Old 21st February 2021, 12:19   #1  |  Link
YaBoyShredderson
Can i add codecs to staxrip?
I downloaded a lossless video codec called ut video, but i have no idea how to actually use it. All i need to do is convert variable framerate footage from my phone into constant frame rate without losing quality, to be edited im davinci resolve. How do i use this codec? I think ffmpeg will use it but i dont actually know how to use it.
YaBoyShredderson is offline   Reply With Quote
Old 21st February 2021, 15:43   #2  |  Link
stax76
stax76's Avatar
The encoder is included:
ffmpeg > UT Video
Decoders are also included.
Old 21st February 2021, 17:34   #3  |  Link
YaBoyShredderson
ffmpeg > UT Video
I dont know how to use ffmpeg even a little bit.
Old 21st February 2021, 17:35   #4  |  Link
YaBoyShredderson
ffmpeg > UT Video
Ok nevermind, i found it. I thought u meant i had to use ffmpeg. Thanks.
Old 21st February 2021, 17:39   #5  |  Link
YaBoyShredderson
I cant find how to change the frame rate however. It comes out as constant, but not the framerate i want.
codec, editing, ffmpeg, lossless, staxrip
