Old 15th May 2018, 04:04   #6121  |  Link
foxyshadis
ангел смерти
foxyshadis's Avatar
Originally Posted by poisondeathray View Post
I'm going to call this issue that Selur brought up, the 8bit=>10bit , 10bit encoding a bug. Both x264 , x265 are affected. You can see similar problem on other full range DSLR clips.
Another possibility: It could be an artifact of the decoder, or even of the spec. I'd check against Mainconcept, or one of the GPU encoders & decoders. x264/x265 and ffmpeg/libav are so ubiquitous that it's hard to test anything else.
There are four boxes to be used in defense of liberty: soap, ballot, jury, and ammo. Please use in that order. ~ Ed Howdershelt
Old 15th May 2018, 15:53   #6122  |  Link
poisondeathray
The testing routine used by selur converted back to 8bit to compare. A native 10bit waveform does not demonstrate the problem. But it's still a bizarre aggregation, and why this occurs at CRF 8 but not lossless.
I'll swap out and double check the decoders and encoders and do some more tests when I have more time
Old 18th May 2018, 13:52   #6123  |  Link
Barough
Barough's Avatar
x265 v2.7+351-d3b714bd5471 (GCC 7.3.0, 32 & 64-bit 8/10/12bit Multilib Windows Binaries)
https://bitbucket.org/multicoreware/x265/commits/all
Old 21st May 2018, 12:25   #6124  |  Link
Ashok Kumar Mishra
x265 v2.8 released
Version 2.8
Release date - 21/05/2018
New features
1. ption:`--asm avx512` used to enable AVX-512 in x265. Default disabled.
For 4K main10 high-quality encoding, we are seeing good gains; for other resolutions and presets, we don't recommend using this setting for now.
2. ption:`--dynamic-refine` dynamically switches between different inter refine levels. Default disabled.
It is recommended to use ption:`--refine-intra 4' with dynamic refinement for a better trade-off between encode efficiency and performance than using static refinement.
3. ption:`--single-sei`
Encode SEI messages in a single NAL unit instead of multiple NAL units. Default disabled.
4. ption:`--max-ausize-factor` controls the maximum AU size defined in HEVC specification.
It represents the percentage of maximum AU size used. Default is 1.
5. VMAF (Video Multi-Method Assessment Fusion)
Added VMAF support for objective quality measurement of a video sequence.
Enable cmake option ENABLE_LIBVMAF to report per frame and aggregate VMAF score. The frame level VMAF score does not include temporal scores.
This is supported only on linux for now.
Encoder enhancements
1. Introduced refine-intra level 4 to improve quality.
2. Support for HLG-graded content and pic_struct in SEI message.
Bug Fixes
1. Fix 32 bit build error (using CMAKE GUI) in Linux.
2. Fix 32 bit build error for asm primitives.
3. Fix build error on mac OS.
4. Fix VBV Lookahead in analysis load to achieve target bitrate.
Ashok Kumar Mishra is offline   Reply With Quote
Old 21st May 2018, 13:23   #6125  |  Link
LigH
LigH's Avatar
x265 2.8+1-478bfe2b7673 (stable release, GCC 7.3.0, Win32+Win64)
last few fixes in analysis mode
New German Gleitz board
Old 21st May 2018, 19:20   #6126  |  Link
user1085
Do you also have a Linux build?
user1085 is offline   Reply With Quote
Old 21st May 2018, 20:00   #6127  |  Link
Sagittaire
Testeur de codecs
Sagittaire's Avatar
Originally Posted by Ashok Kumar Mishra View Post
Version 2.8
VMAF is objective metric from Netflix:
https://medium.com/netflix-techblog/...c-653f208b9652
Really good idea to impliment this metric. VMAF seem have really good correlation with HVS. Why not include PSNR-HVS-M (seem have really good correlation too)?
Possible to introduce tune profil for VMAF or PSNR-HVS-M like for PSNR and SSIM?
Le Sagittaire ... ;-)
1- Ateme AVC or x264
2- VP7 or RV10 only for anime
3- XviD, DivX or WMV9
Old 21st May 2018, 21:08   #6128  |  Link
jd17
I would like that too!
jd17 is offline   Reply With Quote
Old 21st May 2018, 21:26   #6129  |  Link
Asmodian
Any tune profile for VMAF should probably be the default, given that it correlates very well with the human visual system.
madVR options explained
Old 22nd May 2018, 07:05   #6130  |  Link
user1085
Anyone know how to build x265 2.8 with AVX512 enabled on Ubuntu?
I built x265 from 2.8 release tarball but x265 -V doesn't show me it's using AVX512 capability on a Intel Xeon
x265 [info]: HEVC encoder version 2.8
x265 [info]: build info [Linux][GCC 7.3.0][64 bit] 10bit
x265 [info]: using cpu capabilities: MMX2 SSE2Fast LZCNT SSSE3 SSE4.2 AVX FMA3 BMI2 AVX2
Here's the CPU info
uso@xvmub:~/x265_2.8/build/linux$ lscpu
Architecture:        x86_64
CPU op-mode(s):      32-bit, 64-bit
Byte Order:          Little Endian
CPU(s):              2
On-line CPU(s) list: 0,1
Thread(s) per core:  2
Core(s) per socket:  1
Socket(s):           1
NUMA node(s):        1
Vendor ID:           GenuineIntel
CPU family:          6
Model:               85
Model name:          Intel(R) Xeon(R) Platinum 8168 CPU @ 2.70GHz
Stepping:            4
CPU MHz:             2693.677
BogoMIPS:            5387.35
Virtualization:      VT-x
Hypervisor vendor:   Microsoft
Virtualization type: full
L1d cache:           32K
L1i cache:           32K
L2 cache:            1024K
L3 cache:            33792K
NUMA node0 CPU(s):   0,1
Flags:               fpu vme de pse tsc msr pae mce cx8 apic sep mtrr pge mca cmov pat pse36 clflush mmx fxsr sse sse2 ss ht syscall nx pdpe1gb rdtscp lm constant_tsc rep_good nopl xtopology cpuid pni pclmulqdq vmx ssse3 fma cx16 sse4_1 sse4_2 movbe popcnt aes xsave avx f16c rdrand hypervisor lahf_lm abm 3dnowprefetch pti tpr_shadow vnmi ept vpid fsgsbase bmi1 hle avx2 smep bmi2 erms rtm mpx avx512f avx512dq rdseed adx smap clflushopt avx512cd avx512bw avx512vl xsaveopt xsavec xsaves
Old 22nd May 2018, 07:22   #6131  |  Link
LigH
LigH's Avatar
AVX-512 is only enabled if you explicitly add --cpu avx512 to the command line; without it is not even checked for in CPU capabilities, apparently... so try:
x265 --cpu avx512 -V
Is it reported then?
__
No, I was a) quite confident that Linux users know how to install and use GNU compilers (it's good enough documented on Multicoreware's Bitbucket), and b) not sure how portable one build under one specific distro is. Windows builds are quite portable, and knowledge about compiling from sources is probably not so common among Windows users.
Old 22nd May 2018, 07:31   #6132  |  Link
user1085
__
No worries I figured out how to compile, didn't see the instructions earlier
Re:avx512, this worked for me
./x265 --asm avx512 -V
Old 22nd May 2018, 07:34   #6133  |  Link
LigH
LigH's Avatar
Oops, should have read the manual, "asm" instead of "cpu".
Thank you for confirming anyway.
Old 22nd May 2018, 20:53   #6134  |  Link
benwaggoner
VMAF is our least-bad metrics, but it definitely has limitations and blind spots. It doesn't catch banding well, particularly in lower luma. It is only trained on x264 8-bit SDR, and without a lot of different psychovisual tuning, so it doesn't do a great job of discriminating between some kinds of psychovisual tradeoffs. And it's never seen the newer kind of artifacts in HEVC, so it doesn't know about customer preference between them. It doesn't know about <300 Kbps or >1080p. It was only tested against a particular display at 3x screen heights. The temporal comparison base metric is pretty weak.
It's the best thing we've got, but it definitely isn't perfect.
Also, the question of how to go from scores for individual frame to a per-clip score remains unanswered. A file that varies from 30-80 VMAF is going to be perceived as a lot worse than one that varies from 50-60, but the mean of the frames won't show any difference.
That's not a VMAF specific problem; it applies to all metrics where we are trying to figure out quality over time from individual frame metrics.
Ben Waggoner
Principal Video Specialist, Amazon Instant Video
My Compression Book
Amazon Instant Video is hiring! PM me if you're interested.
Old 23rd May 2018, 08:32   #6135  |  Link
jd17
Wait a minute.... The Amazon video specialist does NOT think Netflix's metric is the holy grail?
I'm shocked! Shocked!
Kidding of course... I just think someone had to say it.
I do think Netflix abuses VMAF findings though.
Bitrates between 2000kbit/s and 3000kbit/s for 1080p x264 video are just not good. No matter what VMAF tells you...
Old 23rd May 2018, 08:39   #6136  |  Link
LigH
LigH's Avatar
The main limit is probably a bandwidth cap; restricted VBR. Some scenes will have a demand that can't be satisfied in a streaming usage. But quality tests will often be done for a local playback usage, I guess...
Old 23rd May 2018, 09:11   #6137  |  Link
jd17
Is this a comment on my complaint about the 2000-3000kbit/s?
If that is the case - I do not think bandwidth cap is a factor.
I was referring to the "highest" quality Netflix streams at 1080p for some content. You cannot get more, no matter how high your bandwidth is.
This not only used to be much higher in the past, it still is for some content with more grain.
Additionally, Amazon streams significantly higher 1080p AVC bitrates across the board, so bandwidth can hardly be a limitation...
I think it's just Netflix saving bandwidth, because most people either watch this stuff on smaller screens with a viewing distance too large, or they just do not care / do not see the flaws...
Either way - Netflix abuses it.
Old 23rd May 2018, 09:22   #6138  |  Link
nevcairiel
The bitrate you target is really not related to the metric you use. You can use a metric to optimize encoding settings for any target bitrate to get the best out of the bits available to you.
nevcairiel is online now   Reply With Quote
Old 23rd May 2018, 10:20   #6139  |  Link
jd17
You might be misunderstanding what I tried to say...
I know how metrics work.
I merely tried to point out that I think Netflix is abusing their internal VMAF findings to justify streaming at much lower bitrates.
I would argue they lowered their bitrate target (at least partly) as a result of their use of VMAF.
No matter how clean your video is, 1080p x264 will not be good at 2000-3000kbit/s, especially in the backgrounds.
Maybe you understand where I am coming from when you look at this blog:
https://medium.com/netflix-techblog/...n-7e99442b62a2
In theory, the arguments in that blog are well reasoned.
Use low bitrates for cartoons and clean video, use high bitrates for lots of movement, grain, and so on...
However, especially within the last year or so (look at recent releases of Netflix series for instance), they have moved to the aforementioned low bitrates as highest 1080p target bitrate. On live action video!
While 2000-3000kbit/s is indeed completely fine for Cartoon, it is not for live action video.
Is that VMAF's fault? Of course not.
But I think Netflix saw that the VMAF scores are not too bad for 1080p video at those bitrates, so they decided to lower their targets accordingly.
Sorry for the long off-topic discussion...
Originally, I just wanted to make a little joke and complain about Netflix's quality in the process...
I did not mean for it to drift so far away from x265!
Old 26th May 2018, 06:36   #6140  |  Link
foxyshadis
ангел смерти
foxyshadis's Avatar
Sorry guys, this was getting way too offtrack. AVX512 vs Threadripper has been moved to the PC Hardware forum.
