26th June 2010, 05:24 | #481 | Link |
I am still using aacekeys but this is for my older BD titles and my entire HD-DVD collection which I am ripping to AVCHD format. But if folks post keys MKBV16 and above and I have that title I presume I can just put that key into the config.db and then dumphd can use it?
26th June 2010, 06:18 | #482 | Link |
Spock
That is correct as long as the volume unique key matches the region of the Blu ray disc you are trying to decypt. Then Dumphd will decrypt and rip it to your hard drive. By the way, new BD+ protection such as the movie Avatar won't work.
2nd December 2010, 09:39 | #483 | Link |
Hi, i have question about aacskeys implementation.
In authType == AACSAUTH mode, when it needed to read volume id of media, for prerecorded(read-only media) it just read volume id, but when for recordable(rewritable media) it also reads bn(binding nonce?). So my question is why? I read spec(AACS_Common_cryp...) but there is nothing about reading binding nonce to get volume id, where you get this info? P.S. sorry for my english. |
2nd December 2010, 21:33 | #484 | Link | |
3rd December 2010, 07:54 | #485 | Link |
thanks alot KenD00!
I compared content decrypting procedure for prerecorded and recordable media, and understood that Binding Nonce and Volume ID is used for same purpose. But one thing is not clear to me, how to get Binding Nonce(volume id is simple, after we get bus_key, we simply call for function to read volume id). In AACS_Common... book, i find procedure to read binding nonce from media, but we must send to it some LBA, so what LBA we must send? I think "For BD-R / RE, the Binding Nonce shall be stored in the User Control Data associated with the first logical Sector of the CPS Unit Key File and shall be non-zero value.", am i right? |
7th December 2010, 07:28 | #487 | Link |
Hi KenD00, now i\'m learning MKB processing part of the aacskeys programm, and have some questions. Before finding appropriate Subset-Difference Record value via
if ((u_mask == device_key_u_mask) && (v_mask == device_key_v_mask)) but before this we must check this condition, or not? ((Dnode & mu ) == (uv & mu)) and ((Dnode & mv) != (uv & mv)) (i get it from aacs_common...) where i must get Dnode(from Subset-Difference index record?). btw, i also want to know, is it possible to know protection type of media, e.g. BD+, AACS or no protection? Thanks, alot! Sorry for my english. |
7th December 2010, 09:21 | #488 | Link |
3.2.3 Storing Device Keys
Each device is given its Device Keys and a 31-bit number d called the device number. For each Device Key, there is an associated number denoted the path number, and the “u” bit mask, mu, and the “v” bit mask, mv. ... 3.2.4 Calculation of Media Key It finds the appropriate stored Device Key as follows: assuming the Explicit Subset-Difference Record value is uv, mu, and mv, and the stored Device Key has uv’, m’u, and m’v, the appropriate Device Key is the one that meets the following condition: (mu == m’u) and ((uv & m’v) == (uv’ & m’v)) it is from aacs_common.... where i can find device\'s m\'v, m\'u and uv\'? |
13th December 2010, 23:43 | #489 | Link | |
The presence of BD+ seems to be determined by the presence of the BDSVM directory (and maybe the 3 VM files inside it) only, but i don't know that much about BD+. About the Subset Difference algorithm you are asking the wrong guy . I never really understood how it works and im afraid i already forgot the part i did understand . Afaik we don't have the uv number of the device keys but just brute force all possible values but i'm really not sure about this, i'm afraid you have to look at the code and figure that out yourself. |
25th March 2011, 08:18 | #491 | Link | |
Hi!
[EDIT: Ahh, I just read some where, that currently only MKB up to v16 work, right? :-/] I've installed the patched firmware version 1.03 on my GGC-H20L and it seems to work (I get some info after the sg_raw commands), but when I try to use aacskeys with the last 16 bytes of output I get still: Quote:
Regards Last edited by neXyon; 25th March 2011 at 08:31. |
27th April 2011, 00:42 | #493 | Link |
I'm having a similar problem. using the DumpHD GUI
DumpHD 0.61 by KenD00 Opening Key Data File... OK Initializing AACS... OK Loading aacskeys library... OK aacskeys library 0.4.0 by arnezami, KenD00 Loading BDVM... OK BDVM 0.1.5 Initializing source... Disc type found: Blu-Ray BDMV Collecting input files... Source initialized Identifying disc... OK DiscID : --------- Searching disc in key database... Disc not found in key database Retrieving keys from source... aacskeys 0.4.0 by arnezami, KenD00 Current path: ----- MKBv: 12 Could not find a Processing Key or Device Key resulting in the Media Key. Possible key tried: ----- Possible key tried: ----- Possible key tried: ----- Possible key tried: ----- Possible key tried: ----- Possible key tried: ----- ERROR: PROCESSMKB, errnr: -3 aacskeys ERROR: PROCESSMKB, errnr: -3 Failed retrieving keys from source I removed a lot of the key information I didn't want to take a chance on breaking a rule in my first post. Thanks for all the great work. If only I knew what I was doing.. |
30th April 2011, 17:45 | #494 | Link |
only mkbv 1 to 10 are in aacskeys
you want to decrypt mkbv >10 if you want to decrypt mkbv >10 add keys in ProcessingKeys.txt (only if you have this key , only makemkv / dvdfab / anydvd and legal software have this key ...) |
13th August 2011, 15:08 | #495 | Link |
Hey guys,
when I compile "aacskeys-0.4.0c" I get the following error: Code:
make ==== Building aacskeys ==== ioctl.cpp src/ioctl.cpp: In constructor ‘Drive::Drive()’: src/ioctl.cpp:12:61: warning: converting to non-pointer type ‘int’ from NULL mmc.cpp aacs_ecdsa.cpp cmac_aes.cpp aacs_aes.cpp aacskeys.cpp cmac.cpp Linking aacskeys ==== Building libaacskeys ==== ioctl.cpp src/ioctl.cpp: In constructor ‘Drive::Drive()’: src/ioctl.cpp:12:61: warning: converting to non-pointer type ‘int’ from NULL mmc.cpp aacs_ecdsa.cpp cmac_aes.cpp aacs_aes.cpp aacskeys.cpp In file included from src/aacskeys.cpp:33:0: src/aacskeys.h:8:17: fatal error: jni.h: Datei oder Verzeichnis nicht gefunden compilation terminated. make[1]: *** [obj/linux/ReleaseLib/aacskeys.o] Fehler 1 make: *** [libaacskeys] Fehler 2 Code:
==== Regenerating Makefiles ==== make: premake: Kommando nicht gefunden make: *** [Makefile] Fehler 127 ---------------------------------------------------------------------- EDIT: Ok, I got it. Had to install sun-java6-jdk from a special rep. and activate it under ubuntu 11.04. ---------------------------------------------------------------------- Greetings Hoppel Last edited by hoppel118; 13th August 2011 at 17:24. |
13th September 2011, 16:17 | #496 | Link |
Btw. just noting there are some new MKB keys at the Japanese site. Did someone already test them? I only have a few MKBv19 and some MKBv17 disks, they work fine....
13th September 2011, 18:00 | #497 | Link | |
I've only got discs up to MKBv19, so I can't vouch for the last 2 keys either. The lower ones work on all of the discs I wasn't able to decrypt yet though. |
17th September 2011, 00:49 | #499 | Link |
Spock
Check this out!
spock-desktop aacskeys-0.4.0c # aacskeys -v /media/SOURCE_CODE aacskeys 0.4.0 by arnezami, KenD00 Current path: /bin/aacskeys-0.4.0c MKBv: 25 Processing key: C32238976FF44A51E2D33553CFE85772 Encrypted C-value: 21453D416FAC679D0B5785C35506F045 Corresponding uv: 00000384 Decrypted C-value: 0CD5953716C906557AA362D5EC030855 Media key: 0CD5953716C906557AA362D5EC030BD1 Encrypted verification data: 50B076C4E6A45575263D47D488138839 Decr verif data should be: 0123456789ABCDEF Decrypted verification data: 0123456789ABCDEF3BD1C55692D74042 Drive FW info: YL05 AACS Version: 01 Number of concurrent AGIDs: 1 Supports BN generation: YES BN Block Count: 1 Inserted medium AACS protected: YES AGID: 00 Volume ID (AACSBYPASS): EF0627C1BE85BF658399F665B67C45B4 Volume Unique Key: 8141810DCD755C64F38200D2393990EB Unit Key File Hash (Disc ID): 168106D53C544B57395FCE6CD3EF8D0B5CC97FA6 Encrypted Unit Key 1: 9E0446F068D84C6799B771A009440777 Encrypted Unit Key 2: A6BEEDE353622F48425602DABB570A50 Encrypted Unit Key 3: 08F66271FEC236E8FEAC58B821003D4C Encrypted Unit Key 4: A053961713EC96FD7A64F82B59CD7615 Decrypted Unit Key 1: 947573F10C07E3C2AC45C12B04A3512E Decrypted Unit Key 2: 7B7A09E9451E320B0F5EAE899DE0E7EB Decrypted Unit Key 3: 752E9F700DB971D1FE73CF44B092CDB0 Decrypted Unit Key 4: 8841D33A4FD57589A827CE16AC343125 |
3rd October 2011, 03:17 | #500 | Link |
Following an attempt to play a BD disk (Pink Floyd The Dark Side of the moon)
Any attempts to read another disk is now failing with an error "The given Host Certficate / Private Key has been revoked by your drive." aacskey returns the same errors. Thanks in advance JY Last edited by Guest; 3rd October 2011 at 05:01. Reason: no solicitation of keys (refer to stickie) |
