4th December 2009, 00:59 | #9763 | Link |
I recommend people try the DirectSound: ATI HDMI renderer and see how that works for you. Haven't crashed that one yet.
4th December 2009, 01:01 | #9764 | Link | |
4th December 2009, 01:10 | #9765 | Link |
Let me give you an idea...I pulled my Xonar out of my machine even though it works fine. I have a 5870 which is all I use now. I don't think it makes ANY sense whatsoever to use a card that's tied (officially) to only one player. Yes, albain has it working in ffdshow but it's likely to never be supported in PDVD9, for example. The ATI card is officially supported in PDVD9 and WinDVD 2010. And now of course with ffdshow. And the likelihood is that TMT3 is going to have to support it or risk falling behind. A single card that does all that or a dual card solution that adds heat, power consumption, and complication to your life. Plus the external HDMI cable chaining required. You decide what's better.
4th December 2009, 01:17 | #9766 | Link | |
Alternatively, you can go back one step (to the folder where the folder that contains that file is), and do a shift + right-click on the folder that contains the file you wanna register. Or you can just navigate to the file you want to register, and shift + right-click on it, and select "copy as path", and it will copy the full path of it, which you can then paste on the command prompt, quotes and all. Last edited by Andy o; 4th December 2009 at 01:20. |
4th December 2009, 01:19 | #9767 | Link | |
4th December 2009, 01:20 | #9768 | Link | |
The 5770 should be fine, right (I'm not planning to use it for any new games)? The only thing that worries me is the possible noise, but I heard that shouldn't be an issue for those cards? Some people also mentioned the advantage of having 1 dedicated card for the video and 1 dedicated card for the audio. I didn't quite get that though |
4th December 2009, 01:35 | #9769 | Link | |
4th December 2009, 01:47 | #9772 | Link | |
On another note... does anyone know if this will work in MediaPortal? Well it should, right? |
4th December 2009, 03:44 | #9774 | Link |
The ATI Cat 9.11 HDMI driver. Someone said the realtek driver is the same as the ATI one now, but, I don't think that's accurate from what I've seen. I just use the one from ATI. AFAIK, the realtek one still isn't capable of bitstreaming, even with ffdshow, but I haven't tried the latest realtek driver with the latest ffdshow. It'd be a good thing to try though. If I get a chance I can try them tomorrow.
4th December 2009, 07:57 | #9776 | Link | |
Media Control author
This will be difficult to figure it out : visual studio with ffdshow compiled in debug mode is required to get the exact location of the crash. Is there a developer/or compiler person who owns a radeon 5xxx ? |
4th December 2009, 08:07 | #9777 | Link |
Under ffdshow's video output, the tooltip for Standard under Input levels says that ffdshow automatically uses Full range for Fraps videos, even though it does not. The only way to get Full range is to select it, which is quite annoying having to change that setting back and forth, depending on what content is being decoded. Should be an easy fix, though.
4th December 2009, 08:59 | #9778 | Link |
I have a question that s not related to the new bitstreaming thing, hope thats ok :
When I play a movie which has True-HD audio MPC-HC does not load ffdshow. So after some testing I figured out that it has something to do with Haali Splitter. So I uninstalled Haali Splitter and enabled the internal TS filter in MPC-HC. Ater this FFdshow audio does load fine now. However, something is wrong with the decoding. I enabled all codecs in FFdshow and checked only 16-bit as output. I can see in the info of FFdshow (when playing the file) that True 5.1 decoding is active. However, the video stutters like hell. What could I be doing wrong here? |
4th December 2009, 09:13 | #9779 | Link | |
the number of channels may not be accurate. Have you tried the last beta 46 from the earlier post ? Because I also brought some changes to decoding mode |
