17th May 2007, 15:36 | #1241 | Link | ||
17th May 2007, 16:19 | #1244 | Link |
I don't agree with disabling MPEG-1 audio. For example with ffdshow I can use volume normalization. I also know many people who use ffdhsow to upmix stereo MP3 to 5.1. Or are there any problems with the ffdshow decoder why it should be disabled?
One of the strong points of ffdshow is the fact, that it usually takes over any other decoders installed in system. So it can very often fix problems caused by various codecpacks. Edit: Maybe instead of it, we might want to create some easy to understand profiles during installation (with the option to choose details): 1) Enable only basic formats 2) Enable all fully supported formats (including VfW) 3) Enable everything Last edited by vlada; 17th May 2007 at 16:23. |
17th May 2007, 21:58 | #1245 | Link | |||
Doom9ing since 2001
My approach for installing Ffdshow has always been to let it handle only codecs which aren't already handled by other codecs on the system - unless there's a very good reason to do so. I think the installer's goal should be to fill the gaps in codec coverage, not try to patch existing codecs. Idealy there'd be a detection method in the installer that checks for present codecs - but at the least, I think Ffdshow should not replace decoders that are known to exist on every Windows OS (MP2/MP3, MPEG-1, WMA, WMV, etc.). |
18th May 2007, 01:42 | #1246 | Link |
@zambelli> But AFAIK currently ffdshow works right the opposite way. It has very high merit a replaces all existing filters (why everybody calls them codecs?). I think your request would be much better fulfilled if you just decreased ffdshow's merit and enabled all formats. Then ffdshow would be used only if there are no other filters installed.
My target is always to let ffdshow handle as much formats (why everybody calls them codecs?) as it can, because I want to use the same postprocessing filters for all formats (subtitles, volume normalization, downmix). I know I could just use ffdhow as RAW filter, but why not letting it do the decoding part too. I'm afraid we'll probably won't find a common attitude on this matter. That's why I suggest to prepare some presets so users can choose what they want. Informed people like you and me have no problems to select whatever they want. So I think we shouldn't care about what we need, but what setting will be the best for a common user. And unfortunately many users have their system damaged by different codecpacks. I already saved many people by telling them just to install ffdshow with default setting, if they had video playback problems and hoped to solve it by installing more and more codecpacks I agree it's sweeping the problem under the rug, but have you ever tried to explain to a common user how to work with Graphedit, identify problematic filters and disable them? The way ffdshow works now gains a lot of success because it solves many video playback issues people have. But I think it's up to the developers to decide which way they want to go. There are 2 extremes: Associate everything to ffdshow (my wish) or associate only formats not yet supported on the system (your wish). Maybe something between would be the right choice. |
18th May 2007, 10:37 | #1248 | Link |
@Leak
Thank you for your great work. It is getting more stable and I can report only one this meaningless issue. Code:
FadeIn(30) Well, my sample is meaningless test. But compatible behavior with original ffdshow is more likable for the case that buffering is not necessary. Here, I have a feature request. Please add a new check box "Enable buffering", off by default. Buffers back/ahead can be set 10/10 or something by default. With the check box off, "Buffers back/ahead", "Use Current", "3:2 Pulldown" is grayed out. The behavior can be as compatible as possible unless the original one is too buggy. It's good for not only compatibility but also user's convenience. |
18th May 2007, 11:26 | #1249 | Link | ||||
ffdshow/AviSynth wrangler
Since every time my filter skips ahead it adds 1000 to the frame number and rounds it up according to the input/output frame ratio - this works fine if the ratio is 5:4 with IVTC, or 1:2 with bobbing, but with a ratio of 10810800:10810801 the value to round to gets waaay too big and thus the current frame number is reset to 0. If you use FadeIn0, which doesn't add an extra frame at the very end of the clip (which you probably won't ever reach anyway), you won't get that problem, but you won't get the fade either (unless it's several thousand frames long), since all the resizing/re-connecting/re-you-name-it at the beginning of playback will make the filter seek ahead several thousand frames. I'm afraid there's not much I can do... if I don't seek ahead, you'll be getting green/double/wrong frames again, and if I go back to reseting AviSynth, people will complain about seeking/starting being slow, and the FadeIn is going to happen after every seek. Then again, using FadeIn doesn't make much sense, and FadeOut won't work anyway - it's best to only use filters in ffdshow that will do their magic on all frames of the video, and not just some fixed range of a clip that is a moving target. It does work when buffering is turned off, though, as seeking ahead only seeks ahead one frame then. Quote:
I was planning to add some code to figure out a "better" ratio if it's just off by a few frames (in a range of, say, -15 to +15 frames, by just trying them out), as any difference of a few frames with a clip that's 10 million frames long can be compensated by buffering an extra frame or two ahead at most. Quote:
Would a checkbox before "Buffers back/ahead" be sufficient? I really don't want tear the dialog design apart another time, which would be neccessary to fit another checkbox with label. I won't disable the pulldown options though, as they're independent from buffering - only "Apply pulldown" adds frames, and that's just using the current and the previous frame, so there's no lag introduced either since it doesn't buffer ahead. The pulldown part would even make sense as a filter on it's own - if you've got a TV connected to the PC you can make sure it gets it's 30 interlaced frames per second that way instead of leaving that up to the renderer. And smoothing the timestamps just averages the frame duration to get the oscillating between two frame lenghts out, but won't do anything else. I've also found that leaving the script empty produces no image at all; most probably because an empty script in the config is used to signal the filter to reset itself - that should probably be fixed... Also, it would probably be nice to change the FPS value in the output video headers as well instead of just mangling the timestamps - do you perhaps know where that information is stored?
now playing: [artist] - [track] ([album]) Last edited by Leak; 18th May 2007 at 11:39. |
18th May 2007, 12:53 | #1250 | Link | |||
18th May 2007, 14:33 | #1252 | Link |
What kind of compatibility issues are there? A whitelist was recently added to ffdshow to prevent the filter from being used by (possibly) incompatible applications/games.
MPC-HC 2.1.7.2 |
19th May 2007, 18:30 | #1254 | Link |
I am reverting one of the ffmpeg patches. That should hopefully fix the encoding crash. New build will be online asap.
MPC-HC 2.1.7.2 |
19th May 2007, 22:58 | #1257 | Link | |
Just saying... np: David Sylvian - Jean The Birdman (Everything And Nothing)
now playing: [artist] - [track] ([album]) |
20th May 2007, 02:35 | #1258 | Link |
Turkey Machine
Suggestion for the installer: have a sub-option on the codecs selection page, so the user can choose to use WMV or libavcodec, for WMV7, WMV8, WMV9, WVC1, *if* Microsoft codecs are installed. This is also assuming it's relatively easy to check whether the codecs are installed.....
On Discworld it is clearly recognized that million-to-one chances happen 9 times out of 10. If the hero did not overcome huge odds, what would be the point? Terry Pratchett - The Science Of Discworld |
20th May 2007, 13:02 | #1259 | Link |
The recent change (May 10th) for processor feature detection is making me sad.
The asm functions (check_cpu_features etc.) are declared in an extern "C" block in a .cpp file. This is making VC++ presume that their names should be completely undecorated. However, cpuid64.asm is built with PREFIX defined, and with PREFIX defined, functions gain a leading underscore. In other words, cpuid64.obj exports a function _check_cpu_features, but the linker is looking for check_cpu_features. Easiest thing would be to remove the PREFIX define. |
20th May 2007, 13:40 | #1260 | Link |
Edit: you should have SVN access now. So you can commit fixes.
MPC-HC 2.1.7.2 Last edited by clsid; 20th May 2007 at 13:46. |
