Go Back   Doom9's Forum > Hardware & Software > PC Hard & Software
Old 21st May 2008, 15:37   #1  |  Link
phabian
phabian's Avatar
[Windows Movie Maker] saving avi, not wmv, and without changing resolution?
I have a few .avi clips in 704 x 576 format, imported them in Windows MovieMaker v2.1 and created one big movie.
Now, I want to save the result. But somehow it always wants to save as wmv, in 720x480 resolution. I just want to save it as a normal avi (using ffdshow encoder) and I *certainly* don't want to randomly change the resolution! (because going from 704x576 to 720x480 will cut off content and/or stretch it out of proportion)
How do I do this?
When choosing File -> Save Movie File, My Computer, it seems to insist on saving a 720x480 wmv file, or do I miss something? When choosing DV camera (I've read something about DV-AVI), it says "your camera is not connected" - well I don't even have a camera whatsoever, I just want to save a .avi file to my harddisk.
I hope someone can help me, thanks a lot in advance!
phabian is offline   Reply With Quote
Old 21st May 2008, 18:23   #2  |  Link
JohnnyMalaria
Save movie file...
My Computer
Name/location for saved file
If you only see (.) Best quality for playback on My Computer, click Show more choices...
(.) Other settings and choose DV-AVI (PAL)
I assume you want PAL based on your original video size. Make sure WMM is configured for PAL and not NTSC otherwise you won't see the option (goto Tools/Options/Advanced to change).
Note, DV AVI is the only AVI format WMM can save to.
John Miller
Enosoft DV Processor - Free for personal use
JohnnyMalaria is offline   Reply With Quote
Old 23rd May 2008, 23:52   #3  |  Link
Blue_MiSfit
Derek Prestegard IRL
Blue_MiSfit's Avatar
Windows Movie Maker is horribly inflexible when it comes to output.
JohnnyMalaria's suggestion only applies if your source material is in fact DV. Otherwise, you're screwed
All I can say is that if you're editing anything other than DV, you should probably use a more competent editor. Ulead, Pinnacle, Adobe, and Sony are all places to look
~MiSfit
avi, moviemaker, resolution
