4th August 2010, 12:46 | #2321 | Link | |
4th August 2010, 13:38 | #2322 | Link | |
You'd have to tell the app where to look for the path too. If it's in the registry you need to know the key. Why not simply do what most third-party apps do...make the user configure the program paths.
4th August 2010, 15:41 | #2323 | Link | ||
4th August 2010, 16:11 | #2325 | Link |
4th August 2010, 17:02 | #2326 | Link | |
* Can configure path for templates folder * Can choose desired template file (dialog opens in the configured templates folder) * Can enable or disable template file * Can configure overwrite or not if script already exists * The template file is no longer held locked by DGIndexNV after Save Project Let me know if the following build (32-bit) meets your needs and I will release it. http://neuron2.net/dgdecnv/templates.zip Delete your existing INI file to let DGIndexNV make a new one with the right stuff. Last edited by Guest; 4th August 2010 at 17:15. |
4th August 2010, 20:13 | #2327 | Link | |
AVS template part works just fine, however if you use the "File, Open" dialogue immediately after changing the template file it takes you to the template folder too. Also if you have already done a "File, Open" the template dialogue shows all files instead of just AVS. I suspect some shared ini variable problems. |
4th August 2010, 20:25 | #2328 | Link | ||
6th August 2010, 00:57 | #2330 | Link |
I've tested it on Win7 and gotten it working right. There are some differences for GetOpenFileName() on Win7 versus WinXP.
@all Heads up! I am changing my email address. My new address is: donald.graft @ cantab.net I am doing this to disconnect me from comcast so that I can change my provider. As an alumnus I get this address for life so I may as well use it. My old address (neuron2 @ comcast.net) will auto forward and auto reply for some time. |
6th August 2010, 13:33 | #2332 | Link |
About File-Open dialogs, I made the following experience in Delphi 7:
Having an empty "Path" property, the dialog opens in "My Documents" (since Windows XP). One could store paths and always put them into the property before executing the dialog. But a simple "." (dot) in it can also be convenient already, it should make the dialog open in the executable's directory (or the one which was set to the active directory in a link calling it). Might or might not help in this case. Maybe worth a try. |
6th August 2010, 19:38 | #2334 | Link |
Thanks, Groucho2004, that is very helpful. I'm working with hank315 on this and it appears likely it is the cause of the crashes in HCEnc 024 beta. Hank provided me an initial fixed build that looks promising here at work, although I need to test it at home on the machine that was regularly failing.
7th August 2010, 05:13 | #2335 | Link |
I get CU init failed & Failed to create video decoder (100) when attempting to do anything with the .avs file when accessing my system via remote desktop. I can't open the .avs in vdub, nor can I run an x264 encode. It works ok when not using remote desktop. Is there any work around for this? |
7th August 2010, 06:42 | #2336 | Link | |
PC specs for bug reports: Intel Core i7-4790K @4Ghz Win10(Linux VM) PCI express NVIDIA RTX 2060 SUPER graphics card http://twitter.com/cwebdesign |
7th August 2010, 07:32 | #2337 | Link | |
8th August 2010, 16:13 | #2338 | Link |
Build 2024
* Improved the AVS template handling functionality.
* Added an option in the Audio Demux dialog to permanently turn off audio processing/demuxing. The state of this option is shown on the audio demux menu pulldown. * Made some changes to CUDA context locking intended to eliminate possible crashing in some third-party applications. Successfully tested with MEGUI 0.3.5.6 and a build of HCEnc 024beta that Hank provided and will hopefully release soon. * Please delete your DGIndexNV.ini file so that a new one can be created. http://neuron2.net/dgdecnv/dgdecnv.html |
