23rd August 2012, 07:15 | #2781 | Link |
It is probably again the usual misunderstanding.
It requires an Nvidia card which supports CUDA, because (simply said, despite possible exceptions?) only cards which support CUDA also have the PureVideo decoder chip in version VP2 (or better). But DGDecNV does not execute CUDA programs to decode. It only uses the PureVideo VP2(+) decoder chip features on these cards. Last edited by LigH; 23rd August 2012 at 07:19. |
24th August 2012, 00:03 | #2782 | Link |
Actually DGDecNV has 2 two different modes for decoding, from the manual:
Decode_Modes=0/1,0/1,0/1: The order of the parameters corresponds to AVC video, MPEG2 video, and VC1 video. A value of 0 selects CUVID decoding; a value of 1 selects CUDA decoding. For example, "Decode_Modes=0,1,0" causes CUDA to be used for MPEG2 video and CUVID for AVC and VC1 video. By default, CUVID is used for all video types.
(i have a tendency to drunk post) |
11th September 2012, 21:28 | #2783 | Link | |
Even with CUDA, it would be a lot of code for the 3 main formats. And more over, why would anyone use CUDA for decoding streams when you can access the the Video Processor (VP2..VP4..VP5) using CUVID which can decode these streams already and this all without even writing a single line of code to do the actual decoding ? |
11th September 2012, 22:06 | #2784 | Link |
When CUDA is used, it is not done 100% in CUDA. There is acceleration of some things but mostly it is done in the video driver software. The reason to need it is the rare occasion when the VP engine is broken for a particular stream's syntax. It's very rare.
15th September 2012, 17:17 | #2785 | Link |
when i use the driver that which come with my laptop (geforce g 105m -with cuda-) DGIndexNV work
but after i upgrade the driver (lastest one cuda 5.0.1 and tried cuda 4.2.1) i get error ERROR: cuInit failed (100) why? |
16th September 2012, 00:36 | #2786 | Link |
I don't understand what you mean by cuda drivers. You should install a video driver, not a cuda driver. Why do you talk about cuda drivers?
I do know that some older notebook graphics chipset drivers are not being updated to be compatible with the latest CUDA SDK. You simply cannot upgrade those video drivers without losing support. I cannot do anything if nVidia doesn't release compatible drivers. You can fall back to an earlier DGDecNV version build with CUDA 3, however. Sadly you can't have the latest versions of both the video driver and DGDecNV. Last edited by Guest; 16th September 2012 at 00:41. |
16th September 2012, 21:59 | #2787 | Link | |
but get error ERROR: cuInit failed (100) |
22nd September 2012, 01:42 | #2793 | Link | |
24th September 2012, 13:15 | #2795 | Link |
Here you go:
http://forum.doom9.org/showthread.php?t=165970 |
24th September 2012, 18:24 | #2797 | Link |
RedDwarf Fan
I think that I might of found an obscure bug in 2042.
I don't usually use the cropping feature and usually click no when I get prompted. However I did by mistake click yes and then quickly wanted to remove that by Entering the cropping selection dialogue and unticking the cropping and then clicking the X. I thought everything would be okay and I could then setup the cropping manually as usual. However, that didn't work. The dgi file shows the video dimensions as 1920 x1096! Which with my usual cropping setup of 8 left me with a green bar at the bottom and the resolution showing as 1920x1088, after cropping! I have repeated the steps with the same result. This was with a .h264 raw file. H.264 video 1920x1088. That is reported by DGIndexNV and is how it should be but MediaInfo reports 1920x1080. |
24th September 2012, 18:29 | #2798 | Link |
RedDwarf Fan
Ouch! I tested again but this time changed the cropping of the bottom to 16, from it's original 8 and now the resolution is shown as 1920x1104 in the dgi file. The cropping needs to be deselected for this to occur.
It's the same in the latest 2043rc1. |
