3rd January 2010, 17:30 | #821 | Link |
It doesn't support AVS unfortunately.
I've had some luck wrapping AVS files in VFAPI to make an AVI file and importing that into Vegas, but not always (I've only tried with DGIndex, not the paid version). Has anyone tried different methods to open up DG-NV files (wrapping them as an AVI I imagine) in Vegas (or in Adobe Premiere - it would likely be the same process)? |
3rd January 2010, 17:54 | #822 | Link | ||
4th January 2010, 04:40 | #825 | Link | |
Un-Registered User
Hey neuron2, get better soon! You're in my prayers.
4th January 2010, 04:40 | #826 | Link |
CLI for DGIndexNV
Because the documentation isn't done yet for DGIndexNV, and because I use the CLI inside a Zshell script (cygwin), I need to know if the syntax for DGIndexNV follows the syntax for DGIndex or for DGAVCIndex.
My new PNY GT240 card will arrive later in the week, so when it gets here, I'll be ready to install it and then use DGIndexNV. And yes, I'm ready to license as well. That part is already done. It will be nice having one program for both H.264 and MPEG-2 files. Thanks. |
4th January 2010, 10:05 | #827 | Link | |||
Plus, if I can get the NVidia card to do the decoding my hope is that the render speed will slightly increase, or at least be close enough to the intermediate codec render speed that it will make the use of an intermediate file totally unnecessary. Quote:
4th January 2010, 10:12 | #828 | Link |
i have an GeForce 8600GTS with the latest Nvidia drivers, but when i try to open a vc1 file with DGIndexNV (on the box - not remote) i get licence file missing. Also, when i open DGIndex from MeGui the DGIndexNV option is greyed out.
Can anyone help please? thx |
4th January 2010, 11:28 | #829 | Link |
DG Tools NV & Crashing NV Drivers
Hi @ll.
First of all a big Thx to Donald for creating such a useful Tool. But with exact this one i got a very BIG Problem. My Nvidia Driver crashes all the Time on using DG NG Tools. Code:
" Display Driver nvlddmkm stopped responding, has successfully recovered " Next one was reverting my Rockstable OC to Defaults witch makes no difference ( Maybe its because Win7 X64. HW is also ok, no RAM Problems or something like this. Machine is C2Q 9550 with 8 GB ram and Nvidia GTS260. NV Driver is the latest from NVidia Site (x64). Avisynth is V 2.5.8. Ive tested now so much things but i still dunno why it crashes. It encodes for some minutes well but thats it then.. After the Crash the Cuvid Server reports error because no more frameserving... Does anybody maybe have a suggestion? Thx in advance Chris Edit: I also checked the Speeds of the Graphics Card and all are default. Card was never OCd. CUDA Driver is 3.0.1 NV Driver is 195.55 Edit 2: I CHanged Driver to latest WHQL (195.62), same issues. I Checked the Web for that and found something about TDR but all different. (Problems while Gaming and so on) I also run Benchmarks on 3D Stress Tests to check if the Device Driver also crashes on 3D but nothing. (Furmark 1 hr Extreme Heat) .. Then sopme loops 3DMark Vantage but all flawless. So its Def. something with that CUDA thinggy. Last edited by MOS-Marauder; 4th January 2010 at 15:01. |
4th January 2010, 15:19 | #830 | Link | |
It causes my final render from Vegas to be between 20 and 40% slower than using UTVideo as an intermediate codec (although it is actually faster than if I use Lagarith as an intermediate codec). But that is something I may be able to optimize yet, and using the DGIndex-NV version may also resolve that problem (I will hopefully buy it soon). |
4th January 2010, 16:23 | #832 | Link |
I tried, but its the same. Normally i would use DGAVCIndex 1.0.9 and its DLLs but with that one i cannot use ArteHD or ARD/ZDF HD Streams in 720p.. .Crashes avisynth or playing app after exact 6 seconds.
Chris Last edited by MOS-Marauder; 4th January 2010 at 16:47. |
4th January 2010, 19:42 | #833 | Link |
JoeH a DG based framework for Vegas seems nice (also in terms of costs) but in your case i guess it's better to use a Native Vegas Plugin solution like that from Divide Frame
all my compares are riddles so please try to decipher them yourselves :) It is about Time Join the Revolution NOW before it is to Late ! http://forum.doom9.org/showthread.php?t=168004 |
4th January 2010, 20:21 | #834 | Link | |
I'll try to get some up-to-date manuals ready. |
4th January 2010, 20:51 | #836 | Link | |
license.txt? where is it supposed to come from? I have a genuine 8600 card and the drivers installed from the NVidia site. I have never seen/heard of a license.txt for it before. please elaborate. cheers |
4th January 2010, 21:07 | #837 | Link | |
http://neuron2.net/dgdecnv/dgdecnv.html |
4th January 2010, 22:28 | #839 | Link | |
http://forum.doom9.org/showthread.php?t=151159 |
