Old 14th August 2011, 08:30   #1  |  Link
gwdkwd
Fraps, x264, YV12, avisynth, and youtube
Hello.
I would like to convert my fraps videos to x264 without any colorspace conversion.
I hear that fraps does indeed record in yv12, but that it's decoder itself does not decode in yv12, thus forcing a colorspace conversion when converting to x264. So the colors end up worse.
Is there a way around this? I want to upload my fraps videos to youtube while sacrificing the least possible color quality.
I have looked around for solutions, but none of them have worked so far. Take this one, for example:
LoadPlugin("ffms2.dll")
LoadPlugin("ColorMatrix.dll")
FFVideoSource("FRAPS capture.avi", cache=false)
ColorMatrix(inputFR=true)
I have tried using this avisynth script, and the video does not open and I get the following error:
"Avisynth open failure:
ColorMatrix: input to filter must be YV12 or YUV2!"
I have both plugins installed (that is, put into the avisynth plugin folder) and have tried the script with fraps videos that were recorded with "force lossless RBG capture" ticked both on and off.
If it's relevant to any of this, I have ffdshow installed.
Thank you for any help you can provide.
gwdkwd is offline   Reply With Quote
Old 14th August 2011, 23:59   #2  |  Link
mariush
You can configure fraps to encode in RGB24 , then use x264 to encode to YUV 4:4:4 which should be almost lossless. However, Youtube will re-encode your video to YV12, 4:2:0 I'm not sure Flash and video cards support hardware decoding of YV 4:4:4 so probably all popular websites will convert to YV12 anyway... unless you host the video yourself it's probably not going to do you any good.
Have you tried using the plain old AVISource ? As the coded is Video For Windows, it should work...
mariush is offline   Reply With Quote
Old 15th August 2011, 09:36   #3  |  Link
Blue_MiSfit
Derek Prestegard IRL
Blue_MiSfit's Avatar
I'd bring it down into yv12 inside avisynth. Since it has to go to yv12 eventually, you might as well do it at a stage where you have control over the process.
FFVideoSource("foo.avi") #Assuming this returns RGB24 or RGB32
ConvertToYV12(matrix="rec709") #Assuming you want to make an HD output? Use matrix="rec601" otherwise.
Derek
Old 17th August 2011, 00:01   #4  |  Link
PhrostByte
Grand Fruitioner
PhrostByte's Avatar
If ColorMatrix is giving you an error, you're probably recording in lossless mode (which is true RGB24). Untick that box and you'll get YV12. Use Info() to see what the video is currently.
Using the YV12 directly is a little problematic -- FRAPS uses custom YUV coefficients, so ColorMatrix won't be able to fix your colors to what Youtube expects (TV-range Rec.601 -- even for HD). Also, FRAPS YV12 is TV range, not full range.
Lanczos4, Spline36, what!? Don't know how to pick a resizer? Take a look at my kernel visualizations.
Want a high-quality, gamma-aware resizer? Check out my ResampleHQ filter.
PhrostByte is offline   Reply With Quote
Old 17th August 2011, 11:47   #5  |  Link
gwdkwd
Thanks for the info, that will help. Although specifically, I want to retrieve the yv12 data from the fraps video, so I can avoid the color shift as much as I can, when encoding with x264.
Info is telling me that the colorspace is in RGB32. I am certain that I'm not recording in lossless mode.
So, is there any use to using the fraps yv12 data for youtube uploads, then?
Old 17th August 2011, 23:24   #6  |  Link
TheFluff
Excessively jovial fellow
What version of FFMS2 are you using? Current FFmpeg versions have a broken version of a function used to determine the "best" (least lossy) colorspace to convert to, and the Fraps decoder uses the somewhat unusual and deprecated pixel format YUVJ420P (which in Avisynth terms translates to fullrange I420), so it's entirely possible that something goes wrong during the output format decision and FFMS2 decides to output RGB instead. Very recent FFMS2 beta builds have a workaround for this bug, so try that if you haven't already.
Old 25th August 2011, 00:47   #7  |  Link
gwdkwd
Thanks. I downloaded the latest version and it's telling me the colorspace is yv12 now. Where do I go from there?
Old 25th August 2011, 01:33   #8  |  Link
PhrostByte
Grand Fruitioner
PhrostByte's Avatar
I recommend using AviSource to let FRAPS give you RGB. It's the only way to get correct colors.
Old 26th August 2011, 12:30   #9  |  Link
TheFluff
A pointless conversion to RGB and back was exactly what he wanted to avoid in the first place. Also, FFmpeg's fraps decoder explicitly sets its output as fullrange, so I'm not sure where you got the idea that fraps in YV12 is always TV range. Maybe the VFW decoer converts to that?
Old 26th August 2011, 18:53   #10  |  Link
PhrostByte
Grand Fruitioner
PhrostByte's Avatar
The problem is that ColorMatrix will not be able to correct your colors to the TV-range Rec.601 that YouTube expects.
FFmpeg's output is using none of the usual YUV coefficients. I don't know if this is a FFmpeg bug or if FRAPS itself just uses something weird.
Old 26th August 2011, 20:07   #11  |  Link
zerowalker
Hmm, i am very interested in this aswell, as i am also trying to prevent the stupid YV12->RGB32->YV12 Conversion:S
I have tried Directshowsource, but it´s the same thing, it decodes as TV Range (i think) when it should be PC Range (or if it´s vice versa).
zerowalker is offline   Reply With Quote
Old 26th August 2011, 22:39   #12  |  Link
TheFluff
FFmpeg does nothing re: the actual sample values. AFAICT the entire FRAPS decoder is basically just a Huffman decoder with a few funny twists on it, so whatever values FRAPS put in there should get back out in the same state. How do you know it's not using the usual coefficients, though?
Old 28th August 2011, 17:34   #13  |  Link
PhrostByte
Grand Fruitioner
PhrostByte's Avatar
Compare an RGB capture and a YV12 capture. Decode the YV12 twice—once with AviSource() using FRAPS1, and once with FFVideoSource().ConvertToRGB().
Play with the matrix all you like in ConvertToRGB()—you won't be able to match the colors. The closest I've come is with TV-range Rec.709.
Old 28th August 2011, 23:02   #14  |  Link
TheFluff
A qualified guess says it's sRGB, but I don't know how to prove that theory.
Old 29th August 2011, 01:15   #15  |  Link
PhrostByte
Grand Fruitioner
PhrostByte's Avatar
sRGB mapped to YV12? I don't think so.
Old 12th November 2011, 17:25   #16  |  Link
zerowalker
So there is still no solution for this;O?
Old 14th November 2011, 21:08   #17  |  Link
Asmodian
You use RGB with fraps and convert to TV-range Rec.601 YV12 in avisynth (for upload to Youtube). The extra color space conversion, if there is one, is much preferred to using incorrect coefficients.
Old 15th November 2011, 18:19   #18  |  Link
zerowalker
ehm, i convert to rec.709, it makes the right colors i think, but i guess you mean that youtube will change it into Rec.601 not matter what;D?
Old 15th November 2011, 21:57   #19  |  Link
Asmodian
If your resolution is >=720p and you are not uploading to youtube use rec.709. <720p or uploading to youtube use Rec.601. This is from what I have read about youtube here, not my personal experiance with youtube.
Old 16th November 2011, 00:55   #20  |  Link
naoan
Strangely I found Rec601 to be the closest to the fraps RGB than any other matrix, even for >720p (though I haven't tried capturing <720p)
Here's comparison, using converttoyv12, matrix :
RGB http://i.minus.com/iVwzNF5ComoHr.png
Rec601 http://i.minus.com/ibmq7Nip0uyYl7.png
PC.601 http://i.minus.com/iuDNl3aVtHqiM.png
Rec709 http://i.minus.com/ipoQYVmGYqiF2.png
PC.709 http://i.minus.com/icwukCAqr1wJo.png
I also have to add --colormatrix bt470bg --fullrange off parameter on x264 or else madvr will treat it as fullrange BT.709 and shows it wrong.
naoan is offline   Reply With Quote
avisynth, decoder, fraps, x264, yv12
