use plugins listed in dependencies http://forum.doom9.org/showthread.ph...77#post1716077 and remove old plugins.
I use maa2 http://avisynth.nl/index.php/MAA2
Intel i7-6700K + Noctua NH-D15 + Z170A XPower G. Titanium + Kingston HyperX Savage DDR4 2x8GB + Radeon RX580 8GB DDR5 + ADATA SX8200 Pro 1 TB + Antec EDG750 80 Plus Gold Mod + Corsair 780T Graphite
Overdrive80 is offline   Reply With Quote
Old 9th April 2015, 05:57   #63  |  Link
Great Dragon
I'm using Avisynth+ but I'll check plugins version. However I'm pretty sure they're up to date.
UPDATE:
I'm using 0.41mod version of maa2 http://pastebin.com/fqR4CMbV
There is also 0.42+ mod http://pastebin.com/F0GLtrx5 I guess it's made specially for Avisynth+ however 0.41mod work fine for me too.
UPDATE2:
@Overdrive80 can you please check if those mods works for you with Avisynth 2.6 ?
Old 9th April 2015, 18:39   #64  |  Link
Overdrive80
Anime addict
Ok, but I have convert sintaxis for maa2 on avisynth from your avisynth+ mod.
Old 9th April 2015, 19:54   #65  |  Link
Overdrive80
Anime addict
Ok, with code below of maa2 0.42+ runs fine on avisynth 2.6:
MAA2MOD v0.42
Updated version of the MAA antialising script from AnimeIVTC.
MAA2 uses tp7's SangNom2, which provide a nice speedup for SangNom-based antialiasing,
especially when only processing the luma plane.
The defaults of MAA2 match up with MAA, so you'll get identical output (save for the more accurate border region processing of SangNom2)
when using this script as a drop-in replacement.
MAA2 supports Y8, YV12, YV16 and YV24 input.
Requirements:
   * AviSynth
   * SangNom2 0.3+
   * Masktools 2.0b1
Parameters:
   + [int] mask (1)
       *   0: Disable masking
       *   1: Enable masking
       *  -i: Enable masking with custom treshold
   + [bool] chroma (false)
       *   false: Don't process chroma channels (copy UV from the source clip if present)
       *   true: Process chroma channels
   + [float] ss (2.0)
       *   Supersampling factor (sensible values are between 2.0 and 4.0 for HD content)
   + [int] aa (48)
       *   Sangnom2 luma antialiasing strength
   + [int] aac (aa-8)
       *   Sangnom2 chroma antialiasing strength
   + [int] threads (4)
       *   Number of threads used by every Sangnom2 instance
   + [int] show (0)
       *   0: Don't overlay mask
       *   1: Overlay mask only
       *   2: Overlay mask and run antialiasing on the luma plane
   + [int] maskt (1)
       *   1: sobel
       *   2: min/max
function maa2mod(clip c, int "mask", bool "chroma", float "ss", int "aa", int "aac", int "threads", int "show", int "maskt")
    # create mask
    m = mask  != 0 ? c.mt_edge("sobel", mtresh, mtresh, mtresh-6, mtresh-6, u=uv, v=uv).mt_inflate(u=uv, v=uv) : \
        maskt != 1 ? c.mt_edge("min/max", 0, mtresh, 0, mtresh-6, u=uv, v=uv).mt_inflate(u=uv, v=uv)           : nop
    c_aa_u = (c.IsYV16) ? c.UtoY8().Sangnom2AA(ss, aac, threads=threads) : nop
    c_aa_v = (c.IsYV16) ? c.VtoY8().Sangnom2AA(ss, aac, threads=threads) : nop
    c_aa = (!chroma || show > 0) ? c.ConvertToY8().Sangnom2AA(ss, aa, threads=threads)                         : \
                      (c.IsYV16) ? YToUV(c_aa_u, c_aa_v, c.ConvertToY8().Sangnom2AA(ss, aa, threads=threads))  : c.Sangnom2AA(ss, aa, aac, threads)
    c_aa = (Show == 1 && !c.IsY8)  ? c.mt_lut("x 2 /", y=2, u=3, v=3)                                  : \
           (Show == 1 &&  c.IsY8)  ? c.ConvertToYV12().mt_lut(y=2, u=0, v=0)                           : \
           (show == 2 && !c.IsY8)  ? YtoUV(c.UtoY8(), c.VtoY8(), c_aa).mt_lut("x 2 /", y=2, u=3, v=3)  : \
           (show == 2 &&  c.IsY8)  ? c.ConvertToYV12().mt_lut(y=2, u=0, v=0)                           : c_aa
    m_uv = (c.IsYV16)  ? BilinearResize(m, m.width/2, m.height) : nop
    last = (mask == 0)                          ? mt_logic(c_aa, "and", y=4, u=2, v=2)                      : \
           (mask != 0 && show > 0 && c.isYV16)  ? mt_merge(c, c_aa, YtoUV(m_uv, m_uv, m), u=3, v=3)         : \
           (mask != 0 && show > 0 && c.IsYV24)  ? mt_merge(c, c_aa, m.YtoUV(m,m), u=3, v=3)                 : \
           (mask != 0 && show > 0)              ? mt_merge(c.ConvertToYV12(), c_aa, m, u=3, v=3, luma=true) : \
           (mask != 0 && show == 0 && chroma)   ? mt_merge(c, c_aa, m, u=3, v=3)                            : mt_merge(c, c_aa, m, u=2, v=2)
   return last
function Sangnom2AA(clip c, float "ss", int "aa", int "aac", int "threads")
    threads = Default(threads, 4)
    aa = Default(aa, 48)
    aac = Default(aac, aa-8)
    aac = (aac < 0) ? 0 : aac
    ss = Default(ss, 2.0)
    ss_w = int(round(c.width*ss/4.0)*4)
    ss_h = int(round(c.height*ss/4.0)*4)
    Assert(ss > 0, "MAA2: Supersampling factor must be > 0")
    return c.Spline36Resize(ss_w, ss_h).TurnLeft() \
            .SangNom2(threads=threads, aa=aa, aac=aac).TurnRight().SangNom2(threads=threads, aa=aa, aac=aac).Spline36Resize(c.width, c.height)
Please, check if all code is fine for you, I am not tested too much.
Note: I rename function to maa2mod
Old 10th April 2015, 13:59   #66  |  Link
Great Dragon
It works for me and produces identical result compare to original maa2+ 0.42 mod
Old 10th April 2015, 15:29   #67  |  Link
Overdrive80
Anime addict
Ok, I have incluided in LSharpAAF and runs fine on avisynth 2.6 (maybe problem with avisynth+??), I dont get error for yv12 input.
https://dl.dropboxusercontent.com/u/...arpAAF2.01.zip
Old 10th April 2015, 18:35   #68  |  Link
Great Dragon
No errors this time but the script still does nothing. Picture remains the same no matter what aatype I choose.
So maybe it has some Avisynth+ compatibility issue.
Old 5th June 2015, 17:59   #69  |  Link
real.finder
this will work in both avs and avs+
MAA2 v0.432 mod https://pastebin.com/8qz1kUbM
try it with
maa2(mask=-100, maskt=2, ss=3)
ss=3 is good for noisy source
See My Avisynth Stuff
Old 9th August 2015, 02:24   #70  |  Link
kuchikirukia
If I rewrite my Santiag v1.6 to use Resize8 for the frame shift instead of the internal Spline36Resize, will it avoid the chroma shift bug in the internal resizers? Or is that already taken care of in the frame shift?
kuchikirukia is offline   Reply With Quote
Old 9th August 2015, 17:42   #71  |  Link
cretindesalpes
cretindesalpes's Avatar
Santiag doesn’t take any chroma shift bug into account. But you don’t need to rewrite it to use your own scaler. Just provide it as scaler_post argument in the call (it should have the same prototype as the standard avisynth scalers), or change the default value.
I’ll check how chroma location issues affect the final resizing and will publish a fix if required.
dither 1.28.1 for AviSynth | avstp 1.0.4 for AviSynth development | fmtconv r30 for Vapoursynth & Avs+ | trimx264opt segmented encoding
cretindesalpes is offline   Reply With Quote
Old 12th November 2015, 10:03   #72  |  Link
killerteengohan
Hey cretindesalpes, why is it when I try to use the Santiag v1.6 you posted "aa=24" parameter I get this error every time.
(The named argument "aa" was passed more than once to santiag_dir)
santiagv1.6.avsi, line 30
killerteengohan is offline   Reply With Quote
Old 17th November 2015, 10:15   #73  |  Link
cretindesalpes
Thanks, typo fixed.
antialiasing, fastlinedarken, lsf, lsharpaaf, sharpen
