14th April 2018, 14:50 | #101 | Link | ||||
French Registered User
And here, can you see the differences ?
Don't tell me that you can't see them please ! See how the background moves, the sensation of weight of the characters and objets, the fluidity... I know it looks identical with static pictures. I admit that it's hard to see. But there are subtle differences that make the sensation different too. It's not only a question of "how it looks", but "how it moves" ! You will only see it if you watch the videos in fullscreen and with 1080p or 4k resolution. Here is a new video, with a new script : https://youtu.be/PrrUjauNGto I called the new script "Ultimate style - Clean version" It's a comparison between "Booya style" and "Ultimate style" ! [Edit : I did a new version of the script, with a more "old" look. It's interesting, because it's modern, but reminds the old sensations I find. But I kept the "Clean version", so I have a pure modern look or a mix modern/old... still without the scanlines or grids ] Script for booya style with 8:7 aspect ratio : Quote:
Script for ultimate style clean version with 8:7 aspect ratio : Quote:
https://media.joomeo.com/original/5ad3dc5ce628e.png Script for booya style with 4:3 aspect ratio : Quote:
Script for ultimate style clean version with 4:3 aspect ratio : Quote:
https://media.joomeo.com/original/5ad3dcb96b9aa.png What do you think ? Last edited by SuperLumberjack; 18th April 2018 at 12:30. |
14th April 2018, 19:04 | #103 | Link |
Retro games look much better with CRT emulation enabled. Your upscalled images look weird and unnatural. Games didn't look like this in old days.
I definitely prefer this over your weird upscalling routine. https://www.youtube.com/watch?v=B8Jea_k5DI4
14th April 2018, 19:55 | #104 | Link |
Yes I know, but the videos with scanlines can be problematic if not watched in full screen, you know !
It's not for nothing that I try to find something in between, a subtitute But I have to do lots of experimentations... You know what ? I will share the original videos. So you will be able to test, if you want It's interesting me, because I'm not a big boss with AviSynth Last edited by SuperLumberjack; 14th April 2018 at 20:19. |
14th April 2018, 20:39 | #105 | Link |
I think it's not so bad with my last script (even if I know that it's hard to see differences with static images, but I persist to say that I can see them with movement in videos)
https://media.joomeo.com/original/5ad3dedddbcce.png Video to compare : https://www.youtube.com/watch?v=51iwiDlcQKk https://media.joomeo.com/original/5ad3df1c6069e.png Video to compare : https://www.youtube.com/watch?v=YXW6OOGxC-k But it will never be like in the old days, it's clear ! Last edited by SuperLumberjack; 16th April 2018 at 00:25. |
14th April 2018, 21:32 | #106 | Link |
Here are the video, if you want to test :
https://mega.nz/#!K5FRlJhb!pKqQ06WOn...yGiozQuikkk77A For the Donkey Kong Country games, the output resolution must be 1410x1080 or 2820x2160, and for Mr. Nutz and Super Mario World it must be 1234x1080 or 2468x2160. Last edited by SuperLumberjack; 4th May 2018 at 10:44. |
15th April 2018, 01:01 | #107 | Link |
The difference between the renderer on a CRT and a LCD is quite impressive :
https://www.youtube.com/watch?v=6Iwq-blhOtE Hard to reproduce I think... |
15th April 2018, 17:28 | #108 | Link | |
This looks very convincing to me https://youtu.be/xrpm8o17cHE?t=16m11s
15th April 2018, 18:14 | #109 | Link | |
Retried Guesser
This is a shader effect BTW - maybe @MysteryX can help in getting them to work in AviSynth Shader. Shader source: https://github.com/libretro/slang-sh...ree/master/crt |
15th April 2018, 20:19 | #110 | Link |
Eurobeat Fan
I made some research on this a few days ago and found the same picture as Atak_Snajpera.
Appearently the source is this one: http://forums.ppsspp.org/showthread....9617#pid109617 (I guess what raffriff found was the source of the shader used in the video, instead) The author offers the fragment shader code, but it is designed to work with the PPSSPP emulator (which I have never used). We really need MysteryX's help here. It's not just the CRT grid, but also the bowing effect that makes me doubt wether this is an actual screen or not: |
16th April 2018, 06:36 | #113 | Link | |
Somebody knows for the anti-ringing please ?
https://media.joomeo.com/original/5ad08bdd809a6.png Without the anti-ringing filter in MadVR : https://media.joomeo.com/original/5ad08c0657899.png With the anti-ringing filter in MadVR : https://media.joomeo.com/original/5ad08c21358af.png Last edited by SuperLumberjack; 16th April 2018 at 07:20. |
16th April 2018, 23:58 | #114 | Link |
Retried Guesser
I have two humble suggestions. Forgive me if either one has been mentioned before in this thread.
One is PointSize to smooth the jaggies and create the partial illusion of higher resolution. http://forum.doom9.org/showthread.php?t=154674 http://en.wikipedia.org/wiki/Pixel_a...ing_algorithms http://avisynth.nl/index.php/PointSize PointSize only scales by integer factors such as 2x, 3x, 4x. The other is GaussResize to perform the final resize and aspect ratio correction. GaussResize does not ring at all; no de-ringing is needed. http://avisynth.nl/index.php/Resize#GaussResize Code:
LoadPlugin("<path>\PointSize_x64.dll") ## (source RGB32) LQx(4) ## retains some jaggies (best for 'digital' look) #xBRZ(2) ## softer gradients (best for 'smooth' look) ConvertToYV12(matrix="Rec709") ## (other filters here -- try QTGMC for example) GaussResize(1408, 1080, p=70) (LQx) (xBRZ) Last edited by raffriff42; 17th April 2018 at 00:56. Reason: typpo |
17th April 2018, 01:35 | #115 | Link | ||
Very interesting raffriff42 ! Thanks !
But a light "Oil painting" effect... Sorry, but I'm not totally convinced But however, it's interesting ! Apart from that, I did an alternative version of my "Ultimate script" I called it "New vintage version" This video of comparison between a CRT display and a LCD display inspired me : https://www.youtube.com/watch?v=6Iwq-blhOtE My impression was that with the CRT display, the picture has almost a HD look with low resolution material (a Super Nintendo game in this case) compared to the LCD display which is showing big pixels, even if in reality, it's the LCD which is HD I found that we have approximately the sensation of a vertical resolution 4 times bigger ! So I tried to do a trick I remind you that I choose to begin with a upscaling of the resolution 320x240, so I rose up to 2560x7680 and reduce the horizontal resolution to 1280 with PointResize. It's like a vertical resolution approximately 4X more defined. To create this script, I used this video of Donkey Kong Country played on a CRT display as a model : https://www.youtube.com/watch?v=3GtsHXgB4lM And this too : https://www.youtube.com/watch?v=X3egFl03LVc To have a similar image without scanlines or grids, I find it's not so bad : https://media.joomeo.com/original/5ad67461ab76f.png https://media.joomeo.com/original/5ad6749b24a9b.png Anyway, it has always been a kind of trick or illusion ! So, I tried to do the same to get relief ! Here is my script : Script for ultimate style new vintage version with 8:7 aspect ratio : Quote:
https://media.joomeo.com/original/5ad671ef5d28f.png Script for ultimate style new vintage version with 4:3 aspect ratio : Quote:
https://media.joomeo.com/original/5ad6724d0a1f6.png I will do a video soon, because it's hard to see the differences with screenshots ! Last edited by SuperLumberjack; 17th April 2018 at 23:30. |
17th April 2018, 17:45 | #116 | Link | |
Soul Architect
17th April 2018, 23:37 | #118 | Link |
Here is a new video I did to compare my script "Ultimate style - Clean version" with "Ultimate style - New vintage version" :
https://youtu.be/uVmmpPIkKPY Last edited by SuperLumberjack; 19th April 2018 at 00:19. |
18th April 2018, 02:46 | #119 | Link |
Oh gosh, please just simply number your test scripts, no one cares about what they call.
For the ringing problem, you'll need to go with some higher end resizer like nnedi3. And it's pretty clear now that adding a shader on top gives the best visual effect for these retro games. As the main problems with these low resolution images are the pixelated diagonal lines and the lack of texture when upscaled, so you can't blur them because that will turn them into ugly color blocks. The vertical and gird shader looks like the answer here, as they both added fake details to "smooth" out the diagonal lines and added fake "textures" into the color blocks. |
18th April 2018, 04:51 | #120 | Link | |
Retried Guesser
Which gives me an idea! Suppose we emulate the shader by
LoadPlugin("<path>\PointSize_x64.dll") ## (source RGB32) xBRZ(2) Org = Last Org GaussResize(1408, 1080, p=70) ConvertToYV24 gridmask_square(2) ConvertToRGB32 Trim(0, length=1) Loop(Org.FrameCount) Dots = Last Org GaussResize(1408/4, 1080/4, p=70) PointResize(1408, 1080) ShiftRedBlue(rx = -2, bx = +2) Overlay(Dots, mode="darken", opacity=0.25) Levels(0, 1.0, 255-64, 0, 255, coring=false) ConvertToYV12(matrix="Rec709") return Last # https://forum.doom9.org/showthread.php?p=1803247#post1803247 ################################## ### shift and/or resize Red and Blue relative to Green ## ## @ rx, ry, bx, by - "shift" red & blue position ## @ rxd, ryd, bxd, byd - "delta" width & height ## function ShiftRedBlue(clip C, \ float "rx", float "ry", \ float "bx", float "by", \ float "rxd", float "ryd", \ float "bxd", float "byd") { Assert(C.IsRGB, \ "ShiftRedBlue: source must be RGB") rx = Float(Default(rx, 0)) ry = Float(Default(ry, 0)) bx = Float(Default(bx, 0)) by = Float(Default(by, 0)) rxd = Float(Default(rxd, 0)) ryd = Float(Default(ryd, 0)) bxd = Float(Default(bxd, 0)) byd = Float(Default(byd, 0)) C return (C.IsRGB24) \ ? MergeRGB( \ ShowRed.Spline64Resize(Width, Height, -rx, -ry, Width-rxd, Height-ryd) \ , ShowGreen \ , ShowBlue.Spline64Resize(Width, Height, -bx, -by, Width-bxd, Height-byd) \ ) \ : MergeARGB( \ ShowAlpha \ , ShowRed.Spline64Resize(Width, Height, -rx, -ry, Width-rxd, Height-ryd) \ , ShowGreen \ , ShowBlue.Spline64Resize(Width, Height, -bx, -by, Width-bxd, Height-byd) \ ) } ## http://forum.doom9.org/showthread.php?t=170433 ####################################### ### create a fixed pattern of dots. function gridmask_square(clip C, int size) { C return mt_logic( \ mt_lutspa(mode="absolute", chroma="-128", \ expr="x "+String(size)+" / pi * cos 108 * 126 + "), \ mt_lutspa(mode="absolute", chroma="-128", \ expr="y "+String(size)+" / pi * cos 108 * 126 + "), \ "andn") } Last edited by raffriff42; 18th April 2018 at 11:56. Reason: image |
