22nd May 2007, 21:29 | #1281 | Link |
Software Developer
I just noticed a bug with ffdshow and anamorphic video!
The video was encoded with Xvid at an resolution of 688x560 and a PAR auf 140:129. The resulting video plays 100% fine at 4:3 in both MPlayer and VLC Media Player. Unfortuantely this is what happens with MPC + ffdshow: Tested with ffdshow-tryouts revision 1187. Also I use the latest Haali Renderer. As soon as I use the XviD Decoder-Filter instead of ffdshow, it works okay in MPC too. I uploaded a sample: Download: http://www.mytempdir.com/1335646 Password: doom9
Go to https://standforukraine.com/ to find legitimate Ukrainian Charities 🇺🇦✊ Last edited by LoRd_MuldeR; 22nd May 2007 at 21:34. |
22nd May 2007, 22:31 | #1284 | Link | |
Software Developer
ffdshow + VMR9 (Renderless): Okay ffdshow + Overlay: Okay ffdshow + Haali Renderer: Broken (see screenshot above) Xvid Decoder + VMR9 (Renderless): Okay Xvid Decoder + Overlay: Okay Xvid Decoder + Haali Renderer: Okay Any ideas ???
Go to https://standforukraine.com/ to find legitimate Ukrainian Charities 🇺🇦✊ Last edited by LoRd_MuldeR; 22nd May 2007 at 22:34. Reason: typo |
22nd May 2007, 22:32 | #1285 | Link | |
Also Haali uses GPU PS2 for it's calculations if I'm not mistaken, so updating your video card drivers may help.
I'm sick of following my dreams. I'm just going to ask them where they're goin', and hook up with them later. ---Mitch Hedberg Last edited by GmorG McRoth; 22nd May 2007 at 22:36. |
22nd May 2007, 22:36 | #1286 | Link |
Software Developer
I already did that before I wrote the bug report.
22nd May 2007, 22:43 | #1287 | Link |
I see you are using MPC moded by casimir, I used last MPC made by drevil_xxl, maybe here is problem.
I'm sick of following my dreams. I'm just going to ask them where they're goin', and hook up with them later. ---Mitch Hedberg |
22nd May 2007, 22:49 | #1288 | Link | |
Software Developer
2. As soon as I enable "resize" in ffdshow the problem disappears and (now it gets strange) keeps gone, even if I disable resize again. Once I re-open the video, the problem is back...
22nd May 2007, 22:53 | #1289 | Link |
Wicked XD
ok then, who binary of FFDShow you have installed? I used ffdshow_rev1187_20070520_clsid.exe
22nd May 2007, 22:56 | #1290 | Link | |
Software Developer
// EDIT I just went back to ffdshow_beta2a_20070322_clsid.exe and the problem is gone // EDITē Another attempt with ffdshow_rev1187_20070520_clsid.exe and problem returns...
Go to https://standforukraine.com/ to find legitimate Ukrainian Charities 🇺🇦✊ Last edited by LoRd_MuldeR; 22nd May 2007 at 23:02. |
22nd May 2007, 23:22 | #1291 | Link | |
Turkey Machine
Revision 1186 - Directory Listing Modified Sun May 20 14:47:28 2007 UTC (2 days, 7 hours ago) by h_yamagata Bug fix The following encoders only work for input with specific frame rates: MPEG4, MPEG 1 and MPEG 2. The accepted frame rates are 25*2^n. For example: 6.25, 12.5, 25, 50, 100. Code:
Revision 1189 - Directory Listing Modified Mon May 21 11:32:49 2007 UTC (34 hours, 47 minutes ago) by h_yamagata minor fix of rev 1186 (revert Tffvfw.cpp and move the change to TvideoCodecLibavcodec.cpp) Code:
Revision 1192 - Directory Listing Modified Tue May 22 13:12:23 2007 UTC (9 hours, 7 minutes ago) by h_yamagata more fix about rev 1186 issue.
On Discworld it is clearly recognized that million-to-one chances happen 9 times out of 10. If the hero did not overcome huge odds, what would be the point? Terry Pratchett - The Science Of Discworld |
23rd May 2007, 00:07 | #1292 | Link | |
ffdshow/AviSynth wrangler
That needs some investigation, but I was busy this evening with building a new version of GCC - I'll look into it tomorrow. EDIT: I guess I'll better wait with checking in the new AviSynth filter until I've fixed that one. np: RJD2 - Chicken-Bone Circuit (Deadringer)
now playing: [artist] - [track] ([album]) Last edited by Leak; 23rd May 2007 at 00:16. |
23rd May 2007, 02:14 | #1293 | Link |
The cpu test introduced in revision 1151 is faulty on x64.
The file in question is Tconfig.cpp. I don't quite understand the #ifndef __GNUC__ on line 212; it seems to me that IsProcessorFeaturePresent is always the right way to test for processor features on Windows. But no matter; I think the code as it stands is trying to enable MMX on x64. Although the SSE/SSE2/SSE3/SSSE3 features get tested explicitly, and disabled if they fail, MMX and MMXEXT are never tested, and so, I suspect, never disabled. Forcibly disabling them (available_cpu_flags &= ~FF_CPU_MMX; available_cpu_flags &= ~FF_CPU_MMXEXT restores ffdshow to working order, as does using IsProcessorFeaturePresent (presumably because IsProcessorFeaturePresent knows that x64 has no MMX). |
23rd May 2007, 04:30 | #1295 | Link |
URL http://www.comq.ru/user/alex/pirates2/pirates2.mp4
Mpeg4AVC HighProfile video. Picture is broken using ffdshow, mplayer or KMP. Look normal using CoreAVC 1.2. |
23rd May 2007, 07:38 | #1296 | Link | ||
http://forum.doom9.org/showthread.ph...43#post1001143 Quote:
EDIT: I found an mpg1 (from VCD) which also produces the same bug, when libavcodec is selected at the Codecs in MPG1 ... Last edited by chros; 23rd May 2007 at 08:24. |
23rd May 2007, 07:48 | #1297 | Link | |
No matter, if I remux to mkv. Does the whole file produce this, or only this splitted chunk? PS: the AR is wrong ... |
23rd May 2007, 08:14 | #1298 | Link | |
I was just surprised about ffdshow can't play it normally, so I report about this bug here. |
23rd May 2007, 08:27 | #1299 | Link | |
x264 developer
23rd May 2007, 08:27 | #1300 | Link | |
Altough my MPC is sometimes crashing with the 1080i content (so maybe my Windows is rather old...) |
