7th November 2011, 08:26 | #6822 | Link |
I did not notice any problems with the file, seems to play just fine.
7th November 2011, 09:28 | #6823 | Link | |
Did you finally had the time to take a look at that video? Thanks a lot. |
7th November 2011, 09:51 | #6824 | Link | |
"Mixer→output speakers configuration→2/0/0-stereo" is my default ffdshow audio decoder configuration,it works fine with that sample. If I unckeck "Mixer" in ffdshow audio decoder configuration,it has the same performance with LAV Audio Decoder(part of the audio has disappeared,audio and video are not synchronized). Thank you nev for looked into that sample. |
7th November 2011, 19:35 | #6827 | Link |
LAV Filters 0.39
LAV Splitter - Fixed a bug that caused MPEG-2 and VC-1 parsers to produce wrong timestamps after a seek - Fixed playback of raw .h264 files LAV Video - NV12 is now the preferred YUV 4:2:0 output format - Fixed handling of the "As Input" RGB output setting - Improved VP6 cropping - Don't report completely progressive movies as interlaced to the renderer - Fixed playback of some broken MPEG-2 MKV muxes - RGB will now by default be offered as Bottom-Up instead of Top-Down for improved compatibility Before anyone asks again "Why NV12?" - its quite simple: Hardware post-processing usually requires the video to be in NV12, and especially on ATI only NV12 is accepted. Since there are no downsides to using NV12, it just makes more sense. Another quick note, as a consequence of now trying to figure out if a movie is interlaced or not, the option to disable interlaced flagging has been removed. Also, if you find a movie that was deinterlaced properly before, but now fails, please report those. Have fun.
7th November 2011, 19:52 | #6829 | Link | |
I try since two years with mpc-hc or ffdshow and it doesn't work. (I have gtx285) To use IVTC the only thing that works is the use of avisynth IVTC filter like decomb or TIVTC. Do you expect to add IVTC filter in madvr? |
7th November 2011, 20:11 | #6831 | Link | |
I didn't really know what you wanted. Its already possible to change it on the fly. Change the option, new delay applies (after clicking apply). If you want even better "on the fly", use MPC-HCs delay option, you can just press the numblock +/- keys to change it.
7th November 2011, 20:33 | #6832 | Link |
"Orchestra (Long) (Lossless)" and "Orchestra (Short) (Lossless)" from here are reported as interlaced during playback (and even on that website) but they drop and delay a lot of frames using deinterlacing (madVR 0.78) and look a lot better without deinterlacing, so I assume they are progressive.
Anything the splitter/decoder can do here or were they just encoded wrong? Btw, nothing new in 0.39, is the same in 0.38. |
7th November 2011, 20:53 | #6833 | Link |
Yes, you are right it works. It wasn't working for me because I had ffdshow audio processor after lav audio, I have that principally for audio downmix and volume booster. I by default disable audio switcher module as I can already do audio delay on lav audio. Thanks for the help.
7th November 2011, 21:10 | #6834 | Link |
DXVA does do IVTC, kind of, but with limitations. There are 2 key problems with DXVA IVTC, from what I can see:
(1) The current VMR, EVR and madVR implementations of DXVA deinterlacing "blindly" trust the video bitstream flags. That works well for some DVDs/broadcasts, but not for all. The better solution would be to distrust the flags. This is currently not done by any renderer using DXVA, as far as I can say. I might implement that in madVR in a future version. (2) There's no support for decimation in DXVA1/2, so the output will be 60p, not 24p. I've seen that there may be some sort of support for frame rate changes and maybe decimation in DXVA-HD, but I'm not 100% sure. Anyway, this is probably a bit out of topic here, so let's not let get this into a lengthy discussion. |
7th November 2011, 23:41 | #6835 | Link |
all my compares are riddles so please try to decipher them yourselves :) It is about Time Join the Revolution NOW before it is to Late ! http://forum.doom9.org/showthread.php?t=168004 |
8th November 2011, 01:39 | #6836 | Link |
I had some trouble playing this file: http://www.mediafire.com/?t52j52cp1v4gw96 (xvid AVI with max_bframes 0)
with MPC-HC - LAV Splitter, Video, Audio and madVR. I can play the file with other renderers (Haali, EVR etc.) But I wanted to be able to use madVR with Lav Filters so I started trying different settings. I narrowed it down to the 'Threads' setting in the LAV Video Decoder. I can play the file If I set threads to '1' aything else is a no go. Am I the only one with this strange behaviour? |
8th November 2011, 06:27 | #6837 | Link |
hi nev.
My friend claims that whenever he muxes something large with mkvmerge, the resulting mkv file is unseekable with lav splitter. It appears there is nothing remarkable about his mkvmerge settings, but I may be wrong about that. He muxes with an mkvmerge build for linux. Is there anything in lav splitters mkv handling that could result in problems with files over 4 gigs? I know this isn't a lot to go on, but it is hard to get samples for very large files. Haali and mpc matroska filter have no issues with these files. |
8th November 2011, 07:49 | #6839 | Link |
I cannot reproduce any issues with the 2 10-bit samples i happen to have on my laptop with me.
