8th December 2011, 21:26 | #7621 | Link |
Hi Madshi,
I only use sageTV; which is directshow based. It can use as a video renderers: "EVR", "VMR", and "System Default" (which will most likely NOT work with MadVR). I'm able to define any external DS mpeg2 decoder (like LAV Video) OR use SageTV's builtin mpeg2 decoder along with a dscaler deinterlace filter (all the old ones that used to come with dscaler). I might be able to use a dscaler deinterlace filter that's not part of the old dscaler package. My display refresh rate is 59.940hz. It can also do 60.000hz. I use 23hz (23.976 or as close as possible to it) for Blu-ray media. Please see sageTV configuration options in the screenshots below. It looks like it can use all the old school dscaler deinterlace filters; but, not with LAV Video; unless somehow sageTV allows a post-process DS filter to insert itself in the filtergraph that sageTV uses. EDIT: I just downloaded and installed Dscaler 5 mpeg2 DS filter. I didnt even know there was one! It has builtin IVTC. I can't wait to go home and try it!!! Last edited by mkanet; 8th December 2011 at 21:33. |
8th December 2011, 22:44 | #7622 | Link | ||
The standard DScaler MPEG2 decoder does not do proper/complete IVTC. Only the DScaler IVTC Mod does. You can find it at AvsForum. I guess we're OT here, though, so I'll stop discussing that here. If you do a search on DScaler IVTC Mod you should find all the help that you need. |
9th December 2011, 05:06 | #7623 | Link | |
Problem finally resolved!! Smooth as silk video
All:
I apologize for bringing this forum thread off topic. I want to thank nevcairiel and madshi for all your help and time. I really means a lot to me. There is no more stutter!!! Dscaler IVTC mod mpeg2 decoder can handle removing 3:2 pulldown from weird TV movie encodings that have quickly changing framerates; and, restore it properly to 23.976fps framerate.. It also knows what to do for when there's interlaced/progressive Video content. Dscaler settings: 3. 3:2 playback smoothing= Disabled 4. Inverse Telecine= Enable only if IVTC flags are found 5. Adjust FPS if Any Telecined Film=Set to 23.976/24 FPS I am using Reclock's VBscript to change my display automatically to 24.000hz when "film" material is detected and fine tunes 23.976fps to original framerate at 24.000fps; and also restores original audio pitch/speed (resampled audio still sounds great). When Video content is detected, Reclock changes the display to 59.940hz/59.940fps Of course, I still use LAV video for everything else; just not mpeg2. Quote:
9th December 2011, 15:28 | #7624 | Link | |
Any idea why this is ? |
9th December 2011, 18:40 | #7625 | Link |
Hi nev,
Just one tiny issue I notice with the wvc1 cuvid decoder in LAV Video. When seeking, the image becomes corrupt / shows lots of blocky squares briefly. With ffdshows wvc1 decoder there is no such corruption on seek, and with lav video with cuvid for vc1 disabled there is no such corruption either, only with cuvid vc1 decoder enabled. Could it be an nvidia issue, or something with the way you're handling something in the cuvid implementation. I'm on Win 7, using NVidia GTX 295. It quickly clears itself up but noticible nonetheless. If interested in looking at this at some point, and you need more input from me let me know. Last edited by mark0077; 9th December 2011 at 18:47. |
9th December 2011, 18:54 | #7627 | Link |
NV12 gives you hardware accelerated (DXVA/2) deinterlacing with EVR on ATI (not sure if on Nvidia you'd use CUVID anyways and it's deinterlacing). RGB32 output you lose that deinterlacing through DXVA/2 with EVR but gain dithering I believe which should reduce banding, also with YADIF software deinterlacing, you can use that, so it's a win win to use RGB32 when using EVR IMO. If I'm missing something, hopefully someone should correct/fill me in.
MPC-HC/MPC-BE, Lav Filters, MadVR CPU: AMD Ryzen 5 1600, Video: AMD Radeon RX Vega 56 -> TCL S405 55", Audio: Audio-Technica M50S |
9th December 2011, 19:03 | #7628 | Link |
I use CUVID with vector adaptive deinterlacing for everything it supports, I don't think DXVA is even being used. I'll try RGB32 as you suggest and see if it improves the banding.
For some reason I need the nVidia Control Panel set to output 0-255, otherwise I get grey blacks - maybe this exacerbates the problem. Strangely, my Xbox 360 needs to be set to "Standard" (16-235) to avoid crushed blacks. No idea why they're different. |
9th December 2011, 19:42 | #7629 | Link |
Just dropped by to say Merry Christmas Nev. Great Job on this nifty filter.
oh and Merry Christmas everyone.
Motherboard: GIGABYTE GA-990FXA-D3 Processor: AMD FX 8150 Black Edition 8-core @3.6 Ghz. RAM: G-Skill Ares 16GB dual channel DDR3. GPU: 2X Crossfire AMD RADEON HD 6850. OS: Windows 7 Utlimate x64. |
9th December 2011, 19:47 | #7630 | Link |
nev, may I ask what method does LAV Video / Audio use to keep audio / video in sync.
The reason I ask, is that I have many DVDs that I have converted to mkv over the years, and I know the DVDs themselves were badly made in the first place with most video / decoders showing a noticeable audio blip / stutter at some points such as chapter changes. I am testing with one mkv today and am delighted to see seeking so accurate and fast with the latest lav filters. But lav video / audio still give the frame stutter / jump, and audio blip / buzz at at the same areas as other decoders. I can actually get rid of the audio blip / buzz sound by disabling LAV Audios a/v sync correction setting but of course things get noticibly out of sync then. I assume its this a/v sync feature of other decoders I have used that also causes the blip / stutter effect. So my question really is, is it somehow possible to make corrections to a/v desync like this, less noticible, like a way of more slowly bringing a/v back to sync perhaps rather than in one chunk? |
9th December 2011, 20:24 | #7631 | Link | |
9th December 2011, 20:25 | #7632 | Link |
There is nothing to fix. If there is a gap or overlap in the timestamps, you will hear it. Personally i rather have one glitch rather then a few smaller glitches spread out over a few seconds.
10th December 2011, 11:54 | #7633 | Link |
OK, I've just tested this by comparing to my PC monitor upstairs. The TV when receiving 16-235 has washed out colours but when receiving 0-255, it has black crush. I wonder if it's to do with the TV's brightness and contract settings? I'm sure I calibrated according to Lagom's LCD test website but maybe it needs adjusting.
10th December 2011, 13:14 | #7635 | Link | |
Disable float output, and everything is fine.
10th December 2011, 14:45 | #7639 | Link | |
The only difference is that MPC-HCs decoder by default downmixes AC3 to stereo, and LAV Audio doesn't. Most XP drivers have issues with 5.1 Float audio, while they can deal with Stereo just fine. I just changed it that Float is disabled by default when running on XP, so users running a legacy OS stop bothering me.
LAV Filters - open source ffmpeg based media splitter and decoders Last edited by nevcairiel; 10th December 2011 at 15:03. |
10th December 2011, 15:08 | #7640 | Link | |
MPC-HC crashes when trying to access the Dscaler Mpeg decoder settings (well known problem, reason is DEP) and if I change the settings in Graphstudio, they don't seem to retain. Have you find a way to exclude your player from DEP ? |
